cgal-discuss - Re: [cgal-discuss] Error when add constraint in 2D Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Error when add constraint in 2D Triangulation
  • Date: Mon, 05 May 2014 07:35:17 +0200
On 05/04/2014 11:49 AM, fromradio wrote:
I had the same question in my project and I tried to use some simpler kernel
like CGAL::Simple_cartesian<double> and it works now. I hope this
information can help you.
This is not a correct solution (simply luck I think).
See: http://www.cgal.org/philosophy.html
The issue you observe comes from the fact that due to an inexact
construction, the intersection points of 2 segments falls outside of the
segments.
We started working on the issue but then other things with
higher priority came up...
We'll post a patch in this thread when we find time to work on the issue.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-when-add-constraint-in-2D-Triangulation-tp4658916p4659242.html
