cgal-discuss - Re: [cgal-discuss] assert in refine_edges.h
  • To:
  • Subject: Re: [cgal-discuss] assert in refine_edges.h
  • Date: Wed, 27 Aug 2014 17:38:49 +0200
Hello,
I wrapped the snaprounding code in a header file.
The API is rather adhoc. You pass the sequence
of segments, and get a sequence of segments back,
snapped at the precision given by a fraction.
Note that not only points close to other segments
get changed, but even segment endpoints far from
anything. It should be doable to filter those out.
Best,
Andreas
On 27/08/2014 15:17, Andreas Fabri wrote:
Hello,
I just have a look at your data.
You have two slanted rectangles that have an almost overlapping edge.
Even if this works with an exact number type, it would make
no sense to run the Delaunay conforming algorithm with these
close segments, as the algorithm would produce many many triangles
between the close segments.
I am looking if the nap rounding package is the solution
for this problem. The idea is to snap segment endpoints
which are almost on another segment to the segment.
This also avoids the case that you have a segment that
intersects another segment, and gets split in two segments
with one of them having length almost zero.
Best,
Andreas
On 27/08/2014 15:09, HuyLe wrote:
I have isolated further the issue, my guess is that two constraints
(#56 and
69 in the attachment conforming.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4659749/conforming.cpp>
overlap each other, or are very close. In the example there are many
constraints that overlap which doesn't cause issue. Is there a way to
configure the algorithm to take care of such situation?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/assert-in-refine-edges-h-tp4659748p4659749.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_conformer_2.h>
#include <CGAL/snap_segments.h>
#include <iostream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_2 Point_2;
typedef K::Segment_2 Segment_2;
typedef CGAL::Constrained_Delaunay_triangulation_2<K> CDT;
typedef CDT::Vertex_handle Vertex_handle;
int main()
CDT cdt;
Point_2
v0(0.0000000000000000, 6.0000000000000000),
v1(0.0000000000000000, 0.0000000000000000),
v2(1.0000000000000000, 0.0000000000000000),
v3(1.0000000000000000, 6.0000000000000000),
v4(16.0000000000000000, 16.0000000000000000),
v5(11.0000000000000000, 16.0000000000000000),
v6(11.0000000000000000, 15.0000000000000000),
v7(14.0000000000000000, 15.0000000000000000),
v8(15.0000000000000000, 15.0000000000000000),
v9(15.0000000000000000, 5.0000000000000000),
v10(13.0000000000000000, 5.0000000000000000),
v11(9.0000000000000000, 5.0000000000000000),
v12(9.0000000000000000, 0.0000000000000000),
v13(16.0000000000000000, 0.0000000000000000),
v14(1.0000000000000000, 16.0000000000000000),
v15(1.0000000000000000, 14.0000000000000000),
v16(0.0000000000000000, 14.0000000000000000),
v17(0.0000000000000000, 13.0000000000000000),
v18(3.0000000000000000, 13.0000000000000000),
v19(6.0000000000000000, 13.0000000000000000),
v20(6.0000000000000000, 16.0000000000000000),
v21(7.0000000000000000, 8.0000000000000000),
v22(7.0000000000000000, 7.0000000000000000),
v23(4.0000000000000000, 7.0000000000000000),
v24(4.0000000000000000, 6.0000000000000000),
v25(8.0000000000000000, 6.0000000000000000),
v26(8.0000000000000000, 8.0000000000000000),
v27(14.0000000000000000, 6.0000000000000000),
v28(13.0000000000000000, 6.0000000000000000),
v29(7.0000000000000000, 15.0000000000000000),
v30(7.0000000000000000, 13.0000000000000000),
