- To:
- Subject: Re: [cgal-discuss] Python binding of Poisson_reconstruction_function
- Date: Mon, 28 Jul 2014 08:11:20 -0700 (PDT)
Thanks for the reply Sebastien,
So I work on the binding and now it works fine, it pass all my tests and
finally paraview confirm the good reconstruction. I've also bind
Alpha_Shape_3 and like the Poisson process it works fine.
However, I bind these process for my work so especially for Alpha_Shape_3
it's far from the work done in the old project 'cgal-python'
(http://cgal-python.gforge.inria.fr/).
The aim of my work it to provide python module to do this:
python-list-of-Point_3 => | my module (poisson or alpha_shape_3)| =>
python-Polyhedron_3
So my work could interest some peoples but may be not the official
repository of cgal-binding, am I right?
I produced hight-level-functions, to be clear this is the little API
provided by my two bindings:
CGAL.CGAL_Alpha_shape_3 :
Alpha_shape_3_reconstruction(points, alpha_coef)
\points: list of Point_3
\alpha_coef: python float, coef in front of the optimal value of
alpha (.find_optimal_alpha(1))
pass to the .set_alpha() methode
\return a Polyhedron_3
CGAL.CGAL_Mesh_process_3
Computes_reconstruction_error(points, Polyhedron)
\points python-list of Point_3
\Polyhedron the re-construction polyhedron
\return a list of 3 python-floats
[avg_distance of the point set,
max distance points set <-> surface of the
polyhedron (in % of avg_spacing)
avg distance points set <-> surface of the
polyhedron (in % of avg_spacing)]
Poisson_reconstruction(points,
normals,
sm_angle,
sm_radius,
sm_distance,
solver_name)
\normals python-list returned by jet or pca_estimate_normals
\sm_angle python-float Min triangle angle in degrees
\sm_radius python-float triangle size w.r.t. pt set average spacing
\sm_distance python-float Surface Approximation error w.r.t. point
set average spacing
\solver_name "Eigen - built-in CG" or "Eigen - built-in simplicial
LDLt" for the compatibility of the
native solver in the machine, have to fixe this part...
Write_off_polyhedron(filename, Polyhedron)
\filename the name of the .off file produice (have to pass
"my_file.off", with the .off)
\return None
Could something like this interest the cgal-binding repos? or 'How' could
something like this, finally interest the cgal-binding repos (with some
changes) ?
Then, I have two questions linked to my work, I want to produce an even
easier API for my work, something like:
my_polyhedron = CGAL.CGAL_Mesh_process_3.Poisson_reconstruction(points,
normals, nb_facets)
where nb_facets would be the final numbers of facets of the reconstructions
polyhedron. But I find it hard to predict the good sm_angle, sm_radius and
sm_distance for an appropriate nb facets... Could you give me some idea for
the issue?
Then, the second question is: how can we produce low-nb-facets polyhedron
with Poisson reconstruction?
I find it hard to produce 10_facets-polyhedrons or 50_facets-polyhedrons
with that algorithm...Could you give me some idea for this problem?
Thank Sebastien
Regards
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Python-binding-of-Poisson-reconstruction-function-tp4659400p4659639.html
- Re: [cgal-discuss] Python binding of Poisson_reconstruction_function, hcherkaoui, 07/28/2014
- Re: [cgal-discuss] Python binding of Poisson_reconstruction_function, Sebastien Loriot (GeometryFactory), 07/29/2014
