- To:
- Subject: Re: [cgal-discuss] need help for installing cgal 4.5
- Date: Fri, 21 Nov 2014 08:27:18 -0800 (PST)
Laurent Rineau (CGAL/GeometryFactory) wrote
> Le Thursday 20 November 2014 09:56:47 Sebastien Loriot a écrit :
>> On 11/14/2014 03:13 PM, Alain Ralambo wrote:
>> > Hi
>> > I am new in cgal-discuss ! Apologize for my request if it's not the
>> > proper place !
> That is one of the proper places.
>> > I am installing the last cgal 4.5 on a windows vista pc
>> > I followed all the instructions of the installation guide (an htm file
>> > of the directory Manual of cgal 4.5). And at the present step, when I
>> > run cmake (cmake gui) to configure, I get the following message :
>> > CMake Error: The following variables are used in this project, but
>> > they are set to NOTFOUND.
>> > Please set them or make sure they are set and tested correctly in the
>> > CMake files:
>> > Boost_INCLUDE_DIR (ADVANCED)
>> > used as include directory in directory C:/dev/CGAL-4.5/src/CGAL
>> C:/dev/CGAL-4.5/src/CGAL_Core
>> > C:/dev/CGAL-4.5/src/CGAL_ImageIO
>> > used as include directory in directory C:/dev/CGAL-4.5/src/CGAL_Qt4
>> > I have boost 1_57_0 installed in dir C:\dev\boost 1_57_0
>> > the path environment variables are set to
>> > Boost_INCLUDE_DIR=C:\dev\boost_1_57_0
> The CMake script named FindBoost does not read the environment variable
> Boost_INCLUDE_DIR. However, it reads an environment variable named
> BOOST_INCLUDEDIR. Boost_INCLUDE_DIR is the name of the CMake cache
> variable.
> I suggest that you set, in the CMake cache, and not in the environment, a
> variable named Boost_DEBUG, of type BOOL, and value TRUE. That variable
> will
> triggered the display of extra messages from the script FindBoost. That
> will
> help you understand what happens. You can copy-paste the corresponding
> messages in this discussion thread, if you need further help.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
Sebastien Loriot might be right because I use Boost_1_57_0 with
lib32-msvc-10.0 that I installed with visual studio express 2010 which I
have deleted since.
*Changing the environment variable into BOOST_INCLUDEDIR changes nothing.
Here is the CMake cache generated*
# This is the CMakeCache file.
# For build in directory: c:/dev/CGAL-4.5/build
# It was generated by CMake:
C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUIs for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Build shared libraries
BUILD_SHARED_LIBS:BOOL=ON
//The directory containing a CMake configuration file for Boost.
Boost_DIR:PATH=Boost_DIR-NOTFOUND
//Path to a file.
Boost_INCLUDE_DIR:PATH=C:/dev/boost_1_57_0
//Boost system library (debug)
Boost_SYSTEM_LIBRARY_DEBUG:FILEPATH=Boost_SYSTEM_LIBRARY_DEBUG-NOTFOUND
//Boost system library (release)
Boost_SYSTEM_LIBRARY_RELEASE:FILEPATH=Boost_SYSTEM_LIBRARY_RELEASE-NOTFOUND
//Boost thread library (debug)
Boost_THREAD_LIBRARY_DEBUG:FILEPATH=Boost_THREAD_LIBRARY_DEBUG-NOTFOUND
//Boost thread library (release)
Boost_THREAD_LIBRARY_RELEASE:FILEPATH=Boost_THREAD_LIBRARY_RELEASE-NOTFOUND
//Select to allow to use all preconfigured external libraries
CGAL_ALLOW_ALL_PRECONFIGURED_LIBS_COMPONENT:BOOL=OFF
//Value Computed by CMake
CGAL_BINARY_DIR:STATIC=C:/dev/CGAL-4.5/build
//Link with static Boost libraries
CGAL_Boost_USE_STATIC_LIBS:BOOL=OFF
//User-defined flags
CGAL_CXX_FLAGS:STRING= -frounding-math
//The CGAL_Core library
CGAL_Core_LIBRARY:STRING=C:/dev/CGAL-4.5/build/bin//libCGAL_Core.dll
//Dependencies for the target
CGAL_Core_LIB_DEPENDS:STATIC=general;C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib;general;C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll;general;C:/dev/CGAL-4.5/build/bin//libCGAL.dll;
//Set this to TRUE if you want to define or modify any of CMAKE_*_FLAGS.
// When this is FALSE, all the CMAKE_*_FLAGS flags are overriden
// with the values used when building the CGAL libs. For CGAL_*_flags
// (used for ADDITIONAL flags) , there is no need to set this to
// TRUE.
CGAL_DONT_OVERRIDE_CMAKE_FLAGS:BOOL=TRUE
//Select to allow to preconfiguration of external libraries
CGAL_ENABLE_PRECONFIG:BOOL=ON
//The folder where CGAL user-side scripts will be installed, relative
// to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_BIN_DIR:STRING=bin
//The folder where CGAL CMake modules will be installed, relative
CGAL_INSTALL_CMAKE_DIR:STRING=lib/CGAL
//The folder where CGAL documentation and license files will be
// installed, relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_DOC_DIR:STRING=share/doc/CGAL-4.5
//The folder where CGAL header files will be installed, relative
CGAL_INSTALL_INC_DIR:STRING=include
//The folder where CGAL libraries will be installed, relative to
// CMAKE_INSTALL_PREFIX
CGAL_INSTALL_LIB_DIR:STRING=lib
//The folder where manual pages for CGAL scripts will be installed,
// relative to CMAKE_INSTALL_PREFIX
CGAL_INSTALL_MAN_DIR:STRING=share/man/man1
//The CGAL_ImageIO library
CGAL_ImageIO_LIBRARY:STRING=C:/dev/CGAL-4.5/build/bin//libCGAL_ImageIO.dll
CGAL_ImageIO_LIB_DEPENDS:STATIC=general;C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib;general;C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll;general;C:/dev/CGAL-4.5/build/bin//libCGAL.dll;general;glu32;general;opengl32;
//The CGAL library
CGAL_LIBRARY:STRING=C:/dev/CGAL-4.5/build/bin//libCGAL.dll
CGAL_LIB_DEPENDS:STATIC=general;C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib;general;C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll;
//The CGAL_Qt4 library
CGAL_Qt4_LIBRARY:STRING=C:/dev/CGAL-4.5/build/bin//libCGAL_Qt4.dll
CGAL_Qt4_LIB_DEPENDS:STATIC=general;C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib;general;C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll;general;C:/dev/CGAL-4.5/build/bin//libCGAL.dll;optimized;C:/Qt/4.8.6/lib/qtmain.lib;debug;C:/Qt/4.8.6/lib/qtmaind.lib;optimized;C:/Qt/4.8.6/lib/QtOpenGL4.lib;debug;C:/Qt/4.8.6/lib/QtOpenGLd4.lib;optimized;C:/Qt/4.8.6/lib/QtGui4.lib;debug;C:/Qt/4.8.6/lib/QtGuid4.lib;optimized;C:/Qt/4.8.6/lib/QtCore4.lib;debug;C:/Qt/4.8.6/lib/QtCored4.lib;general;glu32;general;opengl32;
CGAL_SOURCE_DIR:STATIC=C:/dev/CGAL-4.5
//Path to a program.
CMAKE_AR:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/ar.exe
//Build type: Release or Debug
CMAKE_BUILD_TYPE:STRING=Release
//The CodeBlocks executable
CMAKE_CODEBLOCKS_EXECUTABLE:FILEPATH=C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/bin/cmake.exe
//Enable/Disable color output during build.
CMAKE_COLOR_MAKEFILE:BOOL=ON
//CXX compiler.
CMAKE_CXX_COMPILER:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/g++.exe
CMAKE_CXX_FLAGS:STRING= -frounding-math
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=-g
//Flags used by the compiler during release builds for minimum
// size.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
//Flags used by the compiler during release builds.
CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
//Flags used by the compiler during release builds with debug info.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g -DNDEBUG
//Libraries linked by default with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING=-lkernel32 -luser32 -lgdi32 -lwinspool
-lshell32 -lole32 -loleaut32 -luuid -lcomdlg32 -ladvapi32
//C compiler.
CMAKE_C_COMPILER:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/gcc.exe
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING=
CMAKE_C_FLAGS_DEBUG:STRING=-g
// size.
CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g -DNDEBUG
//Libraries linked by default with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING=-lkernel32 -luser32 -lgdi32 -lwinspool
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING=' '
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//Convert GNU import libraries to MS format (requires Visual Studio)
CMAKE_GNUtoMS:BOOL=OFF
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=C:/Program Files/CGAL
CMAKE_LINKER:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/ld.exe
//make program
CMAKE_MAKE_PROGRAM:FILEPATH=C:/PROGRA~1/CODEBL~1/MinGW/bin/mingw32-make.exe
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING=' '
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_NM:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/nm.exe
CMAKE_OBJCOPY:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/objcopy.exe
CMAKE_OBJDUMP:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/objdump.exe
CMAKE_PROJECT_NAME:STATIC=CGAL
CMAKE_RANLIB:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/ranlib.exe
//RC compiler.
CMAKE_RC_COMPILER:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/windres.exe
//Flags for Windows Resource Compiler.
CMAKE_RC_FLAGS:STRING=' '
CMAKE_SH:FILEPATH=CMAKE_SH-NOTFOUND
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=' '
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//If set, runtime paths are not added when installing shared libraries,
// but are added when building.
CMAKE_SKIP_INSTALL_RPATH:BOOL=OFF
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
//Flags used by the linker during the creation of static libraries.
