- To:
- Subject: Re: [cgal-discuss] vertex and edge iterator for arrangment_2
- Date: Sun, 27 Apr 2014 08:18:37 +0300
Use point location, such as CGAL::Arr_landmarks_point_location?
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Sun, Apr 27, 2014 at 6:43 AM, dg <> wrote:
Hello,
I need to find a vertex or edge iterator from an arrangement_2 data
structure.
Now, given the vertex (x,y) or the segment (<x1,y1>, <x2,y2>), Can I do a
O(1) lookup into the arrangement_2 and get the corresponding vertex or edge
iterator ?
Currently, I am doing it in a naive way in which I iterate through all the
vertices using vertex_iterator and searching for the required one. the other
approach I have in mind is to create a hash map of the iterators.
Thanks.
dg.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/vertex-and-edge-iterator-for-arrangment-2-tp4659208.html
- [cgal-discuss] vertex and edge iterator for arrangment_2, dg, 04/27/2014
- Re: [cgal-discuss] vertex and edge iterator for arrangment_2, Efi Fogel, 04/27/2014
- Re: [cgal-discuss] vertex and edge iterator for arrangment_2, dg, 04/29/2014
