- To: cgal-discuss <>
- Subject: Re: [cgal-discuss] 2D Snap rounding
- Date: Wed, 2 Jul 2014 13:16:44 +0200
2014-07-02 11:11 GMT+02:00 Andreas Fabri
> Hi Benjamin,
> thank you for your bug report and even the analysis.
> We will add a floor function for the CGAL number types
> in order to avoid passing to floating point arithmetic.
Sounds good! Thanks!
> Can you work around the problem for the time being?
Yes, it is not beatiful, but it seems to work for now :)
> Note that even without the bug, segments may end up
> in the same pixel.
Yes, I'm aware of that. Thanks.
Regards
Benjamin
> Best,
> Andreas
> On 28/06/2014 20:23, Benjamin Kehlet wrote:
>> Hello!
>> This seems to be a bug in include/CGAL/Snap_rounding_traits_2.h:67-68
>> in Snap_2::operator(). The "pixel number" is computed as floor(x /
>> pixel_size). This floor operation is carried out in double precision,
>> which is not safe.
>> I tried to replace the call to std::floor with the simplest possible
>> implementation and it solves the problem for my case.
>> My very silly floor() implementation essentially just counts the
>> number of integers smaller than x). Here is the diff:
>> diff --git a/3rdparty/CGAL-4.4/include/CGAL/Snap_rounding_traits_2.h
>> b/3rdparty/CGAL-4.4/include/CGAL/Snap_rounding_traits_2.h
>> index 2c252e5..5538e0d 100644
>> --- a/3rdparty/CGAL-4.4/include/CGAL/Snap_rounding_traits_2.h
>> +++ b/3rdparty/CGAL-4.4/include/CGAL/Snap_rounding_traits_2.h
>> @@ -26,6 +26,36 @@
>> #include <CGAL/Arr_segment_traits_2.h>
>> +namespace
>> +template<typename NT>
>> +int floor_for_testing_only(NT x)
>> + const bool negative = x < 0;
>> + if (negative)
>> + x = -x;
>> + int f = 0;
>> + while (x >= 1)
>> + f++;
>> + x -= 1;
>> + if (negative)
>> + if (x != 0)
>> + f++;
>> + f = -f;
>> + return f;
>> namespace CGAL {
>> template<class Base_kernel>
>> @@ -64,10 +94,8 @@ public:
>> NT x_tmp = p.x() / pixel_size;
>> NT y_tmp = p.y() / pixel_size;
>> - double x_floor = std::floor(CGAL::to_double(x_tmp));
>> - double y_floor = std::floor(CGAL::to_double(y_tmp));
>> - x = NT(x_floor) * pixel_size + pixel_size / NT(2.0);
>> - y = NT(y_floor) * pixel_size + pixel_size / NT(2.0);
>> + x = floor_for_testing_only(x_tmp) * pixel_size + pixel_size /
>> NT(2.0);
>> + y = floor_for_testing_only(y_tmp) * pixel_size + pixel_size /
>> NT(2.0);
>> I don't know how this should be implemented in CGAL in a both
>> efficient and number type agnostic way. (The only way I could think of
>> was to use std::floor() with double precision and then check and
>> adjust the result afterwards, but that sounds suboptimal), but I do
>> hope that a fix will find its way into CGAL. Let me know if there is
>> anything I can do in this regard.
>> Best regards
>> Benjamin Kehlet
>> 2014-06-27 22:11 GMT+02:00 Benjamin Kehlet
>>> Hello again!