CMAKE_STATIC_LINKER_FLAGS:STRING=
CMAKE_STATIC_LINKER_FLAGS_DEBUG:STRING=
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELEASE:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_STRIP:FILEPATH=C:/Program Files/CodeBlocks/MinGW/bin/strip.exe
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
//The directory containing the GMP header files
GMP_INCLUDE_DIR:PATH=C:/dev/CGAL-4.5/auxiliary/gmp/include
//Path to the GMP library
GMP_LIBRARIES:FILEPATH=C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll
GMP_LIBRARIES_DIR:FILEPATH=C:/dev/CGAL-4.5/auxiliary/gmp/lib
//The directory containing the MPFR header files
MPFR_INCLUDE_DIR:PATH=C:/dev/CGAL-4.5/auxiliary/mpfr/include
//Path to the MPFR library
MPFR_LIBRARIES:FILEPATH=C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib
//OpenGL library for win32
OPENGL_gl_LIBRARY:STRING=opengl32
//GLU library for win32
OPENGL_glu_LIBRARY:STRING=glu32
//path to Qt3 include directory
QT3_INCLUDE_DIR:PATH=QT3_INCLUDE_DIR-NOTFOUND
QT3_MOC_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/moc.exe
//Path to a library.
QT3_QASSISTANTCLIENT_LIBRARY:FILEPATH=QT3_QASSISTANTCLIENT_LIBRARY-NOTFOUND
//This Library is only needed by and included with Qt3 on MSWindows.
// It should be NOTFOUND, undefined or IGNORE otherwise.
QT3_QTMAIN_LIBRARY:FILEPATH=QT3_QTMAIN_LIBRARY-NOTFOUND
QT3_QT_LIBRARY:FILEPATH=QT3_QT_LIBRARY-NOTFOUND
QT3_UIC_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/uic.exe
QT_ARTHURPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_ARTHURPLUGIN_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/arthurplugin.dll
QT_CONTAINEREXTENSION_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/designer/containerextensiond.dll
QT_CONTAINEREXTENSION_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/containerextension.dll
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/customwidgetplugin.dll
QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND
QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND
QT_DESIGNER_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/designer.exe
//The location of the Qt docs
QT_DOC_DIR:PATH=C:/Qt/4.8.6/doc
//The location of the Qt imports
QT_IMPORTS_DIR:PATH=C:/Qt/4.8.6/imports
QT_LINGUIST_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/linguist.exe
QT_LRELEASE_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/lrelease.exe
QT_LUPDATE_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/lupdate.exe
//The location of the Qt mkspecs containing qconfig.pri
QT_MKSPECS_DIR:PATH=C:/Qt/4.8.6/mkspecs
QT_MOC_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/moc.exe
QT_PHONONWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_PHONONWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_PHONONWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/phononwidgets.dll
QT_PHONON_DS9_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/phonon_backend/phonon_ds9d4.dll
QT_PHONON_DS9_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/phonon_backend/phonon_ds94.dll
//Path to a file.
QT_PHONON_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/phonon
//The Qt PHONON library
QT_PHONON_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/phonon4.lib;debug;C:/Qt/4.8.6/lib/phonond4.lib
QT_PHONON_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/phonond4.lib
QT_PHONON_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/phonon4.lib
//The location of the Qt plugins
QT_PLUGINS_DIR:PATH=C:/Qt/4.8.6/plugins
//Path to a file.
QT_QAXCONTAINER_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/ActiveQt
//The Qt QAXCONTAINER library
QT_QAXCONTAINER_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QAxContainer.lib;debug;C:/Qt/4.8.6/lib/QAxContainerd.lib
QT_QAXCONTAINER_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QAxContainerd.lib
QT_QAXCONTAINER_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QAxContainer.lib
//Path to a file.
QT_QAXSERVER_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/ActiveQt
//The Qt QAXSERVER library
QT_QAXSERVER_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QAxServer.lib;debug;C:/Qt/4.8.6/lib/QAxServerd.lib
QT_QAXSERVER_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QAxServerd.lib
QT_QAXSERVER_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QAxServer.lib
QT_QCNCODECS_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qcncodecsd4.dll
QT_QCNCODECS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qcncodecs4.dll
QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/qcollectiongenerator.exe
QT_QCOREWLANBEARER_PLUGIN_DEBUG:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QCOREWLANBEARER_PLUGIN_RELEASE:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_RELEASE-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG:FILEPATH=QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/qdeclarativeview.dll
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-NOTFOUND
QT_QGENERICBEARER_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/bearer/qgenericbearerd4.dll
QT_QGENERICBEARER_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/bearer/qgenericbearer4.dll
QT_QGIF_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qgifd4.dll
QT_QGIF_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qgif4.dll
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/graphicssystems/qglgraphicssystemd4.dll
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/graphicssystems/qglgraphicssystem4.dll
QT_QICO_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qicod4.dll
QT_QICO_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qico4.dll
QT_QIMSW_MULTI_PLUGIN_DEBUG:FILEPATH=QT_QIMSW_MULTI_PLUGIN_DEBUG-NOTFOUND
QT_QIMSW_MULTI_PLUGIN_RELEASE:FILEPATH=QT_QIMSW_MULTI_PLUGIN_RELEASE-NOTFOUND
QT_QJPCODECS_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qjpcodecsd4.dll
QT_QJPCODECS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qjpcodecs4.dll
QT_QJPEG_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qjpegd4.dll
QT_QJPEG_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qjpeg4.dll
QT_QKRCODECS_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qkrcodecsd4.dll
QT_QKRCODECS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qkrcodecs4.dll
//The qmake executable for the Qt installation to use
QT_QMAKE_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/qmake.exe
QT_QMNG_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qmngd4.dll
QT_QMNG_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qmng4.dll
QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/bearer/qnativewifibearerd4.dll
QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/bearer/qnativewifibearer4.dll
QT_QSQLDB2_PLUGIN_DEBUG:FILEPATH=QT_QSQLDB2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLDB2_PLUGIN_RELEASE:FILEPATH=QT_QSQLDB2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLIBASE_PLUGIN_DEBUG:FILEPATH=QT_QSQLIBASE_PLUGIN_DEBUG-NOTFOUND
QT_QSQLIBASE_PLUGIN_RELEASE:FILEPATH=QT_QSQLIBASE_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE2_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLITE2_PLUGIN_RELEASE:FILEPATH=QT_QSQLITE2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/sqldrivers/qsqlited4.dll
QT_QSQLITE_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/sqldrivers/qsqlite4.dll
QT_QSQLMYSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLMYSQL_PLUGIN_DEBUG-NOTFOUND
QT_QSQLMYSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLMYSQL_PLUGIN_RELEASE-NOTFOUND
QT_QSQLOCI_PLUGIN_DEBUG:FILEPATH=QT_QSQLOCI_PLUGIN_DEBUG-NOTFOUND
QT_QSQLOCI_PLUGIN_RELEASE:FILEPATH=QT_QSQLOCI_PLUGIN_RELEASE-NOTFOUND
QT_QSQLODBC_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/sqldrivers/qsqlodbcd4.dll
QT_QSQLODBC_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/sqldrivers/qsqlodbc4.dll
QT_QSQLPSQL_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/sqldrivers/qsqlpsqld4.dll
QT_QSQLPSQL_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/sqldrivers/qsqlpsql4.dll
QT_QSQLTDS_PLUGIN_DEBUG:FILEPATH=QT_QSQLTDS_PLUGIN_DEBUG-NOTFOUND
QT_QSQLTDS_PLUGIN_RELEASE:FILEPATH=QT_QSQLTDS_PLUGIN_RELEASE-NOTFOUND
QT_QSVGICON_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/iconengines/qsvgicond4.dll
QT_QSVGICON_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/iconengines/qsvgicon4.dll
QT_QSVG_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qsvgd4.dll
QT_QSVG_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qsvg4.dll
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/qt3supportwidgets.dll
//Path to a file.
QT_QT3SUPPORT_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/Qt3Support
//The Qt QT3SUPPORT library
QT_QT3SUPPORT_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/Qt3Support4.lib;debug;C:/Qt/4.8.6/lib/Qt3Supportd4.lib
QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/Qt3Supportd4.lib
QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/Qt3Support4.lib
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/accessible/qtaccessiblecompatwidgetsd4.dll
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/accessible/qtaccessiblecompatwidgets4.dll
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/accessible/qtaccessiblewidgetsd4.dll
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/accessible/qtaccessiblewidgets4.dll
//Path to a file.
QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANTCLIENT library
QT_QTASSISTANTCLIENT_LIBRARY:STRING=
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANT library
QT_QTASSISTANT_LIBRARY:STRING=
QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND
//The Qt QTCLUCENE library
QT_QTCLUCENE_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtCLucene4.lib;debug;C:/Qt/4.8.6/lib/QtCLucened4.lib
QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtCLucened4.lib
QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtCLucene4.lib
//Path to a file.
QT_QTCORE_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtCore
//The Qt QTCORE library
QT_QTCORE_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtCore4.lib;debug;C:/Qt/4.8.6/lib/QtCored4.lib
QT_QTCORE_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtCored4.lib
QT_QTCORE_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtCore4.lib
//Path to a file.
QT_QTDBUS_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtDBus
//The Qt QTDBUS library
QT_QTDBUS_LIBRARY:STRING=
QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND
QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTDECLARATIVE_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtDeclarative
//The Qt QTDECLARATIVE library
QT_QTDECLARATIVE_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtDeclarative4.lib;debug;C:/Qt/4.8.6/lib/QtDeclaratived4.lib
QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtDeclaratived4.lib
QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtDeclarative4.lib
//Path to a file.
