- To:
- Subject: Re: [cgal-discuss] Alpha Shape 2D: Input point index
- Date: Tue, 03 Jun 2014 08:11:07 +0200
Here is what I meant by "with simplex types suited for the Alpha-shape"
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Alpha_shape_vertex_base_2<K> Vbb;
typedef CGAL::Alpha_shape_face_base_2<K> Fb;
typedef CGAL::Triangulation_vertex_base_with_info_2<std::size_t, K, Vbb> Vb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K,Tds> Triangulation_2;
typedef CGAL::Alpha_shape_2<Triangulation_2> Alpha_shape_2;
Sebastien.
On 05/30/2014 07:44 PM, morrischen2008 wrote:
Thanks a lot Sebastien. Your advice works.
Following your advice [1], I successfully created the Delaunay
triangulation with "index inserted in the vertices".
However, I failed to use the established Delaunay triangulation to build
the alpha shape [3].
Here is how I did it.
typedef K::FT FT;
typedef CGAL::Triangulation_vertex_base_with_info_2<unsigned, K> Vb;
typedef CGAL::Triangulation_data_structure_2<Vb,> Tds;
typedef CGAL::Delaunay_triangulation_2<K, Tds> Delaunay_2;
typedef CGAL::Alpha_shape_2<Delaunay> Alpha_shape_2;
Delaunay_2 T;
T.insert(points.begin(), points.end()); // Compile and runs fine until now
Alpha_shape_2 A(T); // compiler gives lots of errors!!!
Previously when I just used a bunch of points to construct alpha shape
it works fine, like this:
typedef K::FT FT;
typedef CGAL::Alpha_shape_vertex_base_2<K> Vb;
Alpha_shape_2 A(input.begin(), input.end()); // Works fine
Any advice to get rid of the compiler errror? I will highly appreciate
it. Thanks.
On Thu, May 29, 2014 at 1:09 AM, Sebastien Loriot (GeometryFactory) [via
cgal-discuss] <[hidden email]
</user/SendEmail.jtp?type=node&node=4659367&i=0>> wrote:
You can try to build the triangulation (with simplex types suited for
the Alpha-shape of course) like in this example [1] or any
"insert_with_info*" example [2].
Then you can build the alpha shape from the triangulation [3].
Sebastien.
[1]
http://doc.cgal.org/latest/Triangulation_2/Triangulation_2_2info_insert_with_pair_iterator_2_8cpp-example.html
[2] http://doc.cgal.org/latest/Triangulation_2/examples.html
[3]
http://doc.cgal.org/latest/Alpha_shapes_2/classCGAL_1_1Alpha__shape__2.html#a9d026da2568aed80884a5053bae0039b
On 05/28/2014 09:24 PM, morrischen2008 wrote:
> Hi everyone,
> I am currently using Alpha Shape to construct the surface of a
bunch of
> points. The process is simple: the input is a bunch of points,
and I get a
> bunch of points as output. However, when I have indexes for the
input
> points, like this
> input
> index location
> 1 (1.0, 2.0)
> 2 (2.1, 2.3)
> 3 (2.3, 1.8)
> 731 (7.1, 9.3)
> I want to have to get, in the output points, also the indexes,
like this
> output
> index location
> 2 (2.1, 2.3)
> 333 (3.5, 7.8)
> However, I do not know how to obtain the indexes in outputs.
Anyone here can
> help me with this? I will appreciate your kind help. Below is how
I obtain
> the output points.
> First, use the constructor
> Alpha_shape_2 A(input.begin(), input.end(), FT(0.0001));
> , while "input" is a "list<Point_2>".
> The output I can obtain from "A" is a bunch of points, by using the
> iterators (I know I can also get a bunch of "Segment_2 as outputs
as well"),
> like this
> for(Alpha_shape_vertices_iterator it =
A.alpha_shape_vertices_begin();
> it != A.alpha_shape_vertices_end();
> ++it) {
> Vertex_handle vh = *it;
> Point_2 p(vh->point().x(), vh->point().y());
> output.push_back(p);
> , while "output" is a "vector<Point_2>".
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Alpha-Shape-2D-Input-point-index-tp4659360.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/Alpha-Shape-2D-Input-point-index-tp4659360p4659362.html
To unsubscribe from Alpha Shape 2D: Input point index, click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Morris
View this message in context: Re: Alpha Shape 2D: Input point index
<http://cgal-discuss.949826.n4.nabble.com/Alpha-Shape-2D-Input-point-index-tp4659360p4659367.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- Re: [cgal-discuss] Alpha Shape 2D: Input point index, Sebastien Loriot (GeometryFactory), 06/03/2014
