cgal-discuss - Re: [cgal-discuss] Possible error in skeleton
  • To:
  • Subject: Re: [cgal-discuss] Possible error in skeleton
  • Date: Tue, 03 Jun 2014 08:30:17 +0200
Looking here:
http://doc.cgal.org/latest/Straight_skeleton_2/index.html
I can read:
"This CGAL package requires the input polygon (with holes) to be non-degenerate, strictly-simple, and oriented counter-clockwise."
Sebastien.
On 05/16/2014 10:22 PM, Hyungon Kim wrote:
Hi,
I am using 3.6 CGAL 2D straight skeleton and polygon offsetting to glow 2D
polygon.
I found out that the order of points is critical to enter_contour function
even if the points represent the same polygon.
I means that the contour in some case is empty if I use the points following
reverse_orientation of polygon.
for (vit = boundary.vertices_begin(); vit != boundary.vertices_end();
vit++) {
points.push_back(*vit);
ssb.enter_contour(points.rbegin(),points.rend());
=> after offset, return the correct contour
boundary.reverse_orientation();
ssb.enter_contour(boundary.vertices_begin(),boundary.vertices_end());
=> after offset, return empty contour
I didn't find the statement to mention it from the manual or examples.
Is it an error in skeleton or an usage error?
Attached you will find the simple example code.
Thanks,
Hyungon Kim
exam_glow.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4659326/exam_glow.cpp>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Possible-error-in-skeleton-tp4659326.html
  • Re: [cgal-discuss] Possible error in skeleton, Sebastien Loriot (GeometryFactory), 06/03/2014
