cgal-discuss - [cgal-discuss] Surface mesh simplification placement policies
  • To:
  • Subject: [cgal-discuss] Surface mesh simplification placement policies
  • Date: Mon, 24 Nov 2014 17:09:01 -0500
Dear list:
I have a slightly modified surface mesh simplification code, with
the previous help from Fernando Cacciola, compiled for my meshing
toolbox "iso2mesh". I just made some changes to this code to
add the support for the default Lindstrom Turk placement policy
in addition to the Midpoint placement, allowing them to be selected
through the command options. However, my modified code no
longer compiles.
My code change can be found at
https://sourceforge.net/p/iso2mesh/code/456
and the full sample unit can be browsed here:
https://sourceforge.net/p/iso2mesh/code/HEAD/tree/trunk/cgalsimp2/edge_collapse_enriched_polyhedron.cpp
(the previous changes suggested by Fernando was to
fix the edges on the boundary when a surface is open)
the compilation errors are attached.
Perhaps there is something simple that I have overlooked, can someone
tell me how can I get this to work?
My second question: using the Midpoint placement method, a
simplified surface often presents self-intersecting elements. I am
wondering if the LT placement, or any other approaches that can
prevent the surface elements from intersecting after decimation?
thanks
Qianqian
Building CXX object
examples/Surface_mesh_simplification/CMakeFiles/edge_collapse_enriched_polyhedron.dir/edge_collapse_enriched_polyhedron.o
In file included from
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse.h:355:0,
from
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/edge_collapse.h:24,
from
CGAL-3.8-beta1/examples/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp:24:
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:
In member function ‘int
CGAL::Surface_mesh_simplification::EdgeCollapse<ECM_, ShouldStop_,
VertexIndexMap_, EdgeIndexMap_, EdgeIsBorderMap_, GetCost_, GetPlacement_,
VisitorT_>::run() [with ECM_ =
CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3>, ShouldStop_ =
CGAL::Surface_mesh_simplification::Count_ratio_stop_predicate<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> >, VertexIndexMap_ =
CGAL::Polyhedron_vertex_index_map_external<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3, CGAL::HalfedgeDS_default,
std::allocator<int> >, EdgeIndexMap_ =
CGAL::Polyhedron_edge_index_map_external<CGAL::Simple_cartesian<double>,
std::allocator<int> >, EdgeIsBorderMap_ =
CGAL::Polyhedron_edge_is_border_map<CGAL::Simple_cartesian<double>,
std::allocator<int> >, GetCost_ =
Cost_with_fixed_edges<CGAL::Surface_mesh_simplification::LindstromTurk_cost<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> > >, GetPlacement_ =
CGAL::Surface_mesh_simplification::LindstromTurk_placement<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> >, VisitorT_ = Visitor*]’:
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/edge_collapse.h:77:24:
instantiated from ‘int
CGAL::Surface_mesh_simplification::edge_collapse(ECM&, const ShouldStop&,
const VertexIndexMap&, const EdgeIndexMap&, const EdgeIsBorderMap&, const
GetCost&, const GetPlacement&, Visitor) [with ECM =
CGAL::Polyhedron_items_with_id_3>, ShouldStop =
CGAL::Polyhedron_items_with_id_3> >, VertexIndexMap =
std::allocator<int> >, EdgeIndexMap =
std::allocator<int> >, EdgeIsBorderMap =
std::allocator<int> >, GetCost =
CGAL::Polyhedron_items_with_id_3> > >, GetPlacement =
CGAL::Polyhedron_items_with_id_3> >, Visitor = Visitor*]’
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/edge_collapse.h:115:23:
const CGAL::cgal_bgl_named_params<P, T, R>&) [with ECM =
CGAL::Polyhedron_items_with_id_3> >, P = Visitor*, T =
boost::graph_visitor_t, R =
CGAL::cgal_bgl_named_params<CGAL::Surface_mesh_simplification::LindstromTurk_placement<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> >, CGAL::get_placement_policy_t,
CGAL::cgal_bgl_named_params<Cost_with_fixed_edges<CGAL::Surface_mesh_simplification::LindstromTurk_cost<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> > >, CGAL::get_cost_policy_t,
CGAL::cgal_bgl_named_params<CGAL::Polyhedron_edge_index_map_external<CGAL::Simple_cartesian<double>,
std::allocator<int> >, boost::edge_index_t,
CGAL::cgal_bgl_named_params<CGAL::Polyhedron_vertex_index_map_external<CGAL::Simple_cartesian<double>,
std::allocator<int> >, boost::vertex_index_t, boost::no_property> > > >]’
CGAL-3.8-beta1/examples/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp:217:12:
instantiated from here
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:70:3:
error: request for member ‘OnStarted’ in
‘((CGAL::Surface_mesh_simplification::EdgeCollapse<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
Visitor*>*)this)->CGAL::Surface_mesh_simplification::EdgeCollapse<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> >, Visitor*>::Visitor’, which is of
non-class type
‘CGAL::Surface_mesh_simplification::EdgeCollapse<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Polyhedron_items_with_id_3> >, Visitor*>::VisitorT {aka Visitor*}’
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:82:3:
error: request for member ‘OnFinished’ in
non-class type
Cost_with_fixed_edges<CGAL::Surface_mesh_simplification::Edge_length_cost<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::Surface_mesh_simplification::Midpoint_placement<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::cgal_bgl_named_params<CGAL::Surface_mesh_simplification::Midpoint_placement<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL::cgal_bgl_named_params<Cost_with_fixed_edges<CGAL::Surface_mesh_simplification::Edge_length_cost<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
CGAL-3.8-beta1/examples/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp:227:12:
non-class type
non-class type
In member function ‘void
VisitorT_>::Collect() [with ECM_ =
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:73:3:
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:130:7:
error: request for member ‘OnCollected’ in
non-class type
VisitorT_>::Loop() [with ECM_ =
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:76:3:
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:172:5:
error: request for member ‘OnSelected’ in
non-class type
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:178:9:
error: request for member ‘OnStopConditionReached’ in
non-class type
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:200:9:
error: request for member ‘OnNonCollapsable’ in
non-class type
non-class type
non-class type
non-class type
non-class type
VisitorT_>::Collapse(const Profile&,
VisitorT_>::Placement_type) [with ECM_ =
CGAL::Polyhedron_items_with_id_3> >, VisitorT_ = Visitor*,
VisitorT_>::Profile =
CGAL::Surface_mesh_simplification::Edge_profile<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
VisitorT_>::Placement_type =
boost::optional<CGAL::Point_3<CGAL::Simple_cartesian<double> > >]’:
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:194:11:
instantiated from ‘void
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:659:3:
error: request for member ‘OnCollapsing’ in
non-class type
CGAL-3.8-beta1/examples/Surface_mesh_simplification/../../include/CGAL/Surface_mesh_simplification/Detail/Edge_collapse_impl.h:742:3:
error: request for member ‘OnCollapsed’ in
non-class type
non-class type
non-class type
make[3]: ***
[examples/Surface_mesh_simplification/CMakeFiles/edge_collapse_enriched_polyhedron.dir/edge_collapse_enriched_polyhedron.o]
Error 1
make[2]: ***
[examples/Surface_mesh_simplification/CMakeFiles/edge_collapse_enriched_polyhedron.dir/all]
Error 2
make[1]: ***
[examples/Surface_mesh_simplification/CMakeFiles/edge_collapse_enriched_polyhedron.dir/rule]
Error 2
make: ***
Error 2
