Re: [cgal-discuss] Precondition violation in Bezier_x_monoton_2.h using Bezier arrangement
- To:
- Subject: Re: [cgal-discuss] Precondition violation in Bezier_x_monoton_2.h using Bezier arrangement
- Date: Mon, 30 Jun 2014 16:58:50 -0700 (PDT)
This is not a solution but a continuation of investigating this bug.
I've tested the two-curve input on CGAL 4.4 and it fails at a different
point from what you had described. For me, it is trying to perform the sweep
line algorithm (see the _sweep method in Basic_sweep_line_2_impl.h:154) and
dies before finishing. Here's a trace that I generated by compiling with
CGAL_SL_VERBOSE defined: http://pastebin.com/xt0UQWGd
Note that the first curve that gets inserted is split as you said, into
(2.15 1.475 --> ~2.175 ~1.45) and (~2.175 ~1.45 --> 2.175 1.45). So the
expected result of inserting the input curves is 3 monotone curves:
A (2.15 1.475 --> ~2.175 ~1.45)
C (~2.175 ~1.45 --> 2.175 1.45)
B (2.175 1.45 --> 2.15 1.425)
The trouble starts on line 121 of the trace, where when setting up the
events, it tries to intersect B with A and "successfully" finds an
intersection point. In fact, A and B should be disjoint by the x-monotone
decomposition above. So that causes strange behavior downstream.
I actually also had no luck switching the order of the two input curves.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Precondition-violation-in-Bezier-x-monoton-2-h-using-Bezier-arrangement-tp4659201p4659495.html
- Re: [cgal-discuss] Precondition violation in Bezier_x_monoton_2.h using Bezier arrangement, atsui, 07/01/2014
- Re: [cgal-discuss] Precondition violation in Bezier_x_monoton_2.h using Bezier arrangement, Alex Tsui, 07/02/2014
