- To:
- Subject: Re: [cgal-discuss] Boost Kruskal Minimum Spanning Tree
- Date: Fri, 24 Oct 2014 11:25:15 +0200
Hi Jasmine,
A bug in the example, not in CGAL or the BGL.
When calling
boost::kruskal_minimum_spanning_tree(ft,
std::back_inserter(mst),
vertex_index_map(vertex_index_pmap));
the first argument must be ft, that is the filtered
graph where the infinite vertex is ignored (In the
example it was t instead of ft).
I fixed it in the code base for the next release.
Best,
Andreas
On 23/10/2014 07:23, jasmine2210 wrote:
Hello,
I'm trying to run CGAL with Boost Graph Library - Kruskal Minimum Spanning
Tree with my input. The code is exactly in this url:
https://doc.cgal.org/4.2/CGAL.CGAL.CGAL-and-the-Boost-Graph-Library/html/BGL_triangulation_2_2emst_8cpp-example.html
My input is
0. 0.
1. 1.
0. 2.
1. 0.
But when I run it, the output is not nice. This is the output of edges in
minimum spanning tree (EMST). Each line is an edge which is a pair of
points.
(0 6.95331e-310) - (0 0)
(1 1) - (1 0)
(1 1) - (0 2)
However, when I print the Delaunay Triangulation, the output is as expected.
(0 0) - (0 2)
(0 0) - (1 1)
(1 1) - (0 2)
(1 1) - (1 0)
(0 0) - (1 0)
I think it should be (0,0) in the first line in output of EMST. Moreover, I
don't think it's correct that the edge (0 0) - (0 0) is in the EMST. Could
you please let me know where is the root cause of my issue.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boost-Kruskal-Minimum-Spanning-Tree-tp4659990.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Boost Kruskal Minimum Spanning Tree, jasmine2210, 10/23/2014
- Re: [cgal-discuss] Boost Kruskal Minimum Spanning Tree, Andreas Fabri, 10/24/2014
- Re: [cgal-discuss] Boost Kruskal Minimum Spanning Tree, jasmine2210, 10/25/2014
