cgal-discuss - Re: [cgal-discuss] assert in refine_edges.h
  • To:
  • Subject: Re: [cgal-discuss] assert in refine_edges.h
  • Date: Mon, 8 Sep 2014 14:14:10 -0700 (PDT)
Hi Andreas,
I have tried your solution, and it works great. The only issue is I'm
looking for a Triangulation Algorithm that will provide a constant output at
every run.
Unfortunately, It looks like there is some randomness in the output, I have
attached sample code and input data to help.
As first parameters it takes, the path of the input folder, and as second
parameter the path of the output folder.
In the attachment, I have put two runs, where we can see that the files
N45_E012_SPL09_U420_R017_Partial.log, don't have the same number of triangle
in the end.
In other case, the points added by the algorithm are not at the same
location or the triangles are arranged differently. log.zip
<http://cgal-discuss.949826.n4.nabble.com/file/n4659809/log.zip>
Regards,
Huy
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/assert-in-refine-edges-h-tp4659748p4659809.html
  • Re: [cgal-discuss] assert in refine_edges.h, HuyLe, 09/08/2014
