- To:
- Subject: Re: [cgal-discuss] Simple triangle intersection
- Date: Thu, 14 Aug 2014 10:31:59 +0200
On 08/13/2014 05:17 PM, Blaz Bratanic wrote:
I am trying to implement a simple triangle intersection test (below),
but i cant get it to work.
I get a bad_get error
terminate called after throwing an instance of
'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::bad_get>
what(): boost::bad_get: failed value get using boost::get
Aborted
when trying to extract Point from Intersection_and_primitive_id
(boost::get<Point>(i1.first)). I guess i must
be missing something.
The intersection might not always be a point.
Sebastien.
Thanks in advance for any help.
// Code snippet
#include <iostream>
#include <vector>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <CGAL/AABB_triangle_primitive.h>
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
typedef K::Ray_3 Ray;
typedef K::Line_3 Line;
typedef K::Point_3 Point;
typedef K::Triangle_3 Triangle;
typedef CGAL::Bbox_3 BoundingBox;
typedef std::vector<Triangle>::iterator Iterator;
typedef CGAL::AABB_triangle_primitive<K, Iterator> Primitive;
typedef CGAL::AABB_traits<K, Primitive> AABB_triangle_traits;
typedef CGAL::AABB_tree<AABB_triangle_traits> Tree;
typedef Tree::Intersection_and_primitive_id<Triangle>::Type
Triangle_intersection;
typedef Tree::Primitive_id Primitive_id;
std::vector<bool> visible_triangles(std::vector<Triangle>& triangles,
size_t nrays_per_axis) {
// constructs AABB tree
Tree tree(triangles.begin(), triangles.end());
BoundingBox bbox = tree.bbox();
std::vector<bool> visibility(triangles.size(), false);
double x = bbox.xmin();
double y = bbox.ymin();
double dx = (bbox.xmax() - bbox.xmin()) / nrays_per_axis;
double dy = (bbox.ymax() - bbox.ymin()) / nrays_per_axis;
std::vector<Triangle_intersection> intersections;
for (int iy = 0; iy < nrays_per_axis; iy++, y += dy) {
for (int ix = 0; ix < nrays_per_axis; ix++, x += dx) {
Point a = {x, y, 1};
Point b = {x, y, 0};
Ray ray_query(a, b);
if (tree.do_intersect(ray_query)) {
intersections.clear();
tree.all_intersections(ray_query,
std::back_inserter(intersections));
auto min_el =
std::min_element(intersections.begin(), intersections.end(),
[&a](Triangle_intersection const& i1,
Triangle_intersection const& i2) {
return squared_distance(a, boost::get<Point>(i1.first)) <
squared_distance(a, boost::get<Point>(i2.first));
visibility[std::distance(triangles.begin(), min_el->second)] =
true;
return visibility;
int main() {
Point a(0.5, 0.0, 0.0);
Point b(0.0, 0.5, 0.0);
Point c(0.0, 0.0, 0.5);
Point d(0.0, 0.0, 0.0);
std::vector<Triangle> triangles = {Triangle(a, b, c), Triangle(a, b, d),
Triangle(a, d, c)};
auto visibility = visible_triangles(triangles, 10);
return 0;
- [cgal-discuss] Simple triangle intersection, Blaz Bratanic, 08/13/2014
- Re: [cgal-discuss] Simple triangle intersection, Sebastien Loriot (GeometryFactory), 08/14/2014
