- To: "" <>
- Subject: [cgal-discuss] R: Re: Memcheck
- Date: Mon, 27 Oct 2014 17:27:10 +0000
- Accept-language: it-IT, en-US
I ll try! Thanks! Where i should define that macro? In every header file?
Av
Inviato da Samsung Mobile
Chris Marsh <> ha scritto:
I cannot recall where on the mailing list I found this, but defining the following macro allows cgal to run under valgrind (but will perhaps hide the errors you're attempting to spot?)
#define CGAL_DISABLE_ROUNDING_MATH_CHECK
On Mon, Oct 27, 2014 at 10:56 AM, Villa Andrea (RSE)
<> wrote:
Hi, i m experiencing several problems using Cgal with new versions of ubuntu and the gnu compiler 4.6. These problems went undetected using 4.4 version and seems to be memory errors.Could you suggest a nemcheck software? Unfortunately valgrind doesn t works with cgal.Thanks.Andrea Villa.
RSE SpA ha adottato il Modello Organizzativo ai sensi del D.Lgs.231/2001, in forza del quale l'assunzione di obbligazioni da parte della Società avviene con firma di un procuratore, munito di idonei poteri. RSE adopts a Compliance Programme under the Italian Law (D.Lgs.231/2001). According to this RSE Compliance Programme, any commitment of RSE is taken by the signature of one Representative granted by a proper Power of Attorney.
Le informazioni contenute in questo messaggio di posta elettronica sono riservate e confidenziali e ne e' vietata la diffusione in qualsiasi modo o forma. Qualora Lei non fosse la persona destinataria del presente messaggio, La invitiamo a non diffonderlo e ad eliminarlo, dandone gentilmente comunicazione al mittente. The information included in this e-mail and any attachments are confidential and may also be privileged. If you are not the correct recipient, you are kindly requested to notify the sender immediately, to cancel it and not to disclose the contents to any other person.
- [cgal-discuss] Memcheck, Villa Andrea (RSE), 10/27/2014
- Re: [cgal-discuss] Memcheck, Chris Marsh, 10/27/2014
- [cgal-discuss] R: Re: Memcheck, Villa Andrea (RSE), 10/27/2014
- Re: [cgal-discuss] R: Re: Memcheck, Chris Marsh, 10/27/2014
