cgal-discuss - Re: [cgal-discuss] Mesh_3: Problem with isolated vertices
  • To:
  • Subject: Re: [cgal-discuss] Mesh_3: Problem with isolated vertices
  • Date: Tue, 14 Oct 2014 17:09:21 +0800 (GMT+08:00)
okay, i see. And I have figure out what the problem is. Thank you.
Best,
Monica
> -----原始邮件-----
> 发件人: "Andreas Fabri"
> 发送时间: 2014-10-14 17:05:54 (星期二)
> 收件人:
> 抄送:
> 主题: Re: [cgal-discuss] Mesh_3: Problem with isolated vertices
> Hello,
> it makes no sense to post no the CGAL list non-CGAL-related questions.
> or have you red James Joyce yet?
> Andreas
> On 14/10/2014 10:59, 杨宝容 wrote:
> > Hi, everyone. Is there any one who has ever used the OpenCSG library, i
> > have some problems like this compiling:
> > displaylistPrimitive.obj : error LNK2019: unresolved external symbol
> > "public: __thiscall OpenCSG::Primitive::Primitive(enum
> > OpenCSG::Operation,unsigned int)"
> > (??0Primitive@OpenCSG@@QAE@W4Operation@1@I@Z) referenced in function
> > "public: __thiscall
> > OpenCSG::DisplayListPrimitive::DisplayListPrimitive(unsigned int,enum
> > (??0DisplayListPrimitive@OpenCSG@@QAE@IW4Operation@1@I@Z)
> > "public: virtual __thiscall OpenCSG::Primitive::~Primitive(void)"
> > (??1Primitive@OpenCSG@@UAE@XZ) referenced in function "public: virtual
> > __thiscall OpenCSG::DisplayListPrimitive::~DisplayListPrimitive(void)"
> > (??1DisplayListPrimitive@OpenCSG@@UAE@XZ)
> > i have tried to change the project properties but it still doesn't work,
> > can you tell me why and how to fix it? thank you!
> > Monica
> > -----原始邮件-----
> > *发件人:* "Jane Tournois"
> > *发送时间:* 2014-10-14 15:55:33 (星期二)
> > *收件人:*
> > *抄送:*
> > *主题:* Re: [cgal-discuss] Mesh_3: Problem with isolated vertices
> > Hi Benjamin,
> > Le 13/10/2014 20:01, Benjamin Kehlet a écrit :
> >> Hi Jane
> >> 2014-10-13 17:25 GMT+02:00 Jane
> >> Tournois<>:
> >>> Hi Benjamin,
> >>> you are not doing anything wrong.
> >>> As you have noticed, the mesh itself is the C3T3
> >>> (Complex_3_in_triangulation_3).
> >>> The C3T3 is a subset of the triangulation.
> >>> So, there can be cells, and vertices, that belong to the
> >>> triangulation, but
> >>> not to the C3T3.
> >>> In your particular example, the criteria that you are using to
> >>> generate the
> >>> mesh are a bit too weak. One symptom of that is that the surface is
> >>> not very
> >>> well fitted by the mesh. You can see it if you output the mesh to
> >>> Medit for
> >>> example.
> >>> About isolated vertices, it's the same as for cells. It is not
> >>> forbidden to
> >>> have one or several vertices that belong to the triangulation but
> >>> not to the
> >>> triangulation.
> >>> It can be the case for example when a vertex is first inserted on
> >>> the
> >>> boundary (let's say during the initialization step), but then the
> >>> refinement
> >>> process changes the connectivity around it, and the vertex can
> >>> start not to
> >>> belong to the boundary anymore.
> >> Ah! I didn't know that could happen.
> >>> To make it short :
> >>> - it is not a bug
> >>> - the object that are interested in at the end/during the mesh
> >>> generation
> >>> process is the C3T3
> >> Thanks a lot for the explanation, Jane! That was very enlightening.
> >> So just to be sure: It is then my responsibility to grab only the
> >> relevant vertices from the triangulation, right? (Since the C3T3 does
> >> not provide an iterator over the vertices that belong to the
> >> complex.)
