- To:
- Subject: Re: [cgal-discuss] CGAL Cmake issue with libQGLViewer
- Date: Fri, 05 Sep 2014 16:05:50 +0200
On 09/05/2014 03:55 PM, john24 wrote:
No that's the current setup which makes Cmake to compile the code without any
problems.
Then they are incorrect. _DEBUG should be
C:/dev/libGLViewer-2.5.3/debug/QGLViewer2d.lib and _RELEASE C:/dev/libGLViewer-2.5.3/release/QGLViewer2.lib (up to typos)
as documented here:
http://doc.cgal.org/latest/Manual/installation.html#title57
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Cmake-issue-with-libQGLViewer-tp4659785p4659794.html
- [cgal-discuss] CGAL Cmake issue with libQGLViewer, john24, 09/05/2014
- Re: [cgal-discuss] CGAL Cmake issue with libQGLViewer, Sebastien Loriot (GeometryFactory), 09/05/2014
- Re: [cgal-discuss] CGAL Cmake issue with libQGLViewer, john24, 09/05/2014
