- To:
- Subject: Re: [cgal-discuss] Remesh to Polyhedron
- Date: Wed, 30 Jul 2014 15:27:41 +0200
I've created a minimal test case, see attached file.
MyMeshTrait::Construct_initial_points::operator() gets called
with n = 20, and if I feed it with 20 points I get
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: aspect_ratio >= 0 && aspect_ratio <= 1
File: /usr/include/CGAL/Surface_mesher/Standard_criteria.h
Line: 161
Aborted (core dumped)
If I instead feed it with 4 points it seems to work,
and of I input the center point of *all* triangles, I get
Expr: is_finite(d)
File: /usr/include/CGAL/GMP/Gmpq_type.h
Line: 132
What is going on here? Please help me find what I'm doing wrong. I want
to input many initial points to cover all disjoint component in the mesh.
/Per
Here is the input file:
https://dl.dropboxusercontent.com/u/28611985/in.off.zip
On Tue, Jul 22, 2014 at 11:10 AM, Per Zetterlund
wrote:
> I've gotten a bit further with this.
> I'm using AABB Tree to speed up the intersects.
> However, my input mesh has several components and it
> is causing some trouble. The 3D Surface Mesh docs
> says that it handles disconnected components as long
> as there is an initial point on each component. This is
> not working for me; I get error messages such as
> Expr: is_finite(d)
> Line: 132
> But if I restrict the initial points to lay on one of the
> components I get a nice reconstruction of that component.
> Any ideas what I'm doing wrong?
> /Per
> On Wed, Jul 16, 2014 at 2:57 PM, Per Zetterlund
> wrote:
>> Hi All,
>> I have a triangular mesh that is ill formed (i.e. crosses
>> itself at vertices and edges) that I want to remesh to
>> a nice CGAL::Polyhedron.
>> Right now I've written my own SurfaceMeshTraits class
>> that I use with make_surface_mesh (3D Surface Mesh Generation
>> package). It's brute force in that for each line/ray/segment I check
>> intersection with every triangle in the mesh. So it is very slow...
>> Is there a better way?
>> I found the Surface_mesher/polyhedron_remesher.cpp example
>> but I can't find documentation for neither CGAL::Polyhedral_surface_3
>> nor CGAL::make_piecewise_smooth_surface_mesh so I'm guessing it's
>> outdated?
>> What is the difference between the "3D Surface Mesh Generation"
>> package and the "3D Mesh Generation" package? Which one is
>> most suitable for my needs?
>> Thanks,
>> Per
#include <fstream> #include <set> #include <stack> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/IO/output_surface_facets_to_polyhedron.h> #include <CGAL/IO/Polyhedron_iostream.h> #include <CGAL/make_surface_mesh.h> #include <CGAL/Surface_mesh_default_triangulation_3.h> #include <CGAL/AABB_tree.h> #include <CGAL/AABB_traits.h> #include <CGAL/AABB_triangle_primitive.h> typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel; typedef Kernel::Point_3 Point; typedef Kernel::Triangle_3 Triangle; typedef std::vector<Triangle>::iterator Iterator; typedef CGAL::AABB_triangle_primitive<Kernel,Iterator> Primitive; typedef CGAL::AABB_traits<Kernel, Primitive> AABB_triangle_traits; typedef CGAL::AABB_tree<AABB_triangle_traits> Tree; struct MyMeshTrait { typedef Point Intersection_point; struct Surface_3 { const std::vector<Triangle>& mTriangles; Tree mTree; Surface_3(std::vector<Triangle> triangles) : mTriangles(triangles), mTree(triangles.begin(),triangles.end()) {} }; struct Construct_initial_points { template <class OutputIteratorPoints> OutputIteratorPoints operator() (const Surface_3& surf, OutputIteratorPoints pts, int n = 0) { assert(surf.mTriangles.size() >= 20); for(int i = 0; i < n; ++i) { *pts = CGAL::centroid(surf.mTriangles[i]); ++pts; } return pts; } }; struct Intersect_3 { template <class T> CGAL::Object operator()(const Surface_3& surf, const T& s) const { auto res = surf.mTree.any_intersection(s); if(res) { return res->first; } else { return CGAL::Object(); } } }; Construct_initial_points construct_initial_points_object() const { return Construct_initial_points(); } Intersect_3 intersect_3_object() const { return Intersect_3(); } }; std::vector<Triangle> importOffVectorOfTriangles(const std::string& filename) { std::ifstream in(filename); std::vector<Triangle> triangles; bool color = false; std::string header; in >> header; if(header == "COFF") { color = true; } else { assert(header == "OFF"); } int num_verts; int num_triangles; int num_edges; in >> num_verts >> num_triangles >> num_edges; assert(num_edges == 0); std::vector<Point> verts(num_verts); for(int t = 0; t < num_verts; ++t) { float x,y,z; in >> x >> y >> z; verts[t] = Point(x,y,z); if(color) { int dummy; in >> dummy >> dummy >> dummy >> dummy; } } for(int t = 0; t < num_triangles; ++t) { std::vector<Point> tri(3); int num; in >> num; assert(num == 3); for(int i = 0; i < 3; ++i) { int idx; in >> idx; tri[i] = verts[idx]; } triangles.emplace_back(tri[0], tri[1], tri[2]); } return triangles; } static void generateMesh(const std::vector<Triangle>& triangles) { CGAL::Surface_mesh_default_triangulation_3 tr; CGAL::Complex_2_in_triangulation_3<CGAL::Surface_mesh_default_triangulation_3> c2t3(tr); MyMeshTrait::Surface_3 surface(triangles); MyMeshTrait traits; CGAL::Surface_mesh_default_criteria_3<CGAL::Surface_mesh_default_triangulation_3> criteria(30, 0.06, 0.06); CGAL::make_surface_mesh(c2t3, surface, traits, criteria, CGAL::Manifold_with_boundary_tag(),3); CGAL::Polyhedron_3<Kernel> polyhedron; CGAL::output_surface_facets_to_polyhedron(c2t3, polyhedron); polyhedron.inside_out(); std::ofstream out("out.off"); out << polyhedron; } int main(int argc, char** argv) { generateMesh(importOffVectorOfTriangles("in.off")); }
- [cgal-discuss] Remesh to Polyhedron, Per Zetterlund, 07/16/2014
- Re: [cgal-discuss] Remesh to Polyhedron, Per Zetterlund, 07/22/2014
- Re: [cgal-discuss] Remesh to Polyhedron, hcherkaoui, 07/22/2014
- Re: [cgal-discuss] Remesh to Polyhedron, Per Zetterlund, 07/30/2014