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtDesigner
//The Qt QTDESIGNERCOMPONENTS library
QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtDesignerComponents4.lib;debug;C:/Qt/4.8.6/lib/QtDesignerComponentsd4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtDesignerComponentsd4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtDesignerComponents4.lib
//Path to a file.
QT_QTDESIGNER_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtDesigner
//The Qt QTDESIGNER library
QT_QTDESIGNER_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtDesigner4.lib;debug;C:/Qt/4.8.6/lib/QtDesignerd4.lib
QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtDesignerd4.lib
QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtDesigner4.lib
QT_QTGA_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qtgad4.dll
QT_QTGA_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qtga4.dll
//Path to a file.
QT_QTGUI_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtGui
//The Qt QTGUI library
QT_QTGUI_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtGui4.lib;debug;C:/Qt/4.8.6/lib/QtGuid4.lib
QT_QTGUI_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtGuid4.lib
QT_QTGUI_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtGui4.lib
//Path to a file.
QT_QTHELP_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtHelp
//The Qt QTHELP library
QT_QTHELP_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtHelp4.lib;debug;C:/Qt/4.8.6/lib/QtHelpd4.lib
QT_QTHELP_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtHelpd4.lib
QT_QTHELP_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtHelp4.lib
QT_QTIFF_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qtiffd4.dll
QT_QTIFF_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/imageformats/qtiff4.dll
//The Qt QTMAIN library
QT_QTMAIN_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/qtmain.lib;debug;C:/Qt/4.8.6/lib/qtmaind.lib
QT_QTMAIN_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/qtmaind.lib
QT_QTMAIN_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/qtmain.lib
//Path to a file.
QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtMultimedia
//The Qt QTMULTIMEDIA library
QT_QTMULTIMEDIA_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtMultimedia4.lib;debug;C:/Qt/4.8.6/lib/QtMultimediad4.lib
QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtMultimediad4.lib
QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtMultimedia4.lib
//Path to a file.
QT_QTNETWORK_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtNetwork
//The Qt QTNETWORK library
QT_QTNETWORK_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtNetwork4.lib;debug;C:/Qt/4.8.6/lib/QtNetworkd4.lib
QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtNetworkd4.lib
QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtNetwork4.lib
//Path to a file.
QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
//The Qt QTNSPLUGIN library
QT_QTNSPLUGIN_LIBRARY:STRING=
QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtOpenGL4.lib;debug;C:/Qt/4.8.6/lib/QtOpenGLd4.lib
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtOpenGLd4.lib
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtOpenGL4.lib
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/graphicssystems/qtracegraphicssystemd4.dll
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/graphicssystems/qtracegraphicssystem4.dll
QT_QTSCRIPTDBUS_PLUGIN_DEBUG:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_DEBUG-NOTFOUND
QT_QTSCRIPTDBUS_PLUGIN_RELEASE:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_RELEASE-NOTFOUND
//Path to a file.
QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtScriptTools
//The Qt QTSCRIPTTOOLS library
QT_QTSCRIPTTOOLS_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtScriptTools4.lib;debug;C:/Qt/4.8.6/lib/QtScriptToolsd4.lib
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtScriptToolsd4.lib
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtScriptTools4.lib
//Path to a file.
QT_QTSCRIPT_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtScript
//The Qt QTSCRIPT library
QT_QTSCRIPT_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtScript4.lib;debug;C:/Qt/4.8.6/lib/QtScriptd4.lib
QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtScriptd4.lib
QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtScript4.lib
//Path to a file.
QT_QTSQL_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtSql
//The Qt QTSQL library
QT_QTSQL_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtSql4.lib;debug;C:/Qt/4.8.6/lib/QtSqld4.lib
QT_QTSQL_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtSqld4.lib
QT_QTSQL_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtSql4.lib
//Path to a file.
QT_QTSVG_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtSvg
//The Qt QTSVG library
QT_QTSVG_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtSvg4.lib;debug;C:/Qt/4.8.6/lib/QtSvgd4.lib
QT_QTSVG_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtSvgd4.lib
QT_QTSVG_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtSvg4.lib
//Path to a file.
QT_QTTEST_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtTest
//The Qt QTTEST library
QT_QTTEST_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtTest4.lib;debug;C:/Qt/4.8.6/lib/QtTestd4.lib
QT_QTTEST_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtTestd4.lib
QT_QTTEST_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtTest4.lib
//Path to a file.
QT_QTUITOOLS_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtUiTools
//The Qt QTUITOOLS library
QT_QTUITOOLS_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtUiTools.lib;debug;C:/Qt/4.8.6/lib/QtUiToolsd.lib
QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtUiToolsd.lib
QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtUiTools.lib
QT_QTWCODECS_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qtwcodecsd4.dll
QT_QTWCODECS_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/codecs/qtwcodecs4.dll
//Path to a file.
QT_QTWEBKIT_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtWebKit
//The Qt QTWEBKIT library
QT_QTWEBKIT_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtWebKit4.lib;debug;C:/Qt/4.8.6/lib/QtWebKitd4.lib
QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtWebKitd4.lib
QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtWebKit4.lib
//Path to a file.
QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtXmlPatterns
//The Qt QTXMLPATTERNS library
QT_QTXMLPATTERNS_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtXmlPatterns4.lib;debug;C:/Qt/4.8.6/lib/QtXmlPatternsd4.lib
QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtXmlPatternsd4.lib
QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtXmlPatterns4.lib
//Path to a file.
QT_QTXML_INCLUDE_DIR:PATH=C:/Qt/4.8.6/include/QtXml
//The Qt QTXML library
QT_QTXML_LIBRARY:STRING=optimized;C:/Qt/4.8.6/lib/QtXml4.lib;debug;C:/Qt/4.8.6/lib/QtXmld4.lib
QT_QTXML_LIBRARY_DEBUG:FILEPATH=C:/Qt/4.8.6/lib/QtXmld4.lib
QT_QTXML_LIBRARY_RELEASE:FILEPATH=C:/Qt/4.8.6/lib/QtXml4.lib
QT_QWEBVIEW_PLUGIN_DEBUG:FILEPATH=QT_QWEBVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QWEBVIEW_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/qwebview.dll
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-NOTFOUND
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-NOTFOUND
QT_RCC_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/rcc.exe
QT_TASKMENUEXTENSION_PLUGIN_DEBUG:FILEPATH=C:/Qt/4.8.6/plugins/designer/taskmenuextensiond.dll
QT_TASKMENUEXTENSION_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/taskmenuextension.dll
//The location of the Qt translations
QT_TRANSLATIONS_DIR:PATH=C:/Qt/4.8.6/translations
QT_UIC3_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/uic3.exe
QT_UIC_EXECUTABLE:FILEPATH=C:/Qt/4.8.6/bin/uic.exe
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE:FILEPATH=C:/Qt/4.8.6/plugins/designer/worldtimeclockplugin.dll
//Select external library BLAS
WITH_BLAS:BOOL=OFF
//Enable CGAL component CGAL_Core
WITH_CGAL_Core:BOOL=ON
//Enable CGAL component CGAL_ImageIO
WITH_CGAL_ImageIO:BOOL=ON
//Enable CGAL component CGAL_Qt3
WITH_CGAL_Qt3:BOOL=ON
//Enable CGAL component CGAL_Qt4
WITH_CGAL_Qt4:BOOL=ON
//Select external library Coin3D
WITH_Coin3D:BOOL=OFF
//Select external library ESBTL
WITH_ESBTL:BOOL=OFF
//Select external library Eigen3
WITH_Eigen3:BOOL=OFF
//Select external library GMP
WITH_GMP:BOOL=ON
//Select external library IPE
WITH_IPE:BOOL=OFF
//Select external library LAPACK
WITH_LAPACK:BOOL=OFF
//Select external library LEDA
WITH_LEDA:BOOL=OFF
//Select external library MPFI
WITH_MPFI:BOOL=OFF
//Select external library MPFR
WITH_MPFR:BOOL=ON
//Select external library NTL
WITH_NTL:BOOL=OFF
//Select external library OpenGL
WITH_OpenGL:BOOL=OFF
//Select external library OpenNL
WITH_OpenNL:BOOL=OFF
//Select external library QGLViewer
WITH_QGLViewer:BOOL=OFF
//Select external library RS
WITH_RS:BOOL=OFF
//Select external library RS3
WITH_RS3:BOOL=OFF
//Select external library ZLIB
WITH_ZLIB:BOOL=OFF
//Select demos
WITH_demos:BOOL=OFF
//Select examples
WITH_examples:BOOL=OFF
//Path to a file.
