cgal-discuss - Re: [cgal-discuss] Optimization in general k-nearest neighbor searching algorithm/implementation
  • To:
  • Subject: Re: [cgal-discuss] Optimization in general k-nearest neighbor searching algorithm/implementation
  • Date: Mon, 04 Aug 2014 07:48:37 +0200
Hi Jintack,
thanks a lot for your patches.
We'll have a look soon and post updates here.
Sebastien.
On 08/02/2014 12:26 AM, Jintack Lim wrote:
Dear all,
while I'm using k nearest neighbor library,
I found there is some room to optimize this library.
With this optimization, I saved up to 60% of execution time.
Source code is available below.
My basic observation is that
1) When calculating distance from a query point to a node, the same
iterators for a query is created over and over. Since query itself is
not changing, making only one iterator per query will do.
min_distance_to_rectangle function in
<CGAL-4.4/include/CGAL/Manhattan_distance_iso_box_point.h>
<CGAL-4.4/include/CGAL/Euclidean_distance.h>
2) Calculating distance from a query to each of sub rectangle is not
necessary. What is necessary is to pick a farther rectangle and
calculate that distance for a branch function.
To pick a farther rectangle, it is enough to check the query's
coordinate and rectangle's separator. (Just like a orthogonal kNN does)
compute_neighbors_general function in
<CGAL-4.4/include/CGAL/K_neighbor_search.h>
3) creating and deleting kd_tree_rectangle objects takes significant
time in a query processing. At each node, CGAL makes two sub rectangle
objects. However, by using a parent's rectangle object, we can save one
rectangle construction/destruction.
Here's the like to those files.
https://dl.dropboxusercontent.com/u/30008069/Euclidean_distance.h
https://dl.dropboxusercontent.com/u/30008069/K_neighbor_search.h
https://dl.dropboxusercontent.com/u/30008069/Manhattan_distance_iso_box_point.h
Best Regards,
Jintack
