- To:
- Subject: Re: [cgal-discuss] alpha shapes 2D
- Date: Sat, 10 May 2014 18:39:09 +0200
Hi iMunk,
So, what means this output? if I think in points, that one correspond to theeach row is one segment with 2 2D points (format: source.x source.y target.x target.y)
convex hull. Why 4 row? why 4 columns?
After googling intensively, I found out that there is no direct way to output polygon from Alpha shape 2D.
Here is one discussion about how to extract ordered polygon from alpha shape:
http://cgal-discuss.949826.n4.nabble.com/Convert-Alpha-Segments-to-an-ordered-Polygon-td3575098.html
However, that discussion only gives suggestions.
Below is my example code to compute general polygon (Polygon_with_holes_2) from alpha shape.
This code works for REGULARIZED alpha shape (meaning no isolated points or sub polygons).
Attached file is plot of an example output polygon.
// form polygons from alpha shape
inline void alpha_to_polygon(const Alpha_shape_2& A, Polygon_with_holes_2& out_poly) {
typedef typename AlphaShape2::Vertex_handle Vertex_handle;
typedef typename AlphaShape2::Edge Edge;
typedef std::vector<Edge> EdgeVector;
// form vertex to vertex map
std::map<Vertex_handle, EdgeVector> v_edges_map;
for (auto it = A.alpha_shape_edges_begin(); it != A.alpha_shape_edges_end();
++it) {
auto edge = *it; // edge <=> pair<face_handle, vertex id>
const int vid = edge.second;
auto v = edge.first->vertex((vid + 1) % 3);
if (v_edges_map.count(v) == 0) v_edges_map[v] = EdgeVector();
v_edges_map[v].push_back(edge);
// form all possible boundaries
std::vector<Polygon_2> polies;
std::vector<double> lengths;
double max_length = 0;
int max_id = 0;
std::set<Edge> existing_edges;
for (auto it = v_edges_map.begin(); it != v_edges_map.end(); ++it) {
if (existing_edges.count((*it).second.front()))
continue;
auto begin_v = (*it).first;
auto next_e = (*it).second.front();
auto next_v = next_e.first->vertex((next_e.second + 2)%3);
Polygon_2 poly;
poly.push_back(next_v->point());
existing_edges.insert(next_e);
if (v_edges_map[begin_v].size() > 1)
v_edges_map[begin_v].erase(v_edges_map[begin_v].begin());
double length = CGAL::squared_distance(begin_v->point(), next_v->point());
while (next_v != begin_v && v_edges_map.count(next_v) > 0) {
next_e = v_edges_map[next_v].front();
if (v_edges_map[next_v].size() > 1)
v_edges_map[next_v].erase(v_edges_map[next_v].begin());
auto t_next_v = next_e.first->vertex((next_e.second + 2)%3);
length += CGAL::squared_distance(next_v->point(), t_next_v->point());
next_v = t_next_v;
if (max_length < length) {
max_length = length;
max_id = polies.size();
polies.push_back(poly);
lengths.push_back(length);
// build polygon with holes
// the first one is outer boundary, the rest are holes
Polygon_2 outer_poly = polies[max_id];
polies.erase(polies.begin() + max_id);
out_poly = Polygon_with_holes_2(outer_poly, polies.begin(), polies.end());
William
Quoting iMunk
Hi every body, I am a medium c++ programmer and I want to use the CGAL
library to calculate the alpha shapes of a collection of points in a two
dimension space. I have read the manual of this class and I've a specific
question about the follow example
doc.cgal.org/latest/Alpha_shapes_2/index.html.
After copy that code in my computer and compile in the correct form in
Ubuntu, I execute it successfully. However
1) Despite my points form a surface with cavities, for instance you can
think in this set (0,2), (-0.5,1), (0,1), (0.5,1), (-2,0), (-1,0), (0,0),
(1,0), (2,0), (-0.5,-1), (0,-1), (0.5,-1), (0,-2) of points, the output in
before code coincide with the convex hull, I mean, the output is
-2 0 0 -2
0 -2 2 0
0 2 -2 0
2 0 0 2
I wish a output for the previous set of points --> (0,2), (-0.5,1),
(0.5,1), (-2,0), (2,0), (-0.5,-1), (0.5,-1), (0-2) which I think coincide
with the appropriate alpha shapes.
Any one can help me?
Thanks in advance.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/alpha-shapes-2D-tp4659269.html
Description: PNG image
- [cgal-discuss] alpha shapes 2D, iMunk, 05/10/2014
- Re: [cgal-discuss] alpha shapes 2D, Thanh Quoc Nguyen, 05/10/2014
- Re: [cgal-discuss] alpha shapes 2D, iMunk, 05/12/2014
- Re: [cgal-discuss] alpha shapes 2D, Thanh Nguyen, 05/12/2014
- Re: [cgal-discuss] alpha shapes 2D, iMunk, 05/14/2014
- Re: [cgal-discuss] alpha shapes 2D, iMunk, 05/25/2014
