Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- To:
- Subject: Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface
- Date: Mon, 10 Nov 2014 18:03:28 -0800 (PST)
Hi Sebastien,
Thanks very much.
I think you are right. I will try to use the function you mentioned.
Best regards,
Min
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/an-issue-about-the-u-v-parameter-for-vertex-after-mesh-generation-for-surface-tp4660049p4660078.html
- [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/05/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/07/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, Sebastien Loriot (GeometryFactory), 11/07/2014
- Re: [cgal-discuss] an issue about the u/v parameter for vertex after mesh generation for surface, hmzhangmin, 11/11/2014
