- To:
- Subject: Re: [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project
- Date: Mon, 25 Aug 2014 11:38:48 +0200
On 08/24/2014 11:00 PM, Brenuin wrote:
No it didn't work, I've tried all the models in the data folder, same result
I set default parameter, like
number of rays = 25,
cone angle = 120,
number of clusters = 5,
smoothness = 0,26
with extract segments checked
here is the screenshot when I've got Access violation reading location
<http://cgal-discuss.949826.n4.nabble.com/file/n4659732/error.png>
Could you try any example (http://doc.cgal.org/latest/Surface_mesh_segmentation/index.html#title9?) just to be sure it
has nothing to do with QT?
Thanks,
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Failed-to-run-mesh-segmentation-in-Polyhedron-demo-project-tp4659729p4659732.html
- [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project, Brenuin, 08/24/2014
- Re: [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project, Andreas Fabri, 08/24/2014
- Re: [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project, Brenuin, 08/24/2014
- Re: [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project, Sebastien Loriot (GeometryFactory), 08/25/2014
- Re: [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project, Brenuin, 08/25/2014
- Re: [cgal-discuss] Failed to run mesh segmentation in Polyhedron demo project, Brenuin, 08/26/2014
