- To:
- Subject: Re: [cgal-discuss] Instalation CGAL Windows 8 Visual Studio 2010
- Date: Mon, 12 May 2014 04:02:13 -0700 (PDT)
I have retry and CMAKE works.
I have the .sln project.
But, when I debug it the next error appered:
<http://cgal-discuss.949826.n4.nabble.com/file/n4659283/errorCGAL%282%29.png>
1>------ Operación Generar iniciada: proyecto: ZERO_CHECK, configuración:
Debug Win32 ------
1>Compilación iniciada a las 12/05/2014 12:53:52.
1>PrepareForBuild:
1> Creando directorio "C:\dev\CGAL-4.3\build\Debug\".
1>InitializeBuildStatus:
1> Se creará "Win32\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" porque
se especificó "AlwaysCreate".
1>CustomBuild:
1> Checking Build System
1> CMake does not need to re-run because
C:/dev/CGAL-4.3/build/CMakeFiles/generate.stamp is up-to-date.
C:/dev/CGAL-4.3/build/src/CMakeFiles/generate.stamp is up-to-date.
C:/dev/CGAL-4.3/build/src/CGAL/CMakeFiles/generate.stamp is up-to-date.
C:/dev/CGAL-4.3/build/src/CGAL_Core/CMakeFiles/generate.stamp is up-to-date.
C:/dev/CGAL-4.3/build/src/CGAL_ImageIO/CMakeFiles/generate.stamp is
up-to-date.
C:/dev/CGAL-4.3/build/src/CGAL_Qt3/CMakeFiles/generate.stamp is up-to-date.
C:/dev/CGAL-4.3/build/src/CGAL_Qt4/CMakeFiles/generate.stamp is up-to-date.
1>FinalizeBuildStatus:
1> Se eliminará el archivo
"Win32\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild".
1> Aplicando tarea Touch a
"Win32\Debug\ZERO_CHECK\ZERO_CHECK.lastbuildstate".
1>
1>Compilación correcta.
1>
1>Tiempo transcurrido 00:00:00.80
2>------ Operación Generar iniciada: proyecto: CGAL, configuración: Debug
Win32 ------
2>Compilación iniciada a las 12/05/2014 12:53:54.
2>PrepareForBuild:
2> Creando directorio "C:\dev\CGAL-4.3\build\bin\Debug\".
2>InitializeBuildStatus:
2> Se creará "CGAL.dir\Debug\CGAL.unsuccessfulbuild" porque se especificó
"AlwaysCreate".
2>CustomBuild:
2> Building Custom Rule C:/dev/CGAL-4.3/src/CGAL/CMakeLists.txt
2> CMake does not need to re-run because
C:\dev\CGAL-4.3\build\src\CGAL\CMakeFiles\generate.stamp is up-to-date.
2>ClCompile:
2> all_files.cpp
2>MakeDirsForLink:
2> Creando directorio "C:\dev\CGAL-4.3\build\lib\Debug\".
2>Link:
2> Creando biblioteca
C:/dev/CGAL-4.3/build/lib/Debug/CGAL-vc100-mt-gd-4.3.lib y objeto
C:/dev/CGAL-4.3/build/lib/Debug/CGAL-vc100-mt-gd-4.3.exp
2>LinkEmbedManifest:
2> CGAL.vcxproj -> C:\dev\CGAL-4.3\build\bin\Debug\CGAL-vc100-mt-gd-4.3.dll
2>PostBuildEvent:
2> 1 archivo(s) copiado(s).
2>FinalizeBuildStatus:
2> Se eliminará el archivo "CGAL.dir\Debug\CGAL.unsuccessfulbuild".
2> Aplicando tarea Touch a "CGAL.dir\Debug\CGAL.lastbuildstate".
2>
2>Compilación correcta.
2>
2>Tiempo transcurrido 00:00:18.93
3>------ Operación Generar iniciada: proyecto: CGAL_Core, configuración:
Debug Win32 ------
4>------ Operación Generar iniciada: proyecto: CGAL_ImageIO, configuración:
Debug Win32 ------
3>Compilación iniciada a las 12/05/2014 12:54:13.
3>InitializeBuildStatus:
3> Se creará "CGAL_Core.dir\Debug\CGAL_Core.unsuccessfulbuild" porque se
3>CustomBuild:
3> Building Custom Rule C:/dev/CGAL-4.3/src/CGAL_Core/CMakeLists.txt
3> CMake does not need to re-run because
C:\dev\CGAL-4.3\build\src\CGAL_Core\CMakeFiles\generate.stamp is up-to-date.
5>------ Operación Generar iniciada: proyecto: CGAL_Qt4, configuración:
Debug Win32 ------
3>ClCompile:
3> all_files.cpp
5>Compilación iniciada a las 12/05/2014 12:54:15.
5>InitializeBuildStatus:
5> Se creará "CGAL_Qt4.dir\Debug\CGAL_Qt4.unsuccessfulbuild" porque se
4>Compilación iniciada a las 12/05/2014 12:54:15.
4>InitializeBuildStatus:
4> Se creará "CGAL_ImageIO.dir\Debug\CGAL_ImageIO.unsuccessfulbuild" porque
4>CustomBuild:
4> Building Custom Rule C:/dev/CGAL-4.3/src/CGAL_ImageIO/CMakeLists.txt
4> CMake does not need to re-run because
C:\dev\CGAL-4.3\build\src\CGAL_ImageIO\CMakeFiles\generate.stamp is
up-to-date.
