- To:
- Subject: [cgal-discuss] Mesher.refine_mesh() block execution without crashing.
- Date: Mon, 21 Jul 2014 08:20:40 -0700 (PDT)
Hello,
I'm refining a 2D Constrained Delaunay Triangulation with a
Delaunay_Mesher_2 mesher.
It works well, but sometimes blocks the execution of the whole program
without any apparent reason, and without crashing. I can't find any way to
get information about this issue.
The program is stuck between the first call to refine_mesh() and the second
call, after setting a Criteria.
Mesher mesher(_cdt);
mesher.refine_mesh();
mesher.set_criteria(Criteria(0.27, 0.5));
* // -> STUCK HERE*
My CDT is valid and contains only 14 vertices.
Could it be a thread-safety issue ?
Thank you.
BenoƮt
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesher-refine-mesh-block-execution-without-crashing-tp4659590.html
- [cgal-discuss] Mesher.refine_mesh() block execution without crashing., Benoit Lahoz, 07/21/2014
- Re: [cgal-discuss] Mesher.refine_mesh() block execution without crashing., Benoit Lahoz, 07/21/2014