ZLIB_INCLUDE_DIR:PATH=ZLIB_INCLUDE_DIR-NOTFOUND
ZLIB_LIBRARY:FILEPATH=ZLIB_LIBRARY-NOTFOUND
# INTERNAL cache entries
//ADVANCED property for variable: Boost_DIR
Boost_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_INCLUDE_DIR
Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_SYSTEM_LIBRARY_DEBUG
Boost_SYSTEM_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_SYSTEM_LIBRARY_RELEASE
Boost_SYSTEM_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_DEBUG
Boost_THREAD_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: Boost_THREAD_LIBRARY_RELEASE
Boost_THREAD_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
CGAL_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/dev/boost_1_57_0
CGAL_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_3RD_PARTY_PRECONFIGURED:INTERNAL=
//ADVANCED property for variable: CGAL_Boost_USE_STATIC_LIBS
CGAL_Boost_USE_STATIC_LIBS-ADVANCED:INTERNAL=1
CGAL_CFG_BOOST_VARIANT_SWAP_BUG:INTERNAL=1
//Result of TRY_COMPILE
CGAL_CFG_BOOST_VARIANT_SWAP_BUG_COMPILED:INTERNAL=FALSE
CGAL_CFG_DENORMALS_COMPILE_BUG:INTERNAL=0
CGAL_CFG_DENORMALS_COMPILE_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG:INTERNAL=0
CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_IEEE_754_BUG:INTERNAL=0
CGAL_CFG_IEEE_754_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_ISTREAM_INT_BUG:INTERNAL=0
CGAL_CFG_ISTREAM_INT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_5:INTERNAL=0
CGAL_CFG_MATCHING_BUG_5_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_6:INTERNAL=0
CGAL_CFG_MATCHING_BUG_6_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_7:INTERNAL=0
CGAL_CFG_MATCHING_BUG_7_COMPILED:INTERNAL=TRUE
CGAL_CFG_MATCHING_BUG_8:INTERNAL=0
CGAL_CFG_MATCHING_BUG_8_COMPILED:INTERNAL=TRUE
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG:INTERNAL=0
CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_LIMITS:INTERNAL=0
CGAL_CFG_NO_LIMITS_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_NEXTAFTER:INTERNAL=0
CGAL_CFG_NO_NEXTAFTER_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_STL:INTERNAL=0
CGAL_CFG_NO_STL_COMPILED:INTERNAL=TRUE
CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG:INTERNAL=0
CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_NUMERIC_LIMITS_BUG:INTERNAL=0
CGAL_CFG_NUMERIC_LIMITS_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG:INTERNAL=0
CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG:INTERNAL=0
CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG:INTERNAL=0
CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG_COMPILED:INTERNAL=TRUE
CGAL_CFG_USING_BASE_MEMBER_BUG_2:INTERNAL=0
CGAL_CFG_USING_BASE_MEMBER_BUG_2_COMPILED:INTERNAL=TRUE
CGAL_CONFIGURED_LIBRARIES:INTERNAL=CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt4
//Directory containing the Core package
CGAL_CORE_PACKAGE_DIR:INTERNAL=C:/dev/CGAL-4.5
CGAL_Core_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Core_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Core_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//ADVANCED property for variable: CGAL_Core_LIBRARY
CGAL_Core_LIBRARY-ADVANCED:INTERNAL=1
//Variable hidden from user
CGAL_Core_LIBRARY_INSTALLED:INTERNAL=C:/Program
Files/CGAL/lib/libCGAL_Core.dll
CGAL_ESSENTIAL_3RD_PARTY_LIBRARIES:INTERNAL=GMP;MPFR
CGAL_EXECUTABLE_TARGETS:INTERNAL=
CGAL_EXT_LIB_BLAS_PREFIX:INTERNAL=BLAS
CGAL_EXT_LIB_Coin3D_PREFIX:INTERNAL=COIN3D
CGAL_EXT_LIB_ESBTL_PREFIX:INTERNAL=ESBTL
CGAL_EXT_LIB_Eigen3_PREFIX:INTERNAL=EIGEN3
CGAL_EXT_LIB_GMP_PREFIX:INTERNAL=GMP
CGAL_EXT_LIB_IPE_PREFIX:INTERNAL=IPE
CGAL_EXT_LIB_LAPACK_PREFIX:INTERNAL=LAPACK
CGAL_EXT_LIB_LEDA_PREFIX:INTERNAL=LEDA
CGAL_EXT_LIB_MPFI_PREFIX:INTERNAL=MPFI
CGAL_EXT_LIB_MPFR_PREFIX:INTERNAL=MPFR
CGAL_EXT_LIB_NTL_PREFIX:INTERNAL=NTL
CGAL_EXT_LIB_OpenGL_PREFIX:INTERNAL=OpenGL
CGAL_EXT_LIB_OpenNL_PREFIX:INTERNAL=OpenNL
CGAL_EXT_LIB_QGLViewer_PREFIX:INTERNAL=QGLVIEWER
CGAL_EXT_LIB_RS3_PREFIX:INTERNAL=RS3
CGAL_EXT_LIB_RS_PREFIX:INTERNAL=RS
CGAL_EXT_LIB_ZLIB_PREFIX:INTERNAL=ZLIB
//Directory containing the Installation package
CGAL_INSTALLATION_PACKAGE_DIR:INTERNAL=C:/dev/CGAL-4.5
CGAL_ImageIO_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_ImageIO_3RD_PARTY_LIBRARIES:INTERNAL=glu32;opengl32
CGAL_ImageIO_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//ADVANCED property for variable: CGAL_ImageIO_LIBRARY
CGAL_ImageIO_LIBRARY-ADVANCED:INTERNAL=1
CGAL_ImageIO_LIBRARY_INSTALLED:INTERNAL=C:/Program
Files/CGAL/lib/libCGAL_ImageIO.dll
//ADVANCED property for variable: CGAL_LIBRARY
CGAL_LIBRARY-ADVANCED:INTERNAL=1
CGAL_LIBRARY_INSTALLED:INTERNAL=C:/Program Files/CGAL/lib/libCGAL.dll
//Directory containing the Maintenance package
CGAL_MAINTENANCE_PACKAGE_DIR:INTERNAL=C:/dev/CGAL-4.5
CGAL_Qt3_3RD_PARTY_DEFINITIONS:INTERNAL=
CGAL_Qt3_3RD_PARTY_INCLUDE_DIRS:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES:INTERNAL=
CGAL_Qt3_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
CGAL_Qt3_LIBRARY:INTERNAL=
CGAL_Qt3_LIBRARY_INSTALLED:INTERNAL=
CGAL_Qt4_3RD_PARTY_DEFINITIONS:INTERNAL=-DQT_DLL
CGAL_Qt4_3RD_PARTY_INCLUDE_DIRS:INTERNAL=C:/Qt/4.8.6/include
CGAL_Qt4_3RD_PARTY_LIBRARIES:INTERNAL=optimized;C:/Qt/4.8.6/lib/qtmain.lib;debug;C:/Qt/4.8.6/lib/qtmaind.lib;optimized;C:/Qt/4.8.6/lib/QtOpenGL4.lib;debug;C:/Qt/4.8.6/lib/QtOpenGLd4.lib;optimized;C:/Qt/4.8.6/lib/QtGui4.lib;debug;C:/Qt/4.8.6/lib/QtGuid4.lib;optimized;C:/Qt/4.8.6/lib/QtCore4.lib;debug;C:/Qt/4.8.6/lib/QtCored4.lib;glu32;opengl32
CGAL_Qt4_3RD_PARTY_LIBRARIES_DIRS:INTERNAL=
//ADVANCED property for variable: CGAL_Qt4_LIBRARY
CGAL_Qt4_LIBRARY-ADVANCED:INTERNAL=1
CGAL_Qt4_LIBRARY_INSTALLED:INTERNAL=C:/Program
Files/CGAL/lib/libCGAL_Qt4.dll
CGAL_SUPPORTING_3RD_PARTY_LIBRARIES:INTERNAL=GMP;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE
//ADVANCED property for variable: CMAKE_AR
CMAKE_AR-ADVANCED:INTERNAL=1
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=c:/dev/CGAL-4.5/build
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=3
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=0
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=2
//ADVANCED property for variable: CMAKE_COLOR_MAKEFILE
CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/bin/cmake.exe
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/bin/ctest.exe
//ADVANCED property for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//Executable file format
CMAKE_EXECUTABLE_FORMAT:INTERNAL=Unknown
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of external makefile project generator.
