cgal-discuss - [cgal-discuss] Triangulate Polyhedron (not point-set)
  • To:
  • Subject: [cgal-discuss] Triangulate Polyhedron (not point-set)
  • Date: Fri, 25 Apr 2014 15:02:26 -0700 (PDT)
Many of the polyhedral algorithms (including AABB tree) require pure-triangle
polyhedrons. Is there any way to take an already-made polyhedron and ensure
all facets are triangles? The is a 2D polygon version of this
(approx_convex_partition_2) which uses Constrained_triangulation_2 and then
removes edges added outside of the original polygon.
If something does not exist, I will try to implement it as follows:
// end will grow with extra triangles as we call split_facet()
Polyhedron_3::Facet_iterator end = P->facets_end();
for (Polyhedron_3::Facet_iterator f = P->facets_begin(); f != end; ++f)
if (f->is_quad())
// simple case, already implemented
// use split_facet on one of the two diagonals
// being careful with concave/degenerate quads
else if (!f->is_triangle())
// convert facet to a Polygon_2
// run approx_convex_partition_2 on the polygon
// tricky part: find all the added edges and figure out
split_facet calls
to make
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulate-Polyhedron-not-point-set-tp4659203.html
