- To:
- Subject: Re: [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3
- Date: Mon, 27 Oct 2014 15:32:50 +0100
On 10/27/2014 03:13 PM, deeFisher wrote:
i've attached a link to the .off file and the polyhedron.isValid() results
log file. thanks!
https://www.dropbox.com/sh/hxv3ov07unk70hn/AAAwbvui9wJ5kTNTAqDcHreba?dl=0
This is not a geometrically valid polyhedron. Each edge is duplicated
in your input. Using the stitching plugin from the polyhedron demo,
I could produce a valid model and convert it to nef.
I sent you the result privately.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Can-t-convert-polyhedron-3-to-nef-polyehdron-3-tp4660003p4660020.html
- [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3, deeFisher, 10/24/2014
- Re: [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3, Sebastien Loriot (GeometryFactory), 10/27/2014
- Re: [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3, deeFisher, 10/27/2014
- Re: [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3, Sebastien Loriot (GeometryFactory), 10/28/2014
- Re: [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3, deeFisher, 10/28/2014
- Re: [cgal-discuss] Can't convert polyhedron_3 to nef_polyehdron_3, Sebastien Loriot (GeometryFactory), 10/29/2014
