- To:
- Subject: Re: [cgal-discuss] Segment tree and tetrahedron
- Date: Thu, 13 Nov 2014 10:54:50 +0100
I had the same thought, but this only makes sense if
you can run the test on many points at the same time
and if the tetrahedra are "small".
andreas
On 13/11/2014 10:49, Sebastien Loriot (GeometryFactory) wrote:
On 11/13/2014 10:45 AM, Per Zetterlund wrote:
Hi all,I would use the fast bbox-intersection-d package for that.
I have a list of (non-overlapping) tetrahedrons
that I want to query with a point to see
which (if any) tetrahedron that contains
the point.
Is it possible to use the Segment tree
structure for this? Can the 3D "segments"
be tetrahedrons?
/Per
http://doc.cgal.org/latest/Box_intersection_d/index.html
Sebastien.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Segment tree and tetrahedron, Per Zetterlund, 11/13/2014
- Re: [cgal-discuss] Segment tree and tetrahedron, Sebastien Loriot (GeometryFactory), 11/13/2014
- Re: [cgal-discuss] Segment tree and tetrahedron, Andreas Fabri, 11/13/2014
- Re: [cgal-discuss] Segment tree and tetrahedron, Per Zetterlund, 11/13/2014
