- To: <>
- Subject: Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata
- Date: Sun, 10 Aug 2014 15:24:52 +0100
Hello Sebastien,
yes, indeed - it is the tree.build() call that makes everything logical.
Honestly, I just should RTFM better - I thought that accelerate_distance_queries() call was responsible for this, which does no good for intersections anyway and just eats more memory for KD tree.
So, I reverted to the iterator which returns triangles by value constructing them on-the-fly and set the CGAL::Tag_true as the last template parameter for primitive.
The test results with are mixed (Isect shows the average over 100 all_intersections() calls, timed with QueryPerformanceCounter):
NO CACHE:
Build tree: 8.97505s
nConversions: 82950772
Isect: 2.97875ms
CGAL CACHE:
Build tree: 8.69819s
nConversions: 72620628
Isect: 1.97289ms
WITHIN-ITERATOR CACHE:
Build tree: 0.647395s
nConversions: 568938
Isect: 1.81151ms
Hope this helps,
Rostislav.
On 10/08/2014 14:39, Sebastien Loriot (GeometryFactory) wrote:
On 08/09/2014 05:59 PM, Rostislav Khlebnikov wrote:
Hello again,
I am just quite curious that the first call to the all_intersections is
very very slow compared to the rest. For example for mesh with about
500k triangles, the first call takes about 10 seconds, while the all the
following ones with the same cutting query take about 3 milliseconds,
giving the difference of 3000 times! Is there some lazy processing going
on that are triggered by the first call? Is this normal anyway?
Try to call tree.build() before, it is probably the construction of the
tree that is happening at the first call.
Sebastien.
Additionally, by adding the cached converted triangle as a member of
Triangles_const_iterator, setting the reference template parameter to
default and returning K::Triangle_3 const& from derefence() will speed
up the first 10 times (down to 1 second) and also speed up the
subsequent calls to about 2 milliseconds. It is clear why this happens,
but I just wanted to mention it.
Note that the last template parameter of AABB_triangle_primitive can be
used to cache the triangle in the primitive. Could you give it a try
and confirm it is as fast as your setting?
Thanks,
Sebastien.
So, if you could answer the questions in the first paragraph - that
would be absolutely great!
Thank you,
Rostislav.
On 08/08/2014 00:30, Rostislav Khlebnikov wrote:
Hello Sebastien,
yes, indeed changing the signature of the Triangles_const_iterator to
class Triangles_const_iterator
: public boost::iterator_facade<
, K::Triangle_3 const // Value
, boost::forward_traversal_tag // CategoryOrTraversal
, *K::Triangle_3*
helped resolving the issue. Just writing this to say thanks to you and
perhaps help anyone looking into similar problem.
Thanks again,
Rostislav.
PS: still weird that it worked in release :)
On 07/08/2014 23:33, Sebastien Loriot (GeometryFactory) wrote:
Thanks for the minimal reproducible example!
Actually, if you read again the doc of boost::iterator_facade
you'll see you're using the default for reference, which is
value&. In your case, reference should be value (Triangle is a
temporary).
Sebastien.
On 08/07/2014 11:14 PM, Rostislav Khlebnikov wrote:
Hi everyone,
I'm using AABB_tree to compute intersections of a VTK poly data with a
plane. When I just convert the triangles from VTK to CGAL and store
them
in std list, everything works fine. However, I would like to reduce
storage requirements by creating a triangle iterator that iterates over
the VTK triangle data.
Code in main.cpp here shows how I do it http://pastebin.com/kNLQevXV
<http://pastebin.com/sKPFHTT2>
In Release version everything works fine, but in Debug version -
intersections are never found! (Funnily enough it's a debug version
that
fails). I tried finding the problem - but I don't seem to understand
it.
What I found is that when CGAL uses the kernel to convert from
Triangle_3 to TriangleC3 with rep() and then uses this TriangleC3's
vertex() method on line 1909 in function_objects.h, the TriangleC3
'base' variable becomes corrupted during get(base) call at line 94 in
Triangle_3.h (i.e. correct coordinates are overwritten in what seems to
be stack initialization in function call when I looked at disassembly).
Is it something wrong that I do with my custom iterator? Or perhaps
it's
a bug in VS2013 compiler (I saw some bug reports regarding stack
corruption for VS2012 such as this
<http://stackoverflow.com/questions/11000798/structure-parameter-corrupted-on-function-call>,
so perhaps it's not completely resolved).
I attached all the code, input files and cmake file, so if someone who
has VTK and CGAL could quitckly test it on their platform. For me the
release version returns 54 intersections and debug - 0.
Thank you in advance,
Rostislav.
CGAL installation info:
Windows 8.1, MSVS 2013, x64
CGAL 4.4 installed with the CGAL-4.4-Setup.exe installer and then
built
with CMake and MSVS 2013.
- [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 08/07/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Sebastien Loriot (GeometryFactory), 08/08/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 08/08/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 08/09/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Sebastien Loriot (GeometryFactory), 08/10/2014
- Re: [cgal-discuss] AABB tree with custom iterator for VTK polydata, Rostislav Khlebnikov, 08/10/2014