v31(8.0000000000000000, 13.0000000000000000),
v32(8.0000000000000000, 15.0000000000000000),
v33(8.0000000000000000, 5.0000000000000000),
v34(8.0000000000000000, 0.0000000000000000),
v35(0.0000000000000000, 12.0000000000000000),
v36(3.0000000000000000, 12.0000000000000000),
v37(2.0000000000000000, 0.0000000000000000),
v38(2.0000000000000000, 6.0000000000000000),
v39(0.0000000000000000, 16.0000000000000000),
v40(8.8541629266471915, 13.0245767861329420),
v41(8.3066572660502267, 12.9328699466773390),
v42(8.6502551399969541, 10.9449291613017810),
v43(9.1977608005939171, 11.0366360007573830),
v44(2.5417150003569482, 11.6628607681877820),
v45(0.3533522663593087, 11.0838445121955010),
v46(1.4481046175850272, 7.0741569900028498),
v47(3.6364673515826667, 7.6531732459951307),
v48(5.1624802263187526, 11.8863167127519760),
v49(2.9741174923211133, 11.3073004567596950),
v50(4.0688698435468318, 7.2976129345670433),
v51(6.2572325775444710, 7.8766291905593242),
v52(12.5267359689079070, 13.8900007338527500),
v53(8.8121230085508877, 13.2678054965947820),
v54(9.9822767510084347, 6.4976927392851493),
v55(13.6968897113654540, 7.1198879765431151),
v56(9.0000000000000000, 8.0000000000000000),
v57(9.0000000000000000, 6.0000000000000000),
v58(16.1600000000000000, 16.1600000000000000),
v59(-0.1600000000000000, 16.1600000000000000),
v60(-0.1600000000000000, -0.1600000000000000),
v61(16.1600000000000000, -0.1600000000000000);
std::list<Segment_2> segments, snapped;
segments.push_back(Segment_2(v60, v61));
segments.push_back(Segment_2(v59, v60));
segments.push_back(Segment_2(v61, v58));
segments.push_back(Segment_2(v58, v59));
segments.push_back(Segment_2(v57, v56));
segments.push_back(Segment_2(v54, v55));
segments.push_back(Segment_2(v53, v54));
segments.push_back(Segment_2(v55, v52));
segments.push_back(Segment_2(v52, v53));
segments.push_back(Segment_2(v50, v51));
segments.push_back(Segment_2(v49, v50));
segments.push_back(Segment_2(v51, v48));
segments.push_back(Segment_2(v48, v49));
segments.push_back(Segment_2(v46, v47));
segments.push_back(Segment_2(v45, v46));
segments.push_back(Segment_2(v47, v44));
segments.push_back(Segment_2(v44, v45));
segments.push_back(Segment_2(v42, v43));
segments.push_back(Segment_2(v41, v42));
segments.push_back(Segment_2(v43, v40));
segments.push_back(Segment_2(v40, v41));
segments.push_back(Segment_2(v38, v37));
segments.push_back(Segment_2(v35, v36));
segments.push_back(Segment_2(v37, v34));
segments.push_back(Segment_2(v34, v33));
segments.push_back(Segment_2(v32, v31));
segments.push_back(Segment_2(v30, v31));
segments.push_back(Segment_2(v32, v29));
segments.push_back(Segment_2(v29, v30));
segments.push_back(Segment_2(v57, v28));
segments.push_back(Segment_2(v28, v27));
segments.push_back(Segment_2(v26, v56));
segments.push_back(Segment_2(v26, v31));
segments.push_back(Segment_2(v33, v25));
segments.push_back(Segment_2(v26, v25));
segments.push_back(Segment_2(v25, v24));
segments.push_back(Segment_2(v23, v24));
segments.push_back(Segment_2(v22, v23));
segments.push_back(Segment_2(v21, v30));
segments.push_back(Segment_2(v26, v21));
segments.push_back(Segment_2(v21, v22));
segments.push_back(Segment_2(v19, v30));
segments.push_back(Segment_2(v19, v20));
segments.push_back(Segment_2(v36, v18));
segments.push_back(Segment_2(v18, v19));
segments.push_back(Segment_2(v17, v35));
segments.push_back(Segment_2(v17, v18));
segments.push_back(Segment_2(v39, v16));
segments.push_back(Segment_2(v16, v17));