CMAKE_EXTRA_GENERATOR:INTERNAL=CodeBlocks
//CXX compiler system defined macros
CMAKE_EXTRA_GENERATOR_CXX_SYSTEM_DEFINED_MACROS:INTERNAL=__STDC__;1;__STDC_HOSTED__;1;__GNUC__;4;__GNUC_MINOR__;7;__GNUC_PATCHLEVEL__;1;__VERSION__;"4.7.1";__ATOMIC_RELAXED;
;__ATOMIC_SEQ_CST;5;__ATOMIC_ACQUIRE;2;__ATOMIC_RELEASE;3;__ATOMIC_ACQ_REL;4;__ATOMIC_CONSUME;1;__FINITE_MATH_ONLY__;
;__SIZEOF_INT__;4;__SIZEOF_LONG__;4;__SIZEOF_LONG_LONG__;8;__SIZEOF_SHORT__;2;__SIZEOF_FLOAT__;4;__SIZEOF_DOUBLE__;8;__SIZEOF_LONG_DOUBLE__;12;__SIZEOF_SIZE_T__;4;__CHAR_BIT__;8;__BIGGEST_ALIGNMENT__;16;__ORDER_LITTLE_ENDIAN__;1234;__ORDER_BIG_ENDIAN__;4321;__ORDER_PDP_ENDIAN__;3412;__BYTE_ORDER__;__ORDER_LITTLE_ENDIAN__;__FLOAT_WORD_ORDER__;__ORDER_LITTLE_ENDIAN__;__SIZEOF_POINTER__;4;__SIZE_TYPE__;unsigned
int;__PTRDIFF_TYPE__;int;__WCHAR_TYPE__;short unsigned
int;__WINT_TYPE__;short unsigned int;__INTMAX_TYPE__;long long
int;__UINTMAX_TYPE__;long long unsigned int;__CHAR16_TYPE__;short unsigned
int;__CHAR32_TYPE__;unsigned
int;__SIG_ATOMIC_TYPE__;int;__INT8_TYPE__;signed char;__INT16_TYPE__;short
int;__INT32_TYPE__;int;__INT64_TYPE__;long long int;__UINT8_TYPE__;unsigned
char;__UINT16_TYPE__;short unsigned int;__UINT32_TYPE__;unsigned
int;__UINT64_TYPE__;long long unsigned int;__INT_LEAST8_TYPE__;signed
char;__INT_LEAST16_TYPE__;short
int;__INT_LEAST32_TYPE__;int;__INT_LEAST64_TYPE__;long long
int;__UINT_LEAST8_TYPE__;unsigned char;__UINT_LEAST16_TYPE__;short unsigned
int;__UINT_LEAST32_TYPE__;unsigned int;__UINT_LEAST64_TYPE__;long long
unsigned int;__INT_FAST8_TYPE__;signed char;__INT_FAST16_TYPE__;short
int;__INT_FAST32_TYPE__;int;__INT_FAST64_TYPE__;long long
int;__UINT_FAST8_TYPE__;unsigned char;__UINT_FAST16_TYPE__;short unsigned
int;__UINT_FAST32_TYPE__;unsigned int;__UINT_FAST64_TYPE__;long long
unsigned int;__INTPTR_TYPE__;int;__UINTPTR_TYPE__;unsigned
int;__GXX_ABI_VERSION;1002;__USING_SJLJ_EXCEPTIONS__;1;__SCHAR_MAX__;127;__SHRT_MAX__;32767;__INT_MAX__;2147483647;__LONG_MAX__;2147483647L;__LONG_LONG_MAX__;9223372036854775807LL;__WCHAR_MAX__;65535;__WCHAR_MIN__;
;__WINT_MAX__;65535;__WINT_MIN__;
;__PTRDIFF_MAX__;2147483647;__SIZE_MAX__;4294967295U;__INTMAX_MAX__;9223372036854775807LL;__INTMAX_C(c);c
## LL;__UINTMAX_MAX__;18446744073709551615ULL;__UINTMAX_C(c);c ##
ULL;__SIG_ATOMIC_MAX__;2147483647;__SIG_ATOMIC_MIN__;(-__SIG_ATOMIC_MAX__ -
1);__INT8_MAX__;127;__INT16_MAX__;32767;__INT32_MAX__;2147483647;__INT64_MAX__;9223372036854775807LL;__UINT8_MAX__;255;__UINT16_MAX__;65535;__UINT32_MAX__;4294967295U;__UINT64_MAX__;18446744073709551615ULL;__INT_LEAST8_MAX__;127;__INT8_C(c);c;__INT_LEAST16_MAX__;32767;__INT16_C(c);c;__INT_LEAST32_MAX__;2147483647;__INT32_C(c);c;__INT_LEAST64_MAX__;9223372036854775807LL;__INT64_C(c);c
LL;__UINT_LEAST8_MAX__;255;__UINT8_C(c);c;__UINT_LEAST16_MAX__;65535;__UINT16_C(c);c;__UINT_LEAST32_MAX__;4294967295U;__UINT32_C(c);c
## U;__UINT_LEAST64_MAX__;18446744073709551615ULL;__UINT64_C(c);c ##
ULL;__INT_FAST8_MAX__;127;__INT_FAST16_MAX__;32767;__INT_FAST32_MAX__;2147483647;__INT_FAST64_MAX__;9223372036854775807LL;__UINT_FAST8_MAX__;255;__UINT_FAST16_MAX__;65535;__UINT_FAST32_MAX__;4294967295U;__UINT_FAST64_MAX__;18446744073709551615ULL;__INTPTR_MAX__;2147483647;__UINTPTR_MAX__;4294967295U;__FLT_EVAL_METHOD__;2;__DEC_EVAL_METHOD__;2;__FLT_RADIX__;2;__FLT_MANT_DIG__;24;__FLT_DIG__;6;__FLT_MIN_EXP__;(-125);__FLT_MIN_10_EXP__;(-37);__FLT_MAX_EXP__;128;__FLT_MAX_10_EXP__;38;__FLT_DECIMAL_DIG__;9;__FLT_MAX__;3.40282346638528859812e+38F;__FLT_MIN__;1.17549435082228750797e-38F;__FLT_EPSILON__;1.19209289550781250000e-7F;__FLT_DENORM_MIN__;1.40129846432481707092e-45F;__FLT_HAS_DENORM__;1;__FLT_HAS_INFINITY__;1;__FLT_HAS_QUIET_NAN__;1;__DBL_MANT_DIG__;53;__DBL_DIG__;15;__DBL_MIN_EXP__;(-1021);__DBL_MIN_10_EXP__;(-307);__DBL_MAX_EXP__;1024;__DBL_MAX_10_EXP__;308;__DBL_DECIMAL_DIG__;17;__DBL_MAX__;((double)1.79769313486231570815e+308L);__DBL_MIN__;((double)2.22507385850720138309e-308L);__DBL_EPSILON__;((double)2.22044604925031308085e-16L);__DBL_DENORM_MIN__;((double)4.94065645841246544177e-324L);__DBL_HAS_DENORM__;1;__DBL_HAS_INFINITY__;1;__DBL_HAS_QUIET_NAN__;1;__LDBL_MANT_DIG__;64;__LDBL_DIG__;18;__LDBL_MIN_EXP__;(-16381);__LDBL_MIN_10_EXP__;(-4931);__LDBL_MAX_EXP__;16384;__LDBL_MAX_10_EXP__;4932;__DECIMAL_DIG__;21;__LDBL_MAX__;1.18973149535723176502e+4932L;__LDBL_MIN__;3.36210314311209350626e-4932L;__LDBL_EPSILON__;1.08420217248550443401e-19L;__LDBL_DENORM_MIN__;3.64519953188247460253e-4951L;__LDBL_HAS_DENORM__;1;__LDBL_HAS_INFINITY__;1;__LDBL_HAS_QUIET_NAN__;1;__DEC32_MANT_DIG__;7;__DEC32_MIN_EXP__;(-94);__DEC32_MAX_EXP__;97;__DEC32_MIN__;1E-95DF;__DEC32_MAX__;9.999999E96DF;__DEC32_EPSILON__;1E-6DF;__DEC32_SUBNORMAL_MIN__;0.000001E-95DF;__DEC64_MANT_DIG__;16;__DEC64_MIN_EXP__;(-382);__DEC64_MAX_EXP__;385;__DEC64_MIN__;1E-383DD;__DEC64_MAX__;9.999999999999999E384DD;__DEC64_EPSILON__;1E-15DD;__DEC64_SUBNORMAL_MIN__;0.000000000000001E-383DD;__DEC128_MANT_DIG__;34;__DEC128_MIN_EXP__;(-6142);__DEC128_MAX_EXP__;6145;__DEC128_MIN__;1E-6143DL;__DEC128_MAX__;9.999999999999999999999999999999999E6144DL;__DEC128_EPSILON__;1E-33DL;__DEC128_SUBNORMAL_MIN__;0.000000000000000000000000000000001E-6143DL;__REGISTER_PREFIX__;
