- To:
- Subject: Re: [cgal-discuss] Problem with building polyhedron
- Date: Thu, 20 Nov 2014 09:40:13 +0100
On 11/19/2014 04:43 PM, Omer Ozturk wrote:
B.begin_facet();Here you create one facet with all the vertices inside that facet.
for(int i=0;i<pts.length(); i++){
B.add_vertex_to_facet( i);
B.end_facet();
If you have triangles, you need to do begin_facet/end_facet for
each triangle.
Sebastien.
- [cgal-discuss] Problem with building polyhedron, Omer Ozturk, 11/19/2014
- <Possible follow-up(s)>
- Re: [cgal-discuss] Problem with building polyhedron, Sebastien Loriot (GeometryFactory), 11/20/2014
