Re: [cgal-discuss] Q: This demo requires the CGAL Qt4 library, and will not be compiled
- To:
- Subject: Re: [cgal-discuss] Q: This demo requires the CGAL Qt4 library, and will not be compiled
- Date: Tue, 01 Jul 2014 11:48:02 +0200
Le Monday 30 June 2014 23:29:01 shilu a écrit :
> Dear all:
> I'm a new to CGAL. I have configured the CGAL using CMAKE-GUI and
> compiled it with the vs 2010 strictly according to the windows installation
> instruction (http://www.cgal.org/windows_installation.html) and no question
> has emerged. I have got lib and bin as follows:
> however, when I use cmake-gui to config the
> 'Surface_reconstruction_points_3' demo, the CGAL QT4 can not be found which
> cause the it not be compiled.
If you configure a CGAL demo separately from the CGAL library, then during
that second configuration you need to fill again the CMake variable about Qt4
(not CGAL_Qt4 that is a different library). Is QTDIR set in your environment
variables?
Laurent Rineau, PhD
- [cgal-discuss] Q: This demo requires the CGAL Qt4 library, and will not be compiled, shilu, 07/01/2014
- Re: [cgal-discuss] Q: This demo requires the CGAL Qt4 library, and will not be compiled, Laurent Rineau (CGAL/GeometryFactory), 07/01/2014
