cgal-discuss - Re: [cgal-discuss] Collapse edge in Polyhedron_3
  • To: "cgal-discuss" <>
  • Subject: Re: [cgal-discuss] Collapse edge in Polyhedron_3
  • Date: Mon, 20 Oct 2014 20:48:21 +0800
According to my experience, the methods such as join_vertex do work, but as we know, on a polyhedron structure, edge collapsing operations have to conform to many constraints, so my suggestion is to map the polyhedron to a graph strcture ( u can use the boost library), then you can collapse the edges on that graph as you wish.
2014-10-20
Liyang
发件人: Per Zetterlund
发送时间: 2014-10-20  20:14:18
收件人: cgal-discuss
抄送:
主题: [cgal-discuss] Collapse edge in Polyhedron_3
Hi all,
What's the best way to implement edge
collapsing in a (triangular) Polyhedron_3?
A straight forward way would be to use
join_vertex. But that doesn't work as it
doesn't work for triangles.
What I'm doing now is to remove a couple
of edges using join_facet to get quads, and
then I use join_vertex to collapse the edge
and then put the edges back using split_facet
to get the original structure. Is there a better
way?
 /Per
You are currently subscribed to cgal-discuss.
To unsubscribe or access the archives, go to
