- To:
- Subject: Re: [cgal-discuss] Modify vertex values
- Date: Sat, 26 Jul 2014 07:39:22 -0700 (PDT)
It's the same rotation to each vertex, regardless of face.
On Jul 26, 2014 2:23 AM, "andreas.fabri [via cgal-discuss]" <[hidden email]> wrote:
Hello,
Is it the same rotation for all vertices?
Even then due to numerical issues collinear vertices
might become non-collinear.
Or do you apply different rotations to the
vertices?
Or do you even apply a different rotation for
a vertex, depending on the face you are in?
andreas
On 26/07/2014 01:58, chrism wrote:-->
> Yes that's my concern that it breaks something in a subtle way. I'll try
> this and see what happens though. Thanks!
> On Jul 25, 2014 5:14 PM, "Sylvain Pion-3 [via cgal-discuss]" <[hidden
> email] </user/SendEmail.jtp?type=node&node=4659616&i=0>> wrote:
> I believe it changes nothing else. But of course be careful, this
> violates Delaunay invariants, and if you use the Delaunay hierarchy,
> things can get funny.
> If you can find a different way to achieve what you want without
> resorting to such a hack, it would be better.
> 2014-07-25 16:01 GMT-07:00 chrism <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=4659615&i=0>>:
> And that will not change the triangulation? Not sure how I
> missed that, thanks.
> On Jul 25, 2014 4:52 PM, "Sylvain Pion-3 [via cgal-discuss]"
> <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=4659614&i=0>> wrote:
> Use set_point() to change the point of a vertex :
> http://doc.cgal.org/latest/Triangulation_2/classTriangulationVertexBase__2.html> Sent from the cgal-discuss mailing list archive at
> 2014-07-25 15:33 GMT-07:00 chrism <[hidden email]
> <http://user/SendEmail.jtp?type=node&node=4659613&i=0>>:
> I need to apply a rotation to each triangle in my
> Delauny (2D) triangulation.
> To do this, I calculate the rotation to move each
> triangle's vertex into the
> new coordinate system. Because I need to perform
> triangle-triangle
> intersection in this new coordinate system I need to
> update the x,y,z values
> at each vertex to the new x',y',z' values. Critically
> though, I need to
> maintain the triangles (despite the fact they will no
> longer be Delaunay) --
> therefore removal/insert doesn't work.
> Therefore, what would be the best way forward to modify
> the vertex's x,y,z
> values?
> Ideally I'd do something like:
> Delaunay prj(original_tri);
> for (triangulation::Finite_faces_iterator fit =
> prj->finite_faces_begin(); fit !=
> prj->finite_faces_end(); ++fit)
> //interpolate the station data to the current
> element
> triangulation::Face_handle face = fit;
> vert(0) = face->vertex(0)->point().x();
> ver(1) = face->vertex(0)->point().y();
> vert(2) = face->vertex(0)->point().z();
> rot_vert = rotation(vert);
> face->vertex(0)->set_x(rot_vert(0));
> face->vertex(1)->set_x(rot_vert(1));
> face->vertex(2)->set_x(rot_vert(2));
> Thanks.
> View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Modify-vertex-values-tp4659612.html>
> Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> If you reply to this email, your message will be added to
> the discussion below:
> http://cgal-discuss.949826.n4.nabble.com/Modify-vertex-values-tp4659612p4659613.html>
> To unsubscribe from Modify vertex values, click here.
> NAML
> <http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Modify vertex values
> <http://cgal-discuss.949826.n4.nabble.com/Modify-vertex-values-tp4659612p4659614.html>
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
> If you reply to this email, your message will be added to the
> discussion below:
> http://cgal-discuss.949826.n4.nabble.com/Modify-vertex-values-tp4659612p4659615.html
> NAML
> <http://cgal-discuss.949826.n4.nabble.com/Modify-vertex-values-tp4659612p4659616.html>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: <a href=""tel:%2B33.492.954.912"" value="+33492954912" target="_blank">+33.492.954.912 skype: andreas.fabri
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Modify-vertex-values-tp4659612p4659617.html
- [cgal-discuss] Modify vertex values, chrism, 07/26/2014
- Re: [cgal-discuss] Modify vertex values, Sylvain Pion, 07/26/2014
- Re: [cgal-discuss] Modify vertex values, chrism, 07/26/2014
- Re: [cgal-discuss] Modify vertex values, Andreas Fabri, 07/26/2014
