cgal-discuss - Re: [cgal-discuss] Convex_hull_d wrong usage or bug?
  • To:
  • Subject: Re: [cgal-discuss] Convex_hull_d wrong usage or bug?
  • Date: Thu, 18 Sep 2014 22:36:07 +0200 (CEST)
On Thu, 18 Sep 2014, stfu wrote:
we have an application where we need to determine the vertices of a convex
hull in moderate dimensions (d<=50) and tried the Convex_hull_d code from
CGAL.
The following program unfortunately crashes with a segmentation fault, e.g.
when trying to insert 1000 points in 10 dimensions after insertion of about
40 points:
[snip]
By employing an exact kernel we should not experience robustness problems,
right?
Or is there a really stupid mistake in our above code?
BTW for small dimensions (e.g. d=3) it seems more stable and does not crash
as quickly. Tested on cgal 4.2 as included with Ubuntu 13.10 and 14.04 on an
intel x86 system (64-bit).
I hope we did not make a too obvious mistake here ...
I did not try your example, but past experience is that this code involves a recursion that becomes quite deep when the dimension is large. Could you try increasing significantly the size of the stack?
Marc Glisse