;__USER_LABEL_PREFIX__;_;__GNUC_GNU_INLINE__;1;__NO_INLINE__;1;__GCC_ATOMIC_BOOL_LOCK_FREE;1;__GCC_ATOMIC_CHAR_LOCK_FREE;1;__GCC_ATOMIC_CHAR16_T_LOCK_FREE;1;__GCC_ATOMIC_CHAR32_T_LOCK_FREE;1;__GCC_ATOMIC_WCHAR_T_LOCK_FREE;1;__GCC_ATOMIC_SHORT_LOCK_FREE;1;__GCC_ATOMIC_INT_LOCK_FREE;1;__GCC_ATOMIC_LONG_LOCK_FREE;1;__GCC_ATOMIC_LLONG_LOCK_FREE;1;__GCC_ATOMIC_TEST_AND_SET_TRUEVAL;1;__GCC_ATOMIC_POINTER_LOCK_FREE;1;__PRAGMA_REDEFINE_EXTNAME;1;__SIZEOF_WCHAR_T__;2;__SIZEOF_WINT_T__;2;__SIZEOF_PTRDIFF_T__;4;__i386;1;__i386__;1;i386;1;__tune_i386__;1;_X86_;1;__stdcall;__attribute__((__stdcall__));__fastcall;__attribute__((__fastcall__));__thiscall;__attribute__((__thiscall__));__cdecl;__attribute__((__cdecl__));_stdcall;__attribute__((__stdcall__));_fastcall;__attribute__((__fastcall__));_thiscall;__attribute__((__thiscall__));_cdecl;__attribute__((__cdecl__));__GXX_MERGED_TYPEINFO_NAMES;
;__GXX_TYPEINFO_EQUALITY_INLINE;
;__MSVCRT__;1;__MINGW32__;1;_WIN32;1;__WIN32;1;__WIN32__;1;WIN32;1;__WINNT;1;__WINNT__;1;WINNT;1;_INTEGRAL_MAX_BITS;64;__declspec(x);__attribute__((x));__DECIMAL_BID_FORMAT__;1;__STDC__;1;__cplusplus;199711L;__STDC_HOSTED__;1;__GNUC__;4;__GNUC_MINOR__;7;__GNUC_PATCHLEVEL__;1;__VERSION__;"4.7.1";__ATOMIC_RELAXED;
;__SIZEOF_INT__;4;__SIZEOF_LONG__;4;__SIZEOF_LONG_LONG__;8;__SIZEOF_SHORT__;2;__SIZEOF_FLOAT__;4;__SIZEOF_DOUBLE__;8;__SIZEOF_LONG_DOUBLE__;12;__SIZEOF_SIZE_T__;4;__CHAR_BIT__;8;__BIGGEST_ALIGNMENT__;16;__ORDER_LITTLE_ENDIAN__;1234;__ORDER_BIG_ENDIAN__;4321;__ORDER_PDP_ENDIAN__;3412;__BYTE_ORDER__;__ORDER_LITTLE_ENDIAN__;__FLOAT_WORD_ORDER__;__ORDER_LITTLE_ENDIAN__;__SIZEOF_POINTER__;4;__GNUG__;4;__SIZE_TYPE__;unsigned
int;__GXX_WEAK__;1;__DEPRECATED;1;__GXX_RTTI;1;__EXCEPTIONS;1;__GXX_ABI_VERSION;1002;__USING_SJLJ_EXCEPTIONS__;1;__SCHAR_MAX__;127;__SHRT_MAX__;32767;__INT_MAX__;2147483647;__LONG_MAX__;2147483647L;__LONG_LONG_MAX__;9223372036854775807LL;__WCHAR_MAX__;65535;__WCHAR_MIN__;
ULL;__INT_FAST8_MAX__;127;__INT_FAST16_MAX__;32767;__INT_FAST32_MAX__;2147483647;__INT_FAST64_MAX__;9223372036854775807LL;__UINT_FAST8_MAX__;255;__UINT_FAST16_MAX__;65535;__UINT_FAST32_MAX__;4294967295U;__UINT_FAST64_MAX__;18446744073709551615ULL;__INTPTR_MAX__;2147483647;__UINTPTR_MAX__;4294967295U;__FLT_EVAL_METHOD__;2;__DEC_EVAL_METHOD__;2;__FLT_RADIX__;2;__FLT_MANT_DIG__;24;__FLT_DIG__;6;__FLT_MIN_EXP__;(-125);__FLT_MIN_10_EXP__;(-37);__FLT_MAX_EXP__;128;__FLT_MAX_10_EXP__;38;__FLT_DECIMAL_DIG__;9;__FLT_MAX__;3.40282346638528859812e+38F;__FLT_MIN__;1.17549435082228750797e-38F;__FLT_EPSILON__;1.19209289550781250000e-7F;__FLT_DENORM_MIN__;1.40129846432481707092e-45F;__FLT_HAS_DENORM__;1;__FLT_HAS_INFINITY__;1;__FLT_HAS_QUIET_NAN__;1;__DBL_MANT_DIG__;53;__DBL_DIG__;15;__DBL_MIN_EXP__;(-1021);__DBL_MIN_10_EXP__;(-307);__DBL_MAX_EXP__;1024;__DBL_MAX_10_EXP__;308;__DBL_DECIMAL_DIG__;17;__DBL_MAX__;double(1.79769313486231570815e+308L);__DBL_MIN__;double(2.22507385850720138309e-308L);__DBL_EPSILON__;double(2.22044604925031308085e-16L);__DBL_DENORM_MIN__;double(4.94065645841246544177e-324L);__DBL_HAS_DENORM__;1;__DBL_HAS_INFINITY__;1;__DBL_HAS_QUIET_NAN__;1;__LDBL_MANT_DIG__;64;__LDBL_DIG__;18;__LDBL_MIN_EXP__;(-16381);__LDBL_MIN_10_EXP__;(-4931);__LDBL_MAX_EXP__;16384;__LDBL_MAX_10_EXP__;4932;__DECIMAL_DIG__;21;__LDBL_MAX__;1.18973149535723176502e+4932L;__LDBL_MIN__;3.36210314311209350626e-4932L;__LDBL_EPSILON__;1.08420217248550443401e-19L;__LDBL_DENORM_MIN__;3.64519953188247460253e-4951L;__LDBL_HAS_DENORM__;1;__LDBL_HAS_INFINITY__;1;__LDBL_HAS_QUIET_NAN__;1;__DEC32_MANT_DIG__;7;__DEC32_MIN_EXP__;(-94);__DEC32_MAX_EXP__;97;__DEC32_MIN__;1E-95DF;__DEC32_MAX__;9.999999E96DF;__DEC32_EPSILON__;1E-6DF;__DEC32_SUBNORMAL_MIN__;0.000001E-95DF;__DEC64_MANT_DIG__;16;__DEC64_MIN_EXP__;(-382);__DEC64_MAX_EXP__;385;__DEC64_MIN__;1E-383DD;__DEC64_MAX__;9.999999999999999E384DD;__DEC64_EPSILON__;1E-15DD;__DEC64_SUBNORMAL_MIN__;0.000000000000001E-383DD;__DEC128_MANT_DIG__;34;__DEC128_MIN_EXP__;(-6142);__DEC128_MAX_EXP__;6145;__DEC128_MIN__;1E-6143DL;__DEC128_MAX__;9.999999999999999999999999999999999E6144DL;__DEC128_EPSILON__;1E-33DL;__DEC128_SUBNORMAL_MIN__;0.000000000000000000000000000000001E-6143DL;__REGISTER_PREFIX__;
;__USER_LABEL_PREFIX__;_;__GNUC_GNU_INLINE__;1;__NO_INLINE__;1;__WCHAR_UNSIGNED__;1;__GCC_ATOMIC_BOOL_LOCK_FREE;1;__GCC_ATOMIC_CHAR_LOCK_FREE;1;__GCC_ATOMIC_CHAR16_T_LOCK_FREE;1;__GCC_ATOMIC_CHAR32_T_LOCK_FREE;1;__GCC_ATOMIC_WCHAR_T_LOCK_FREE;1;__GCC_ATOMIC_SHORT_LOCK_FREE;1;__GCC_ATOMIC_INT_LOCK_FREE;1;__GCC_ATOMIC_LONG_LOCK_FREE;1;__GCC_ATOMIC_LLONG_LOCK_FREE;1;__GCC_ATOMIC_TEST_AND_SET_TRUEVAL;1;__GCC_ATOMIC_POINTER_LOCK_FREE;1;__PRAGMA_REDEFINE_EXTNAME;1;__SIZEOF_WCHAR_T__;2;__SIZEOF_WINT_T__;2;__SIZEOF_PTRDIFF_T__;4;__i386;1;__i386__;1;i386;1;__tune_i386__;1;_X86_;1;__stdcall;__attribute__((__stdcall__));__fastcall;__attribute__((__fastcall__));__thiscall;__attribute__((__thiscall__));__cdecl;__attribute__((__cdecl__));_stdcall;__attribute__((__stdcall__));_fastcall;__attribute__((__fastcall__));_thiscall;__attribute__((__thiscall__));_cdecl;__attribute__((__cdecl__));__GXX_MERGED_TYPEINFO_NAMES;
//CXX compiler system include directories
CMAKE_EXTRA_GENERATOR_CXX_SYSTEM_INCLUDE_DIRS:INTERNAL=c:\program
files\codeblocks\mingw\bin\../lib/gcc/mingw32/4.7.1/include/c++;c:\program
files\codeblocks\mingw\bin\../lib/gcc/mingw32/4.7.1/include/c++/mingw32;c:\program
files\codeblocks\mingw\bin\../lib/gcc/mingw32/4.7.1/include/c++/backward;c:\program
files\codeblocks\mingw\bin\../lib/gcc/mingw32/4.7.1/include;c:\program
files\codeblocks\mingw\bin\../lib/gcc/mingw32/4.7.1/../../../../include;c:\program
files\codeblocks\mingw\bin\../lib/gcc/mingw32/4.7.1/include-fixed
//C compiler system defined macros
CMAKE_EXTRA_GENERATOR_C_SYSTEM_DEFINED_MACROS:INTERNAL=__STDC__;1;__STDC_HOSTED__;1;__GNUC__;4;__GNUC_MINOR__;7;__GNUC_PATCHLEVEL__;1;__VERSION__;"4.7.1";__ATOMIC_RELAXED;
//C compiler system include directories
CMAKE_EXTRA_GENERATOR_C_SYSTEM_INCLUDE_DIRS:INTERNAL=c:\program
//Name of generator.
CMAKE_GENERATOR:INTERNAL=MinGW Makefiles
//Name of generator toolset.