4>ClCompile:
4> all_files.cpp
5>CustomBuild:
5> Building Custom Rule C:/dev/CGAL-4.3/src/CGAL_Qt4/CMakeLists.txt
5> CMake does not need to re-run because
C:\dev\CGAL-4.3\build\src\CGAL_Qt4\CMakeFiles\generate.stamp is up-to-date.
5> Generating __/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx
5> Generating __/__/include/CGAL/Qt/moc_DemosMainWindow.cxx
5> Generating __/__/include/CGAL/Qt/moc_GraphicsItem.cxx
5> Generating __/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx
5> Generating qrc_CGAL.cxx
5> Generating qrc_Input.cxx
5> Generating qrc_File.cxx
5> Generating qrc_Triangulation_2.cxx
5>ClCompile:
5> all_files.cpp
5> moc_GraphicsViewNavigation.cxx
5> moc_DemosMainWindow.cxx
5> moc_GraphicsItem.cxx
5> moc_GraphicsViewInput.cxx
5> qrc_CGAL.cxx
5> qrc_Input.cxx
5> qrc_File.cxx
5> qrc_Triangulation_2.cxx
5> Generando código...
4>Link:
4> Creando biblioteca
C:/dev/CGAL-4.3/build/lib/Debug/CGAL_ImageIO-vc100-mt-gd-4.3.lib y objeto
C:/dev/CGAL-4.3/build/lib/Debug/CGAL_ImageIO-vc100-mt-gd-4.3.exp
5>Link:
5> Creando biblioteca
C:/dev/CGAL-4.3/build/lib/Debug/CGAL_Qt4-vc100-mt-gd-4.3.lib y objeto
C:/dev/CGAL-4.3/build/lib/Debug/CGAL_Qt4-vc100-mt-gd-4.3.exp
4>LinkEmbedManifest:
4> CGAL_ImageIO.vcxproj ->
C:\dev\CGAL-4.3\build\bin\Debug\CGAL_ImageIO-vc100-mt-gd-4.3.dll
5>LinkEmbedManifest:
5> CGAL_Qt4.vcxproj ->
C:\dev\CGAL-4.3\build\bin\Debug\CGAL_Qt4-vc100-mt-gd-4.3.dll
5>PostBuildEvent:
5> 1 archivo(s) copiado(s).
5>FinalizeBuildStatus:
5> Se eliminará el archivo "CGAL_Qt4.dir\Debug\CGAL_Qt4.unsuccessfulbuild".
5> Aplicando tarea Touch a "CGAL_Qt4.dir\Debug\CGAL_Qt4.lastbuildstate".
5>
5>Compilación correcta.
5>
5>Tiempo transcurrido 00:00:23.51
3>Link:
3> Creando biblioteca
C:/dev/CGAL-4.3/build/lib/Debug/CGAL_Core-vc100-mt-gd-4.3.lib y objeto
C:/dev/CGAL-4.3/build/lib/Debug/CGAL_Core-vc100-mt-gd-4.3.exp
3>LinkEmbedManifest:
3> CGAL_Core.vcxproj ->
C:\dev\CGAL-4.3\build\bin\Debug\CGAL_Core-vc100-mt-gd-4.3.dll
3>PostBuildEvent:
3> 1 archivo(s) copiado(s).
3>FinalizeBuildStatus:
3> Se eliminará el archivo
"CGAL_Core.dir\Debug\CGAL_Core.unsuccessfulbuild".
3> Aplicando tarea Touch a "CGAL_Core.dir\Debug\CGAL_Core.lastbuildstate".
3>
3>Compilación correcta.
3>
3>Tiempo transcurrido 00:00:26.51
4>PostBuildEvent:
4> 1 archivo(s) copiado(s).
4>FinalizeBuildStatus:
4> Se eliminará el archivo
"CGAL_ImageIO.dir\Debug\CGAL_ImageIO.unsuccessfulbuild".
4> Aplicando tarea Touch a
"CGAL_ImageIO.dir\Debug\CGAL_ImageIO.lastbuildstate".
4>
4>Compilación correcta.
4>
4>Tiempo transcurrido 00:00:24.90
6>------ Operación Generar iniciada: proyecto: ALL_BUILD, configuración:
Debug Win32 ------
6>Compilación iniciada a las 12/05/2014 12:54:40.
6>InitializeBuildStatus:
6> Se creará "Win32\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" porque se
6>CustomBuild:
6> Building Custom Rule C:/dev/CGAL-4.3/CMakeLists.txt
6> CMake does not need to re-run because
C:\dev\CGAL-4.3\build\CMakeFiles\generate.stamp is up-to-date.
6> Build all projects
6>FinalizeBuildStatus:
6> Se eliminará el archivo
"Win32\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild".
6> Aplicando tarea Touch a
"Win32\Debug\ALL_BUILD\ALL_BUILD.lastbuildstate".
6>
6>Compilación correcta.
6>
6>Tiempo transcurrido 00:00:00.78
========== Generar: 6 correctos, 0 incorrectos, 0 actualizados, 0 omitidos
Sorry about it, but i have the program in spanish.
Finally appered "Correct Compilation"
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Instalation-CGAL-Windows-8-Visual-Studio-2010-tp4659281p4659283.html
- [cgal-discuss] Instalation CGAL Windows 8 Visual Studio 2010, Nikitita91, 05/12/2014
- Re: [cgal-discuss] Instalation CGAL Windows 8 Visual Studio 2010, Laurent Rineau (CGAL/GeometryFactory), 05/12/2014
- Re: [cgal-discuss] Instalation CGAL Windows 8 Visual Studio 2010, Nikitita91, 05/12/2014
