Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued)
- To:
- Subject: Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued)
- Date: Mon, 03 Nov 2014 17:12:55 +0100
Le Monday 03 November 2014 15:23:09 Quentin Merigot a écrit :
> Thank you for this bug report, it is now fixed in my repository. However, I
> must say that I am surprised that it did not work before this change: the
> numbers provided to the constructor of Polyhedron_incremental_builder_3 are
> in principle only used as estimations to reserve memory. What version of
> CGAL are you using ?
The constructor of CGAL::Polyhedron_incremental_builder has a second
parameter
that is a Boolean:
http://doc.cgal.org/latest/Polyhedron/classCGAL_1_1Polyhedron__incremental__builder__3.html#acb8216ef40323e777f57cd4656d98c83
When it is set to 'true', then that class template does extra checks, and
display diagnostics.
Ilya uses 'true' for the second parameter:
> typename CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
> B.begin_surface(_primal.size_of_facets(),
> _primal.size_of_vertices(),
> _primal.size_of_vertices());
That explains the reported behavior.
Laurent Rineau, PhD
- Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Quentin Merigot, 11/03/2014
- Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Laurent Rineau (CGAL/GeometryFactory), 11/03/2014
- Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Илья Палачев, 11/05/2014
- Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Quentin Merigot, 11/06/2014
- Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Илья Палачев, 11/06/2014
- Re: [cgal-discuss] Bug in halfspaces_intersection.h - or - How to efficiently compute intersection of half-planes (continued), Sebastien Loriot (GeometryFactory), 11/07/2014
