- To:
- Subject: Re: [cgal-discuss] Is deprecated <boost/pending/integer_log2.hpp>?
- Date: Mon, 04 Aug 2014 17:44:47 +0200
Le Wednesday 30 July 2014 11:50:28 lednakashim a écrit :
> Hi wanted to bring to the lists attention that the stable version of CGAL
> doesn't compile with the latest version of boost (from git). The solution
> was to include the missing header file (`integer_log2.hpp`), whose content
> is trivial.
> integer_log2.hpp
> <http://cgal-discuss.949826.n4.nabble.com/file/n4659662/integer_log2.hpp>
I have installed Boost from Git, and the compatiblity file
boost/pending/integer_log2.hpp does exist. The issue you report was probably
either a temporary bug from Boost, or an incorrect local installation.
Laurent Rineau, PhD
- Re: [cgal-discuss] Is deprecated <boost/pending/integer_log2.hpp>?, lednakashim, 08/04/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] Is deprecated <boost/pending/integer_log2.hpp>?, Laurent Rineau (CGAL/GeometryFactory), 08/04/2014
