- To:
- Subject: [cgal-discuss] A problem on sdf example
- Date: Sun, 20 Jul 2014 02:39:00 -0700 (PDT)
Hi!
When I tried to copy the code from
Surface_mesh_segmentation/sdf_values_example.cpp to my own program, a notice
"syntax error, identifier 'internal_map' "came out.And the error pointer was
at "boost::associative_property_map<Facet_double_map>
sdf_property_map(internal_map);"
Would anyone please tell me why, thank you!
Sean
Phd Student
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/A-problem-on-sdf-example-tp4659574.html
- [cgal-discuss] A problem on sdf example, sean, 07/20/2014
- Re: [cgal-discuss] A problem on sdf example, sean, 07/21/2014
- Re: [cgal-discuss] A problem on sdf example, Sebastien Loriot (GeometryFactory), 07/21/2014
