- To:
- Subject: Re: [cgal-discuss] Assign z-coordinate as extra information in a point
- Date: Fri, 2 May 2014 13:40:08 -0700
Sebastien,
Thank you.http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Point__3.html
If I'm reading it correctly, the coordinate value is a Kernel::FT, which is a Lazy_exact_nt< ..> for which I've searched for conversion functions.
typedef CGAL::Triangulation_vertex_base_with_info_3<int, K> Vb;
/// Store the timeslice number in each vertex
Delaunay::Finite_vertices_iterator vit;
for (vit = S3->finite_vertices_begin(); vit != S3->finite_vertices_end(); ++vit)
vit->info() = (int) vit->point().z();
┌─[getchell][Hapkido][±][master ✗][~/CDT-plusplus]
└─▪ make
Scanning dependencies of target cdt
[100%] Building CXX object CMakeFiles/cdt.dir/cdt.cpp.o
In file included from /Users/getchell/CDT-plusplus/cdt.cpp:20:
/Users/getchell/CDT-plusplus/spherical_3_complex.h:96:19: error: cannot convert 'typename cpp11::result_of<typename
R::Compute_z_3 (Point_3<Epeck>)>::type' (aka 'Lazy_exact_nt<typename boost::remove_cv<typename
boost::remove_reference<typename cpp11::result_of<Compute_z_3<Simple_cartesian<Gmpq> >
(E0)>::type>::type>::type>') to 'int' without a conversion operator
1 error generated.
make[2]: *** [CMakeFiles/cdt.dir/cdt.cpp.o] Error 1
make[1]: *** [CMakeFiles/cdt.dir/all] Error 2
make: *** [all] Error 2
On Fri, May 2, 2014 at 12:12 AM, Sebastien Loriot (GeometryFactory) <> wrote:
vit->point().z()
Sebastien.
On 05/02/2014 08:53 AM, Adam Getchell wrote:
about.me/adamgetchell <http://about.me/adamgetchell>Hello all,
I would like to assign the z-coordinate of a point inserted into a
Delaunay triangulation as an extra bit of information, the timeslice number.
In brief, I have:
template <typename T>
void make_S3_simplicial_complex(T* S3, int number_of_simplices, int
number_of_timeslices) {
/// Start with a 3D sphere with two simplices
S3->insert(typename T::Point(0,0,0));
S3->insert(typename T::Point(1, 0, 0));
S3->insert(typename T::Point(0, 1, 0));
S3->insert(typename T::Point(0, 0, 1));
S3->insert(typename T::Point(0, 0, -1));
vit->info() = 1;
/// Debugging: print out each vertex and the timeslice number associated
std::cout << '(' << vit->point() << ") (timeslice = " <<
vit->info() << ")" << std::endl;
assert(S3->dimension() == 3);
Where I'd like to use:
vit->info() = vit->z()
or
vit->info() = vit->point()::cartesian(2)
or the appropriate member function.
Here's the full code listing:
https://github.com/acgetchell/CDT-plusplus/blob/master/spherical_3_complex.h
Which currently compiles.
Any pointers greatly appreciated!
Thank you!
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu
Adam Getchell
"Invincibility is in oneself, vulnerability in the opponent." -- Sun Tzu- [cgal-discuss] Assign z-coordinate as extra information in a point, Adam Getchell, 05/02/2014
- Re: [cgal-discuss] Assign z-coordinate as extra information in a point, Sebastien Loriot (GeometryFactory), 05/02/2014
- Re: [cgal-discuss] Assign z-coordinate as extra information in a point, Adam Getchell, 05/02/2014
- Re: [cgal-discuss] Assign z-coordinate as extra information in a point, Adam Getchell, 05/03/2014
