- To:
- Subject: Re: [cgal-discuss] How to execute the program ?
- Date: Tue, 23 Sep 2014 09:49:41 +0200
You need to install QT4
Sebastien.
On 09/23/2014 07:44 AM, ramesh wrote:
Hello Mr. Sebastien...
I have already followed the manual and I could configure and build
successfully.
When I see the output it says "Sorry, this demo needs QT..." as it supposed
to.
But how to get widget (resp. code is written in second main())?. I tried by
commenting the first main()
/* int main(int, char*){
std::cout << "Sorry, this demo needs QT..." << std::endl; return 0;}
#else */
then, I got the following errors
super@Jallu:~/cgal$ make
Scanning dependencies of target executable
[100%] Building CXX object CMakeFiles/executable.dir/test.cpp.o
In file included from /home/super/cgal/test.cpp:9:0:
/home/super/CGAL-4.4/include/CGAL/IO/Qt_widget.h:36:21: fatal error:
qwidget.h: No such file or directory
compilation terminated.
make[2]: *** [CMakeFiles/executable.dir/test.cpp.o] Error 1
make[1]: *** [CMakeFiles/executable.dir/all] Error 2
make: *** [all] Error 2
How to fix this and get widget on output?.
Thank you
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-execute-the-program-tp4659846p4659872.html
- [cgal-discuss] How to execute the program ?, ramesh, 09/16/2014
- Re: [cgal-discuss] How to execute the program ?, Zohar, 09/17/2014
- Re: [cgal-discuss] How to execute the program ?, Sebastien Loriot (GeometryFactory), 09/22/2014
- Re: [cgal-discuss] How to execute the program ?, ramesh, 09/23/2014
- Re: [cgal-discuss] How to execute the program ?, Sebastien Loriot (GeometryFactory), 09/23/2014
- Re: [cgal-discuss] How to execute the program ?, Laurent Rineau (CGAL/GeometryFactory), 09/23/2014
