Re: [cgal-discuss] Face handles after inserting a point into a delaunay triangulation
- To:
- Subject: Re: [cgal-discuss] Face handles after inserting a point into a delaunay triangulation
- Date: Wed, 10 Sep 2014 07:16:39 +0200
The dimension is not specified in your question, however the principal is similar.
You can find all simplices in conflict using either get_conflits [1] in
2D or find_conflits in 3D [2]. That way you can remove the Face_handle
from the map.
After insertion, you simply need to consider all faces incident to the
point you just inserted.
Sebastien.
[1] http://doc.cgal.org/latest/Triangulation_2/classCGAL_1_1Delaunay__triangulation__2.html#abfc0e6082e03efa41154e2b6379a66f8
[2] http://doc.cgal.org/latest/Triangulation_3/classCGAL_1_1Delaunay__triangulation__3.html#a6f0000d1a9fca5dd96a3835e86177e1d
On 09/09/2014 05:26 PM, Maria wrote:
Hello,
I am trying to solve a time dependent PDE on a delaunay triangulation. For
that, I need to store values given on each /face/, e.g. with a
map<Face_handle, double>.
Now I want to insert a point in that delaunay triangulation which results in
a new bundle of faces that do not have a value in the map. New faces should
get a value such that the weighted sum of all values is preserved, old faces
should be deleted from the map. My questions are:
1. How do I find all the faces, that were created due to the insertion? How
do I know which face handles are not valid any more?
2. Is there a structure (something like a directed acyclic graph) that shows
the relation between the removed face(s) and the new ones? Could I extract
this information somehow out of the triangulation_hierarchy?
Thanks in advance!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Face-handles-after-inserting-a-point-into-a-delaunay-triangulation-tp4659811.html
- [cgal-discuss] Face handles after inserting a point into a delaunay triangulation, Maria, 09/09/2014
- Re: [cgal-discuss] Face handles after inserting a point into a delaunay triangulation, Sebastien Loriot (GeometryFactory), 09/10/2014
