cgal-discuss - Re: [cgal-discuss] Function to go from
  • To:
  • Subject: Re: [cgal-discuss] Function to go from
  • Date: Fri, 13 Jun 2014 19:45:30 +0200
Le Friday 13 June 2014 09:59:24 lednakashim a écrit :
> Hi Folks,
> I was wondering if somebody could kindly point me in the right direction.
> I want to generate a volume from an 3D image stack (`
> Mesh_3/mesh_3D_image.cpp
> <http://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_3D_image_8cpp-example.html>
> `), modify the mesh, and get back binary mask to extract the values inside
> my mesh. I want to use the mesh as a kind of `3D` threshold.
> How can I go from a mesh back to an 3D image stack?
Given a 3D point, the function c3t3.triangulation().locate(point) can locale
the triangulation cell that contains the point. Then, your can read the
domain
index of the cell with:
int domain_index = c3t3.subdomain_index(cell_handle);
You can reconstruct a new image using that trick on a regular 3D grid of
points.
Laurent Rineau, PhD
