cgal-discuss - [cgal-discuss] Adding info to vertices in d-Dimensional Triangulation
  • To:
  • Subject: [cgal-discuss] Adding info to vertices in d-Dimensional Triangulation
  • Date: Thu, 26 Jun 2014 08:23:20 -0700 (PDT)
Hello,
I have tried without success to find a way to add additional info to my
vertices in a d-Dimensional triangulation.
There are more details described in this Stack Overflow question here:
http://stackoverflow.com/questions/24408805/cgal-how-to-use-global-indices-on-vertices-in-ddimensional-triangulation
In short, is there an easy way to add additional info to vertices in
d-Dimensions, just like in 2D and 3D?
This would be useful for keeping track of the global indices, but also for
some other stuff, like defining a function over the vertices of a
d-dimensional complex.
If not, then is there a way to at least get the global index of a vertex of
a Delaunay triangulation?
As far as I understood, only the local index is available (say, if you have
a 4-dim simplex, then the indices of its vertices would be 0, 1, 2, 3, 4, 5)
Thank you,
Stefan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Adding-info-to-vertices-in-d-Dimensional-Triangulation-tp4659480.html
  • [cgal-discuss] Adding info to vertices in d-Dimensional Triangulation, StefanB, 06/26/2014