> > Yes, you are right.
> > You can iterate on cells, using the Cells_in_complex_iterator
> > (see
> > http://doc.cgal.org/latest/Mesh_3/classMeshComplex__3InTriangulation__3.html
> > and then collect the vertices.
> > The iterator on vertices that you can use on a C3T3 is
> > Vertices_in_complex_iterator
> > <http://doc.cgal.org/latest/Mesh_3/classMeshComplexWithFeatures__3InTriangulation__3.html#a000d7e82e052dc9231c30e781eff4004>
> > (see
> > but it iterates only on the corners of the object.
> > Regards,
> > Jane.
> >> Regards
> >> Benjamin
> >>> Best regards,
> >>> Jane.
> >>> Jane Tournois, PhD
> >>> R&D Engineer at GeometryFactory
> >>> http://www.geometryfactory.com/
> >>> Le 13/10/2014 10:41, Benjamin Kehlet a écrit :
> >>>> 2014-10-13 9:55 GMT+02:00 Clément
> >>>> Jamin<>:
> >>>>> Hi Benjamin,
> >>>>> Do you use the *parallel* mesh algorithm that is available in
> >>>>> CGAL 4.5
> >>>>> (with CGAL::Parallel_tag)?
> >>>> Hello Clément!
> >>>> No, this is in serial.
> >>>> Regards
> >>>> Benjamin
> >>>>> Best,
> >>>>> Clément.
> >>>>> On Mon, Oct 13, 2014 at 12:44 AM, Benjamin
> >>>>> Kehlet<>
> >>>>> wrote:
> >>>>>> Hello CGAL community!
> >>>>>> When meshing polyhedral domains, I sometimes experience isolated
> >>>>>> vertices, ie. vertices which does not belong to any cell. The
> >>>>>> attached
> >>>>>> file demonstrates the problem. Could someone take a look, and
> >>>>>> check if
> >>>>>> I'm doing anything wrong? The code for reading out the mesh is
> >>>>>> based
> >>>>>> on the code in CGAL for exporting to medit's file format.
> >>>>>> I get this result when attempting to mesh the file
> >>>>>> demo/Polyhedron/data/rotor.off from CGAL's source tree:
> >>>>>> benjamik@benjamik-ThinkPad:~/tmp/cgal-meshing/build$ ./main
> >>>>>> ~/software/CGAL-4.5/demo/Polyhedron/data/rotor.off
> >>>>>> Number of unconnected vertices:14
> >>>>>> 0.0693619 0.340288 -0.260398 0
> >>>>>> 0.148692 0.344385 -0.252795 0
> >>>>>> 0.11059 0.332426 -0.267569 0
> >>>>>> 0.0800736 0.308173 -0.290017 0
> >>>>>> 0.0358875 0.312982 -0.283919 0
> >>>>>> 0.0739249 0.2902 -0.306196 0
> >>>>>> 0.100469 0.304801 -0.293518 0
> >>>>>> 0.0949104 0.318775 -0.276573 0
> >>>>>> 0.0777684 0.350724 -0.248457 0
> >>>>>> 0.0909964 0.338994 -0.261008 0
> >>>>>> 0.0263695 0.298269 -0.299189 0
> >>>>>> 0.00269295 0.307881 -0.290388 0
> >>>>>> 0.0496229 0.300013 -0.297675 0
> >>>>>> -0.0248875 0.311644 -0.285615 0
> >>>>>> Also a few other files (at least cow.off and bones.off and maybe
> >>>>>> others) in the same directory reproduces the problem.
> >>>>>> Best regards
> >>>>>> Benjamin Kehlet
> >>>>>> You are currently subscribed to cgal-discuss.
> >>>>>> To unsubscribe or access the archives, go to
> >>>>>> https://sympa.inria.fr/sympa/info/cgal-discuss
> > Jane Tournois, PhD
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912 skype: andreas.fabri
