- To:
- Subject: Re: [cgal-discuss] Polylines to Polyhedron
- Date: Tue, 14 Oct 2014 23:01:31 +0200
Hi Omer,
There should be two new items.
The polyline is only where the two input objects intersect.
Rightclick on the other item and you will see
that you can generate the intersection, A-B, etc.
andreas
On 14/10/2014 22:56, Omer Ozturk wrote:
Hello everyone,
After using the corefinement plugin in polyhedron demo, the result appears
to be a scene_polyline_item. Is there a way to cast it to
scene_polyhedron_item? After that, I need to triangulate the remaining
surface.
Thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polylines-to-Polyhedron-tp4659959.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Polylines to Polyhedron, Omer Ozturk, 10/14/2014
- Re: [cgal-discuss] Polylines to Polyhedron, Andreas Fabri, 10/14/2014
- Re: [cgal-discuss] Polylines to Polyhedron, Omer Ozturk, 10/14/2014
