- To:
- Subject: Re: [cgal-discuss] compiler problem using create_offset_polygons_2 (VS 2013)
- Date: Sun, 21 Sep 2014 07:20:16 -0700 (PDT)
Your solution work fine. Many thanks!
Another possibility that I've found after your suggestion is :
#pragma push_macro("NDEBUG")
#define NDEBUG
#include<CGAL/create_offset_polygons_2.h>
#include<CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include<CGAL/Polygon_2.h>
#pragma pop_macro("NDEBUG")
Thanks.
Jack
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/compiler-problem-using-create-offset-polygons-2-VS-2013-tp4659857p4659859.html
- [cgal-discuss] compiler problem using create_offset_polygons_2 (VS 2013), jack64, 09/21/2014
- Re: [cgal-discuss] compiler problem using create_offset_polygons_2 (VS 2013), Rostislav Khlebnikov, 09/21/2014
- Re: [cgal-discuss] compiler problem using create_offset_polygons_2 (VS 2013), jack64, 09/21/2014