>>> Here is a simpler program that (if I understand the snap rounding
>>> package correctly) reveals a bug
>>> #include <CGAL/Cartesian.h>
>>> #include <CGAL/Quotient.h>
>>> #include <CGAL/MP_Float.h>
>>> #include <CGAL/Snap_rounding_traits_2.h>
>>> #include <CGAL/Snap_rounding_2.h>
>>> typedef CGAL::Quotient<CGAL::MP_Float> Number_type;
>>> typedef CGAL::Cartesian<Number_type> Kernel;
>>> typedef CGAL::Snap_rounding_traits_2<Kernel> Traits;
>>> typedef Kernel::Segment_2 Segment_2;
>>> typedef Kernel::Point_2 Point_2;
>>> int main(int argc, char** argv)
>>> Point_2 p1(1, 0);
>>> Point_2 p2(0, 0);
>>> Number_type pixel_width(0.1);
>>> CGAL::Hot_pixel<Traits> hp(p1, pixel_width);
>>> CGAL::Segment_data<Traits> sd(p1, p2);
>>> CGAL::SEG_Direction dir;
>>> sd.determine_direction(dir);
>>> if (!hp.intersect(sd, dir))
>>> std::cout << "Error! Segment did not intersect hot pixel of
>>> endpoint" << std::endl;
>>> This hits the bug, but only with a debug build. However, my guess is
>>> that this is not related to code that is removed when doing a release
>>> build. I think it is more likely that something in the creation of the
>>> hot pixel or in the intersection test is somehow prone to roundoff
>>> errors.
>>> I will try to investigate more. I would be nice if someone who know
>>> the package better than me could confirm that I'm not doing something
>>> completely wrong.
>>> Best regards
>>> Benjamin Kehlet
>>> 2014-06-27 1:58 GMT+02:00 Benjamin Kehlet
>>>> Hello!
>>>> I am attempting to use the 2D snap rounding package to safely get from
>>>> exact numbers to float in our mesh generation tool in FEniCS. However,
>>>> I get some (to me) unexpected results. Here is a simple example:
>>>> When running this simple modification of
>>>> examples/Snap_rounding_2/snap_rounding.cpp:
>>>> typedef std::list<Segment_2> Segment_list_2;
>>>> typedef std::list<Point_2> Polyline_2;
>>>> typedef std::list<Polyline_2> Polyline_list_2;
>>>> int main()
>>>> Segment_list_2 seg_list;
>>>> Polyline_list_2 output_list;
>>>> seg_list.push_back(Segment_2(Point_2(1, 0), Point_2(0, 0)));
>>>> // Generate an iterated snap-rounding representation, where the
>>>> centers of
>>>> // the hot pixels bear their original coordinates, using 5 kd trees:
>>>> CGAL::snap_rounding_2<Traits,Segment_list_2::const_iterator,Polyline_list_2>
>>>> (seg_list.begin(), seg_list.end(), output_list, .1, true, false,
>>>> 5);
>>>> int counter = 0;
>>>> Polyline_list_2::const_iterator iter1;
>>>> for (iter1 = output_list.begin(); iter1 != output_list.end();
>>>> ++iter1) {
>>>> std::cout << "Polyline number " << ++counter << ":\n";
>>>> Polyline_2::const_iterator iter2;
>>>> for (iter2 = iter1->begin(); iter2 != iter1->end(); ++iter2)
>>>> std::cout << " (" << iter2->x() << ":" << iter2->y() << ")\n";
>>>> return(0);
>>>> I get this result:
>>>> benjamik@benjamik-ThinkPad-X300:~/software/CGAL-4.4/examples/Snap_rounding_2/build$
>>>> ./snap_rounding
>>>> Polyline number 1:
>>>> (0.1/2:0.1/2)
>>>> So the one segment in the input seems to be "reduced" to a single
>>>> point. Is this expected? If the pixel size argument in the call to
>>>> CGAL::snap_rounding_2() is changed to "Number_type(1, 10)", then I get
>>>> the output that I would expect:
>>>> ./snap_rounding
>>>> Polyline number 1:
>>>> (210/200:10/200)
>>>> (10/200:10/200)
>>>> This may be due to my limited knowledge of the
>>>> Quotient<CGAL::MP_float> number type, but from the reference manual it
>>>> seems that it should be constructable from a double.
>>>> This occurs with a debug build of CGAL 4.4. I get the equal results on
>>>> a 32-bit Ubuntu 13.10 box with gcc 4.8.1 and with a 64-bit debian
>>>> Jessie box with gcc 4.9.0.
>>>> Best regards
>>>> Benjamin Kehlet
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912 skype: andreas.fabri
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- Re: [cgal-discuss] 2D Snap rounding, Andreas Fabri, 07/02/2014
- Re: [cgal-discuss] 2D Snap rounding, Benjamin Kehlet, 07/02/2014
