- To:
- Subject: Re: [cgal-discuss] Unexpected result when meshing polyhedron
- Date: Fri, 18 Jul 2014 12:00:27 +0200
Hi Benjamin,
the polyhedral domain class has a function
Polyhedral_mesh_domain::Construct_initial_points
that provides an intial set of points on the surface.
It currently does this by shooting rays in random
directions from the center of the bounding box.
When the surface has several connected components
and for a component no intial point is given
it may happen that the mesh generator later
never finds it (by also shooting rays, not random
though).
What you have to do is to initialize
the Complex_3_in_triangulation_3 with better
points by doing what
Mesh_3::init_c3_t3 do.
If I find the time next week, I will try to provide
an example.
best,
andreas
On 17/07/2014 01:40, Benjamin Kehlet wrote:
Hello CGAL people!
I got a report of some unexpected results in mshr (a mesh generation
component in the FEniCS project which uses CGAL heavily). I have
simplified it a bit and reproduced the issue as a standalone CGAL
program.
When meshing a box with a crude triangulation of a sphere subtracted,
the sphere is sometimes "missing" in the resulting mesh.
When meshing the polyhedron in smaller.off (which is basically an axis
aligned box with corners at (-1, -1, -.4) and (1,1,1) with a sphere
with center at origin and radius .3 subtracted) it works fine. See the
surface plot of the resulting mesh in smaller.png.
However, with bigger.off (where the first corner is at (-1,-1,-.7) and
the rest is equal) the inner sphere can not be seen in the plot. See
bigger.png.
I confirmed that it is not a plotting issue by calculating the volume
of the mesh. For bigger.off the result is 6.8 which is equal to the
volume of the box (2*2*1.7). For smaller.off it calculates the volume
to 5.5223. I assume is the correct solution since it is smaller than
5.6 which is the volume of the box (2*2*1.4=5.6). The program source
code is attached. The issue seems to be insensitive to the meshing
parameters.
Best regards
Benjamin Kehlet
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Unexpected result when meshing polyhedron, Benjamin Kehlet, 07/17/2014
- Re: [cgal-discuss] Unexpected result when meshing polyhedron, Andreas Fabri, 07/18/2014
- Re: [cgal-discuss] Unexpected result when meshing polyhedron, Benjamin Kehlet, 07/18/2014
- Re: [cgal-discuss] Unexpected result when meshing polyhedron, Laurent Rineau (CGAL/GeometryFactory), 07/18/2014
- Re: [cgal-discuss] Unexpected result when meshing polyhedron, Andreas Fabri, 07/22/2014
- Re: [cgal-discuss] Unexpected result when meshing polyhedron, Benjamin Kehlet, 07/23/2014
