- To:
- Subject: Re: [cgal-discuss] CGAL_vc110_mt_gd_4.5.dll is missing and is not generated!
- Date: Mon, 24 Nov 2014 15:39:28 +0100
Le Friday 14 November 2014 12:49:47 ramigmodi a écrit :
> Well I have it's .lib and .exp in the build/lib/debug but Not .dll in bin!
The .lib/.exp should both be in build/lib/ and build/lib/Debug/, and the .dll
should be both in build/bin/ and build/bin/Debug/. What do you have in
build/bin/ ?
> And here is the cmake output:
> == Setting paths ==
> Build CGAL from release in directory CGAL-4.5
> Packagenames: CGAL-4.5
I do not see anything particular in the CMake output, apart that you are
using
CMake-3.1 that we have never tested so far.
Laurent Rineau, PhD
- [cgal-discuss] CGAL_vc110_mt_gd_4.5.dll is missing and is not generated!, ramigmodi, 11/13/2014
- Re: [cgal-discuss] CGAL_vc110_mt_gd_4.5.dll is missing and is not generated!, Laurent Rineau (CGAL/GeometryFactory), 11/14/2014
- Re: [cgal-discuss] CGAL_vc110_mt_gd_4.5.dll is missing and is not generated!, ramigmodi, 11/14/2014
- Re: [cgal-discuss] CGAL_vc110_mt_gd_4.5.dll is missing and is not generated!, Laurent Rineau (CGAL/GeometryFactory), 11/24/2014
- Re: [cgal-discuss] CGAL_vc110_mt_gd_4.5.dll is missing and is not generated!, Ramin Irani, 11/29/2014
