- To:
- Subject: Re: [cgal-discuss] CGAL ERROR: precondition violation!
- Date: Mon, 25 Aug 2014 11:47:38 +0200
On 08/19/2014 02:23 PM, TableYoung wrote:
Hi Sebastien,
You are right,i put the data file in a wrong directory
.plus, i have a question is that i read the data from cube.off file which
is really a tiny file following is detail data in the file:
OFF8 6 0
-0.500000 -0.500000 0.500000
-0.500000 0.500000 0.500000
-0.500000 0.500000 -0.500000
-0.500000 -0.500000 -0.500000
4 0 1 3 2
4 2 3 5 4
4 4 5 7 6
4 6 7 1 0
4 1 7 5 3
4 6 0 2 4
but when i run program, the same error appeared().is that i got a
incorrect data struct in the .off file or some thing else.thank you again
for your help.
Best Regards
Tobe Yang.
Up to end-of-lines, the file seems correct.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-ERROR-precondition-violation-tp4659706p4659711.html
- [cgal-discuss] CGAL ERROR: precondition violation!, TableYoung, 08/18/2014
- Re: [cgal-discuss] CGAL ERROR: precondition violation!, Sebastien Loriot (GeometryFactory), 08/19/2014
- Re: [cgal-discuss] CGAL ERROR: precondition violation!, TableYoung, 08/19/2014
- Re: [cgal-discuss] CGAL ERROR: precondition violation!, Zohar, 08/22/2014
- Re: [cgal-discuss] CGAL ERROR: precondition violation!, Sebastien Loriot (GeometryFactory), 08/25/2014
