- To:
- Subject: [cgal-discuss] Removing edges and facets from a 3d triangulation
- Date: Tue, 24 Jun 2014 08:18:08 -0700 (PDT)
Hi,
I am looking for a way to remove cells, facets and edges from a 3d
triangulation using CGAL. There are functions provided to remove vertices
but I would like to keep all of the vertices and do not want to
retriangulate them.
It is possible to add a boolean flag in the cell base class to indicate
whether it should be removed but because edges and facets are not explicitly
or uniquely represented i am having difficulty finding a way to remove them
from the triangulation.
Is there a way to remove facets and edges from the triangulation?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Removing-edges-and-facets-from-a-3d-triangulation-tp4659472.html
- [cgal-discuss] Removing edges and facets from a 3d triangulation, colonel_panic, 06/24/2014
- Re: [cgal-discuss] Removing edges and facets from a 3d triangulation, Olivier Devillers, 06/24/2014
- Re: [cgal-discuss] Removing edges and facets from a 3d triangulation, Thijs van Lankveld, 06/24/2014
- Re: [cgal-discuss] Removing edges and facets from a 3d triangulation, colonel_panic, 06/24/2014
