Re: [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra
- To:
- Subject: Re: [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra
- Date: Mon, 29 Sep 2014 12:06:41 +0200
On 09/26/2014 05:55 PM, shebbycat wrote:
Thanks for the response, Sebastien.
Plane_3::has_on_positive_side(origin) seems like it will do the
trick. However when I use Exact_predicates_exact_constructions_kernel
seems I can no longer convert a Polyhedron/3 to a Nef/Polyhedron3. My
initial polyhedron is generated by Random_points_in_sphere_3 followed by
a Delaunay triangulation.
Did you also changed the Polyhedron Kernel?
Sebastien.
At a high level I start with a Polyhedron_3 random sphere, define a
clipping plane, clip, convert to Nefpolyhedron3, clip, then convert back
to a Polyhedron_3 for rendering in OpenGL. Could there be a better
way of approaching this process?
From: "Sebastien Loriot (GeometryFactory) [via cgal-discuss]" <[hidden
email] </user/SendEmail.jtp?type=node&node=4659901&i=0>>
Date: Monday, September 22, 2014 at 7:23 AM
To: Scott Shebby <[hidden email]
</user/SendEmail.jtp?type=node&node=4659901&i=1>>
Subject: Re: Iterative Applications of 3D Boolean Operations on Nef
Polyhedra
On 09/21/2014 03:12 AM, shebbycat wrote:
Hi everyone,Try CGAL::Exact_predicates_exact_constructions_kernel instead of K2.
I'm new to CGAL and quite grateful for its existence! I've built an
application that iteratively clips a 3D Nef Polyhedra with a plane, for a
specific application. For example, I define a clipping plane which
intersects a polyhedron (with its center at 0,0,0) and clip, rotate by some
degrees, clip again, and so on. When its done I convert it back to a 3D
polyhedron and render it in OpenGL.
My first question is that this process is really slow.. like taking a couple
seconds per clip. My kernel is:
typedef CGAL::Extended_cartesian< CGAL::Gmpq> K2;
Do you have a geometric properties for your set of clipping planes?
(like defining a convex volume)?
My second question is that sometimes after my clip process Ive inadvertently
clipped the origin side of the polyhedron instead of the "outer" side of the
intersection. Id like to always preserve the portion of the poly that
contains the origin. Ive tried grabbing the volume handle for the origin
point, but not sure how to use it properly.
try using Plane_3::has_on_positive_side(origin)
http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Plane__3.html#a2ca90cac980833ff38dd12dcb9858baf
Sebastien.
Is there anything I can do to speed the clipping up, and whats the best way
to check that my intersection will preserve the correct side of the poly?
Thanks!
View this message in
context:http://cgal-discuss.949826.n4.nabble.com/Iterative-Applications-of-3D-Boolean-Operations-on-Nef-Polyhedra-tp4659856.html
If you reply to this email, your message will be added to the discussion
below:
http://cgal-discuss.949826.n4.nabble.com/Iterative-Applications-of-3D-Boolean-Operations-on-Nef-Polyhedra-tp4659856p4659867.html
To unsubscribe from Iterative Applications of 3D Boolean Operations on
Nef Polyhedra, click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: Iterative Applications of 3D Boolean
<http://cgal-discuss.949826.n4.nabble.com/Iterative-Applications-of-3D-Boolean-Operations-on-Nef-Polyhedra-tp4659856p4659901.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra, shebbycat, 09/21/2014
- Re: [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra, Sebastien Loriot (GeometryFactory), 09/22/2014
- Re: [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra, shebbycat, 09/26/2014
- Re: [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra, Sebastien Loriot (GeometryFactory), 09/29/2014
- Re: [cgal-discuss] Iterative Applications of 3D Boolean Operations on Nef Polyhedra, shebbycat, 09/29/2014
