- To:
- Subject: Re: [cgal-discuss] Polyhedron flip_edge() crash
- Date: Thu, 21 Aug 2014 12:10:19 -0700 (PDT)
1.
WeiHua solved it. CGAL is missing a precondition that checks that the target
flipped edge doesn't already exist. For example, flipping one of a tet
edges. So the following check is needed:
bool does_flip_exist(Halfedge_handle he)
Vertex_handle v1 = he->next()->vertex();
Vertex_handle v2 = he->opposite()->next()->vertex();
Halfedge_around_vertex_circulator hc = v1->vertex_begin(), hc_end = hc;
CGAL_For_all(hc, hc_end) {
if ( hc->opposite()->vertex() == v2 )
return true;
return false;
2.
It would be useful to an option to check also the geometry after the flip
(for intersections), similar to the test in the simplification package.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polyhedron-flip-edge-crash-tp4659723p4659724.html
- [cgal-discuss] Polyhedron flip_edge() crash, Zohar, 08/21/2014
- Re: [cgal-discuss] Polyhedron flip_edge() crash, Zohar, 08/21/2014
