- To:
- Subject: [cgal-discuss] Triangulation -> mesh, strange result
- Date: Fri, 27 Jun 2014 15:53:16 +0200
Hi all,
I'm extracting triangles from a triangulation
to create a Polyhedron.
(EPIC kernel)
Triangulation tri;
//(Build triangulation)
typedef Surface_mesh_complex_2_in_triangulation_3<Triangulation> Smc2t3;
Smc2t3 smc2t3(tri);
for(auto fit = tri.all_facets_begin(); fit != tri.all_facets_end(); ++fit) {
if(shouldBeInMesh(fit)) {
smc2t3.add_to_complex(*fit);
Polyhedron polyhedron;
Complex_2_in_triangulation_3_polyhedron_builder<Smc2t3, Polyhedron>
builder(smc2t3);
polyhedron.delegate(builder);
When I run it on different data I often get these kinds of error:
CGAL::Polyhedron_incremental_builder_3<HDS>::
lookup_halfedge(): input error: facet 19061 shares a halfedge from
vertex 12328 to vertex 8026 with facet 19034.
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: check_protocoll == 1
File: /usr/include/CGAL/Polyhedron_incremental_builder_3.h
Line: 225
Aborted (core dumped)
And also, when it does succeed, if I run
Face.plane().orthogonal_vector() I sometimes
get very strange result, such as (0, 0, 0). I suspect this is related
to the other
problems. Am I doing something obvious wrong?
/Per
- [cgal-discuss] Triangulation -> mesh, strange result, Per Zetterlund, 06/27/2014
