- To:
- Subject: Re: [cgal-discuss] Missing SurfaceMeshComplex_2InTriangulation_3 constructor
- Date: Wed, 14 May 2014 14:26:33 +0200
Le Wednesday 14 May 2014 11:50:07 Per Zetterlund a écrit :
> Thank you for clearing that up.
> So I have a Delaunay_triangulation_3 from which
> I'd like to extract a triangular mesh. I have a
> "FacetSelector" functor to indicate what facets
> to extract. My plan was to use the missing constructor
> and then use CGAL::output_surface_facets_to_polyhedron
> to get a polyhedron object representing my mesh.
> How should I do it instead? Build the complex manually
> by adding facets? Or can I plug in my functor into
> make_surface_mesh() somehow?
You can also implement the missing constructor! :-)
- construct the c2t3 object from the Delaunay_triangulation_3 reference,
- loop on all facets of the triangulation, and if the fonctor result is
positive, call:
add_to_complex (Facet f);
That would be something like:
C2t3 c3t3(tr);
for (Finite_facets_iterator fit = tr.finite_facets_begin();
fit != tr.finite_facets_end(); ++fit)
if(functor(*fit)) {
c2t3.add_to_complex(*fit);
Laurent Rineau, PhD
- [cgal-discuss] Missing SurfaceMeshComplex_2InTriangulation_3 constructor, Per Zetterlund, 05/14/2014
- Re: [cgal-discuss] Missing SurfaceMeshComplex_2InTriangulation_3 constructor, Laurent Rineau (CGAL/GeometryFactory), 05/14/2014
- Re: [cgal-discuss] Missing SurfaceMeshComplex_2InTriangulation_3 constructor, Per Zetterlund, 05/14/2014
- Re: [cgal-discuss] Missing SurfaceMeshComplex_2InTriangulation_3 constructor, Per Zetterlund, 05/15/2014
- Re: [cgal-discuss] Missing SurfaceMeshComplex_2InTriangulation_3 constructor, Per Zetterlund, 05/19/2014