CMAKE_GENERATOR_TOOLSET:INTERNAL=
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=C:/dev/CGAL-4.5
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_NM
CMAKE_NM-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=7
//ADVANCED property for variable: CMAKE_OBJCOPY
CMAKE_OBJCOPY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_OBJDUMP
CMAKE_OBJDUMP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_RANLIB
CMAKE_RANLIB-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_COMPILER
CMAKE_RC_COMPILER-ADVANCED:INTERNAL=1
CMAKE_RC_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_FLAGS
CMAKE_RC_FLAGS-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/share/cmake-3.0
//ADVANCED property for variable: CMAKE_SH
CMAKE_SH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_INSTALL_RPATH
CMAKE_SKIP_INSTALL_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS
CMAKE_STATIC_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_DEBUG
CMAKE_STATIC_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELEASE
CMAKE_STATIC_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STRIP
CMAKE_STRIP-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
CMAKE_UNAME:INTERNAL=CMAKE_UNAME-NOTFOUND
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
CONFIG_CXX_FLAGS:INTERNAL= -frounding-math
EXECUTABLE_OUTPUT_PATH:INTERNAL=
//Details about finding GMP
FIND_PACKAGE_MESSAGE_DETAILS_GMP:INTERNAL=[C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll][C:/dev/CGAL-4.5/auxiliary/gmp/include][v()]
//Details about finding OpenGL
FIND_PACKAGE_MESSAGE_DETAILS_OpenGL:INTERNAL=[opengl32][v()]
GCC_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
GCC_RUN_RES:INTERNAL=0
GMP_COMPILE_RES:INTERNAL=FALSE
GMP_IN_CGAL_AUXILIARY:INTERNAL=TRUE
LIBRARY_OUTPUT_PATH:INTERNAL=
MPFR_COMPILE_RES:INTERNAL=FALSE
OPENGL_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
OPENGL_RUN_RES:INTERNAL=0
//ADVANCED property for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_INCLUDE_DIR
QT3_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_MOC_EXECUTABLE
QT3_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QASSISTANTCLIENT_LIBRARY
QT3_QASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QTMAIN_LIBRARY
QT3_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_QT_LIBRARY
QT3_QT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT3_UIC_EXECUTABLE
QT3_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
QT4_COMPILE_RES:INTERNAL=TRUE
//Result of TRY_RUN
QT4_RUN_RES:INTERNAL=0
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_DEBUG
QT_ARTHURPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_RELEASE
QT_ARTHURPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_BINARY_DIR:INTERNAL=C:/Qt/4.8.6/bin
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_DEBUG
QT_CONTAINEREXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_RELEASE
QT_CONTAINEREXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE
QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE
QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DESIGNER_EXECUTABLE
QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DOC_DIR
QT_DOC_DIR-ADVANCED:INTERNAL=1
QT_HEADERS_DIR:INTERNAL=C:/Qt/4.8.6/include
//ADVANCED property for variable: QT_IMPORTS_DIR
QT_IMPORTS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LIBRARY_DIR
QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
//Qt library dir
QT_LIBRARY_DIR:INTERNAL=C:/Qt/4.8.6/lib
//ADVANCED property for variable: QT_LINGUIST_EXECUTABLE
QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LRELEASE_EXECUTABLE
QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LUPDATE_EXECUTABLE
QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MKSPECS_DIR
QT_MKSPECS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MOC_EXECUTABLE
QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_DEBUG
QT_PHONONWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_RELEASE
QT_PHONONWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_DS9_PLUGIN_DEBUG
QT_PHONON_DS9_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_DS9_PLUGIN_RELEASE
QT_PHONON_DS9_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_INCLUDE_DIR
QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY
QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG
QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE
QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PLUGINS_DIR
QT_PLUGINS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_INCLUDE_DIR
QT_QAXCONTAINER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY
QT_QAXCONTAINER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY_DEBUG
QT_QAXCONTAINER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY_RELEASE
QT_QAXCONTAINER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_INCLUDE_DIR
QT_QAXSERVER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY
QT_QAXSERVER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY_DEBUG
QT_QAXSERVER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY_RELEASE
QT_QAXSERVER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_DEBUG
QT_QCNCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_RELEASE
QT_QCNCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE
QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_DEBUG
QT_QCOREWLANBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_RELEASE
QT_QCOREWLANBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_DEBUG
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_RELEASE
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_DEBUG
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_RELEASE
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_DEBUG
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_RELEASE
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_DEBUG
QT_QGENERICBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_RELEASE
QT_QGENERICBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_DEBUG
QT_QGIF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_RELEASE
QT_QGIF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_DEBUG
QT_QICO_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_RELEASE
QT_QICO_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_DEBUG
QT_QIMSW_MULTI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_RELEASE
QT_QIMSW_MULTI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_DEBUG
QT_QJPCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_RELEASE
QT_QJPCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_DEBUG
QT_QJPEG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_RELEASE
QT_QJPEG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_DEBUG
QT_QKRCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_RELEASE
QT_QKRCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_QMAKE_EXECUTABLE_LAST:INTERNAL=C:/Qt/4.8.6/bin/qmake.exe
//ADVANCED property for variable: QT_QMNG_PLUGIN_DEBUG
QT_QMNG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QMNG_PLUGIN_RELEASE
QT_QMNG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG
QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE
QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_DEBUG
QT_QSQLDB2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_RELEASE
QT_QSQLDB2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_DEBUG
QT_QSQLIBASE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_RELEASE
QT_QSQLIBASE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_DEBUG
QT_QSQLITE2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_RELEASE
QT_QSQLITE2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_DEBUG
QT_QSQLITE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_RELEASE
QT_QSQLITE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_DEBUG
QT_QSQLMYSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_RELEASE
QT_QSQLMYSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_DEBUG
QT_QSQLOCI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_RELEASE
QT_QSQLOCI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_DEBUG
QT_QSQLODBC_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_RELEASE
QT_QSQLODBC_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_DEBUG
QT_QSQLPSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_RELEASE
QT_QSQLPSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_DEBUG
QT_QSQLTDS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_RELEASE
QT_QSQLTDS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_DEBUG
QT_QSVGICON_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_RELEASE
QT_QSVGICON_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_DEBUG
QT_QSVG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_RELEASE
QT_QSVG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR
QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY
QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR
QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY
QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR
QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY
QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG
QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE
QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY
QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG
QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE
QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR
QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY
QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG
QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE
QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR
QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY
QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG
QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE
QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR
QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY
QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG
QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE
QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY
QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR
QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY
QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG
QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE
QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGA_PLUGIN_DEBUG
QT_QTGA_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGA_PLUGIN_RELEASE
QT_QTGA_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR
QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY
QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG
QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE
QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR
QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY
QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG
QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE
QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_DEBUG
QT_QTIFF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_RELEASE
QT_QTIFF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY
QT_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY_DEBUG
QT_QTMAIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY_RELEASE
QT_QTMAIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR
QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY
QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG
QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE
QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR
QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY
QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG
QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE
QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR
QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY
QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR
QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY
QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG
QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE
QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_DEBUG
QT_QTSCRIPTDBUS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_RELEASE
QT_QTSCRIPTDBUS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR
QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY
QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR
QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY
QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG
QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE
QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR
QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY
QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG
QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE
QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR
QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY
QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG
QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE
QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR
QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY
QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG
QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE
QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR
QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY
QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG
QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE
QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_DEBUG
QT_QTWCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_RELEASE
QT_QTWCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR
QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY
QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG
QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE
QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR
QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY
QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG
QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE
QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_INCLUDE_DIR
QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY
QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG
QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE
QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_DEBUG
QT_QWEBVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_RELEASE
QT_QWEBVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_RCC_EXECUTABLE
QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_DEBUG
QT_TASKMENUEXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_RELEASE
QT_TASKMENUEXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TRANSLATIONS_DIR
QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC3_EXECUTABLE
QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC_EXECUTABLE
QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//Have symbol Q_WS_MAC
Q_WS_MAC:INTERNAL=
//Have symbol Q_WS_QWS
Q_WS_QWS:INTERNAL=
//Have symbol Q_WS_WIN
Q_WS_WIN:INTERNAL=1
//Have symbol Q_WS_X11
Q_WS_X11:INTERNAL=
//ADVANCED property for variable: ZLIB_INCLUDE_DIR
ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: ZLIB_LIBRARY
ZLIB_LIBRARY-ADVANCED:INTERNAL=1
//Last used Boost_ADDITIONAL_VERSIONS value.
_Boost_ADDITIONAL_VERSIONS_LAST:INTERNAL=1.56.1;1.56.0;1.56;1.55.1;1.55.0;1.55;1.54.1;1.54.0;1.54;1.53.1;1.53.0;1.53;1.52.1;1.52.0;1.52;1.51.1;1.51.0;1.51;1.50.1;1.50.0;1.50;1.49.1;1.49.0;1.49;1.48.1;1.48.0;1.48;1.47.1;1.47.0;1.47;1.46.1;1.46.0;1.46;1.45.1;1.45.0;1.45;1.44.1;1.44.0;1.44;1.43.1;1.43.0;1.43;1.42.1;1.42.0;1.42;1.41.1;1.41.0;1.41;1.40.1;1.40.0;1.40;1.39.1;1.39.0;1.39;1.38.1;1.38.0;1.38;1.37.1;1.37.0;1.37
//Components requested for this build tree.
_Boost_COMPONENTS_SEARCHED:INTERNAL=system;thread
//Last used Boost_INCLUDE_DIR value.
_Boost_INCLUDE_DIR_LAST:INTERNAL=C:/dev/boost_1_57_0
//Last used Boost_NAMESPACE value.
_Boost_NAMESPACE_LAST:INTERNAL=boost
//Last used Boost_USE_MULTITHREADED value.
_Boost_USE_MULTITHREADED_LAST:INTERNAL=TRUE
//Last used Boost_USE_STATIC_LIBS value.
_Boost_USE_STATIC_LIBS_LAST:INTERNAL=OFF
*And here is the error message* :
== Setting paths ==
Build CGAL from release in directory CGAL-4.5
Packagenames: CGAL-4.5
== Setting paths (DONE) ==
== Generate version files ==
CGAL_MAJOR_VERSION=4
CGAL_MINOR_VERSION=5
CGAL_BUGFIX_VERSION=0
CGAL_SONAME_VERSION=10
CGAL_SOVERSION =10.0.4
CGAL_REFERENCE_CACHE_DIR=
Building shared libraries
Targetting MinGW Makefiles
Using C:/Program Files/CodeBlocks/MinGW/bin/g++.exe compiler.
USING CMake version: 3.0.2
System: Windows
USING GCC_VERSION = '4.7.1'
Using gcc version 4 or later. Adding -frounding-math
== Generate version files (DONE) ==
== Set up flags ==
Build type: Release
USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
USING LDFLAGS = ' '
== Set up flags (DONE) ==
== Detect external libraries ==
External libraries supported:
Preconfiguring library: GMP ...