segments.push_back(Segment_2(v15, v16));
segments.push_back(Segment_2(v14, v39));
segments.push_back(Segment_2(v20, v14));
segments.push_back(Segment_2(v14, v15));
segments.push_back(Segment_2(v34, v12));
segments.push_back(Segment_2(v12, v13));
segments.push_back(Segment_2(v11, v33));
segments.push_back(Segment_2(v12, v11));
segments.push_back(Segment_2(v10, v28));
segments.push_back(Segment_2(v10, v11));
segments.push_back(Segment_2(v9, v10));
segments.push_back(Segment_2(v8, v9));
segments.push_back(Segment_2(v27, v7));
segments.push_back(Segment_2(v7, v8));
segments.push_back(Segment_2(v6, v32));
segments.push_back(Segment_2(v6, v7));
segments.push_back(Segment_2(v5, v20));
segments.push_back(Segment_2(v5, v6));
segments.push_back(Segment_2(v13, v4));
segments.push_back(Segment_2(v4, v5));
segments.push_back(Segment_2(v38, v3));
segments.push_back(Segment_2(v2, v37));
segments.push_back(Segment_2(v2, v3));
segments.push_back(Segment_2(v1, v2));
segments.push_back(Segment_2(v35, v0));
segments.push_back(Segment_2(v3, v0));
segments.push_back(Segment_2(v0, v1));
snap_segments(segments.begin(), segments.end(),
std::back_inserter(snapped), 1, 10000);
std::cout.precision(17);
for (std::list<Segment_2>::iterator iter = snapped.begin(); iter !=
snapped.end(); ++iter) {
cdt.insert_constraint(iter->source(), iter->target());
std::cout << "Number of vertices before: "
<< cdt.number_of_vertices() << std::endl;
// make it conforming Delaunay
CGAL::make_conforming_Delaunay_2(cdt);
std::cout << "Number of vertices after make_conforming_Delaunay_2: "
// then make it conforming Gabriel
CGAL::make_conforming_Gabriel_2(cdt);
std::cout << "Number of vertices after make_conforming_Gabriel_2: "
#ifndef CGAL_SNAP_SEGMENTS_H
#define CGAL_SNAP_SEGMENTS_H
#include <CGAL/Cartesian.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Snap_rounding_traits_2.h>
#include <CGAL/Snap_rounding_2.h>
template <typename InputIterator, typename OutputIterator>
OutputIterator
snap_segments(InputIterator b, InputIterator e, OutputIterator out, int
pixel_num, int pixel_denum)
typedef CGAL::Gmpq Gmpq;
typedef CGAL::Cartesian<Gmpq> Kernel;
typedef CGAL::Snap_rounding_traits_2<Kernel> Traits;
typedef Kernel::Segment_2 Segment_2;
typedef Kernel::Point_2 Point_2;
typedef std::list<Segment_2> Segment_list_2;
typedef std::list<Point_2> Polyline_2;
typedef std::list<Polyline_2> Polyline_list_2;
Gmpq w(pixel_num,pixel_denum), w2(pixel_num,2*pixel_denum);
Segment_list_2 seg_list;
typedef typename std::iterator_traits<InputIterator>::value_type
InputSegment_2;
typedef typename CGAL::Kernel_traits<InputSegment_2>::Kernel::Point_2
InputPoint_2;
for(; b!= e; ++b){
seg_list.push_back(Segment_2(Point_2(Gmpq(b->source().x()-w2),
Gmpq(b->source().y()-w2)),
Point_2(Gmpq(b->target().x()-w2),
Gmpq(b->target().y()-w2))));
Polyline_list_2 output_list;
CGAL::snap_rounding_2<Traits,typename
Segment_list_2::const_iterator,Polyline_list_2>
(seg_list.begin(), seg_list.end(), output_list, w, true, false, 5);
typename Polyline_list_2::const_iterator iter1;
for (iter1 = output_list.begin(); iter1 != output_list.end(); ++iter1) {
typename Polyline_2::const_iterator iter2 = iter1->begin();
Point_2 p = *iter2;
InputPoint_2 ip(CGAL::to_double(p.x()+w2), CGAL::to_double(p.y()+w2));
++iter2;
for (; iter2 != iter1->end(); ++iter2){
Point_2 q = *iter2;
InputPoint_2 iq(CGAL::to_double(q.x()+w2), CGAL::to_double(q.y()+w2));
*out++ = InputSegment_2(ip,iq);
ip = iq;
return out;
#endif