GMP has been preconfigured:
UseGMP-file:
GMP include: C:/dev/CGAL-4.5/auxiliary/gmp/include
GMP libraries: C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll
GMP definitions:
WARNING: GMP found but could not compile print_GMP_version.cpp:
GMP_INCLUDE_DIR=C:/dev/CGAL-4.5/auxiliary/gmp/include
GMP_LIBRARIES=C:/dev/CGAL-4.5/auxiliary/gmp/lib/libgmp-10.dll
GMP_LIBRARIES_DIR=C:/dev/CGAL-4.5/auxiliary/gmp/lib
Change Dir: C:/dev/CGAL-4.5/build/CMakeFiles/CMakeTmp
Run Build Command:"C:/PROGRA~1/CODEBL~1/MinGW/bin/mingw32-make.exe"
"cmTryCompileExec2183705917/fast"
C:/PROGRA~1/CODEBL~1/MinGW/bin/mingw32-make.exe -f
CMakeFiles\cmTryCompileExec2183705917.dir\build.make
CMakeFiles/cmTryCompileExec2183705917.dir/build
mingw32-make.exe[1]: Entering directory
`C:/dev/CGAL-4.5/build/CMakeFiles/CMakeTmp'
C:\Users\Alain\Documents\exe_noinstall\cmake-3.0.2-win32-x86\cmake-3.0.2-win32-x86\bin\cmake.exe
-E cmake_progress_report
C:\dev\CGAL-4.5\build\CMakeFiles\CMakeTmp\CMakeFiles 1
Building CXX object
CMakeFiles/cmTryCompileExec2183705917.dir/print_GMP_version.cpp.obj
C:\PROGRA~1\CODEBL~1\MinGW\bin\G__~1.EXE -frounding-math
@CMakeFiles/cmTryCompileExec2183705917.dir/includes_CXX.rsp -o
CMakeFiles\cmTryCompileExec2183705917.dir\print_GMP_version.cpp.obj -c
C:\dev\CGAL-4.5\config\support\print_GMP_version.cpp
Linking CXX executable cmTryCompileExec2183705917.exe
-E cmake_link_script CMakeFiles\cmTryCompileExec2183705917.dir\link.txt
--verbose=1
-E remove -f CMakeFiles\cmTryCompileExec2183705917.dir/objects.a
C:\PROGRA~1\CODEBL~1\MinGW\bin\ar.exe cr
@CMakeFiles\cmTryCompileExec2183705917.dir\objects1.rsp
-Wl,--whole-archive CMakeFiles\cmTryCompileExec2183705917.dir/objects.a
-Wl,--no-whole-archive -o cmTryCompileExec2183705917.exe
-Wl,--out-implib,libcmTryCompileExec2183705917.dll.a
-Wl,--major-image-version,0,--minor-image-version,0
-LC:\dev\CGAL-4.5\auxiliary\gmp\lib
C:\dev\CGAL-4.5\auxiliary\gmp\lib\libgmp-10.dll -lkernel32 -luser32 -lgdi32
-lwinspool -lshell32 -lole32 -loleaut32 -luuid -lcomdlg32 -ladvapi32
C:\dev\CGAL-4.5\auxiliary\gmp\lib\libgmp-10.dll: file not recognized: File
format not recognized
collect2.exe: error: ld returned 1 exit status
mingw32-make.exe[1]: *** [cmTryCompileExec2183705917.exe] Error 1
mingw32-make.exe[1]: Leaving directory
mingw32-make.exe: *** [cmTryCompileExec2183705917/fast] Error 2
USING GMP_VERSION = 'unknown'
Preconfiguring library: MPFR ...
MPFR has been preconfigured:
UseMPFR-file:
MPFR include: C:/dev/CGAL-4.5/auxiliary/mpfr/include
MPFR libraries: C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib
MPFR definitions:
WARNING: MPFR found but could not compile print_MPFR_version.cpp:
MPFR_INCLUDE_DIR=C:/dev/CGAL-4.5/auxiliary/mpfr/include
MPFR_LIBRARIES=C:/dev/CGAL-4.5/auxiliary/mpfr/lib/libmpfr-4.lib
MPFR_LIBRARIES_DIR=
"cmTryCompileExec2575762988/fast"
CMakeFiles\cmTryCompileExec2575762988.dir\build.make
CMakeFiles/cmTryCompileExec2575762988.dir/build
Building CXX object
CMakeFiles/cmTryCompileExec2575762988.dir/print_MPFR_version.cpp.obj
@CMakeFiles/cmTryCompileExec2575762988.dir/includes_CXX.rsp -o
CMakeFiles\cmTryCompileExec2575762988.dir\print_MPFR_version.cpp.obj -c
C:\dev\CGAL-4.5\config\support\print_MPFR_version.cpp
Linking CXX executable cmTryCompileExec2575762988.exe
-E cmake_link_script CMakeFiles\cmTryCompileExec2575762988.dir\link.txt
--verbose=1
-E remove -f CMakeFiles\cmTryCompileExec2575762988.dir/objects.a
@CMakeFiles\cmTryCompileExec2575762988.dir\objects1.rsp
-Wl,--whole-archive CMakeFiles\cmTryCompileExec2575762988.dir/objects.a
-Wl,--no-whole-archive -o cmTryCompileExec2575762988.exe
-Wl,--out-implib,libcmTryCompileExec2575762988.dll.a
C:\dev\CGAL-4.5\auxiliary\mpfr\lib\libmpfr-4.lib
mingw32-make.exe[1]: *** [cmTryCompileExec2575762988.exe] Error 1
mingw32-make.exe: *** [cmTryCompileExec2575762988/fast] Error 2
USING MPFR_VERSION = 'unknown'
CMake Error at
C:/Users/Alain/Documents/exe_noinstall/cmake-3.0.2-win32-x86/cmake-3.0.2-win32-x86/share/cmake-3.0/Modules/FindBoost.cmake:1179
(message):
Unable to find the requested Boost libraries.
Boost version: 1.57.0
Boost include path: C:/dev/boost_1_57_0
Could not find the following Boost libraries:
boost_thread
boost_system
No Boost libraries were found. You may need to set BOOST_LIBRARYDIR to
the
directory containing Boost libraries or BOOST_ROOT to the location of
Boost.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:85 (include)
CMakeLists.txt:639 (include)
Boost include: C:/dev/boost_1_57_0
Boost libraries:
Boost definitions:
USING BOOST_VERSION = '1.57.0'
== Detect external libraries (DONE) ==
== Write compiler_config.h ==
Performing Test CGAL_CFG_BOOST_VARIANT_SWAP_BUG - Failed
Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
Performing Test CGAL_CFG_IEEE_754_BUG - Success
Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
Performing Test CGAL_CFG_MATCHING_BUG_6 - Success
Performing Test CGAL_CFG_MATCHING_BUG_7 - Success
Performing Test CGAL_CFG_MATCHING_BUG_8 - Success
Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Success
Performing Test CGAL_CFG_NO_LIMITS - Success
Performing Test CGAL_CFG_NO_NEXTAFTER - Success
Performing Test CGAL_CFG_NO_STL - Success
Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Success
Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
== Write compiler_config.h (DONE) ==
== Generating build files ==
Configuring libCGAL
Requested component: MPFR
Requested component: GMP
libCGAL is configured
Sources for CGAL component library 'CGAL_Core' detected
Configuring libCGAL_Core
libCGAL_Core is configured
Sources for CGAL component library 'CGAL_ImageIO' detected
Configuring libCGAL_ImageIO
Found OpenGL: opengl32
Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
OpenGL include:
OpenGL libraries: glu32;opengl32
libCGAL_ImageIO is configured
NOTICE: libCGAL_ImageIO needs ZLib to read compressed files. That feature
will not be activated.
Sources for CGAL component library 'CGAL_Qt3' detected
Configuring libCGAL_Qt3
libCGAL_Qt3 needs Qt3, cannot be configured.
Sources for CGAL component library 'CGAL_Qt4' detected
Configuring libCGAL_Qt4
Looking for Q_WS_X11
Looking for Q_WS_X11 - not found
Looking for Q_WS_WIN
Looking for Q_WS_WIN - found
Looking for Q_WS_QWS
Looking for Q_WS_QWS - not found
Looking for Q_WS_MAC
Looking for Q_WS_MAC - not found
USING OPENGL_VERSION = '1.1'
USING QT4_VERSION = '4.8.6'
OpenGL include:
OpenGL definitions:
Qt4 include: C:/Qt/4.8.6/include
Qt4 libraries:
Qt4 definitions: -DQT_DLL
moc executable: C:/Qt/4.8.6/bin/moc.exe
uic executable: C:/Qt/4.8.6/bin/uic.exe
libCGAL_Qt4 is configured
Sources for CGAL component libraries
'CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt4' detected
== Generating build files (DONE) ==
Configuring incomplete, errors occurred!
See also "C:/dev/CGAL-4.5/build/CMakeFiles/CMakeOutput.log".
See also "C:/dev/CGAL-4.5/build/CMakeFiles/CMakeError.log".
I use the cmake gui CMake 3.0.2
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/need-help-for-installing-cgal-4-5-tp4660117p4660149.html
- [cgal-discuss] need help for installing cgal 4.5, Alain Ralambo, 11/14/2014
- Re: [cgal-discuss] need help for installing cgal 4.5, Sebastien Loriot (GeometryFactory), 11/20/2014
- Re: [cgal-discuss] need help for installing cgal 4.5, Laurent Rineau (CGAL/GeometryFactory), 11/20/2014
- Re: [cgal-discuss] need help for installing cgal 4.5, alainR, 11/21/2014
